Aaron, great setup you guys have there
I decided also to try this out, but first at my 3kW generator. I disassembled the ignition side and removed the ignition coil from the magneto. Then I made a fastening plate with some holes out of aluminum so that I can now adjust the distance from the magnet to the reed switch and the timing. I made a small test and tried if the magnet can trigger the reed switch and it can. I can also adjust the ON time of the reed switch. The magnet on the wheel is very strong, so I need a rather big distance between the magnet and the reed switch. Here are some pictures:
So I am ready to go further. But at first I have a couple of questions.
1. I am intending to use my UPS to charge up the cap, that will be 230V. Which SCR would you suggest me to use?
2. So at the end what is the best diode config - half bridge or full bridge?
3. Can you touch the engine while it is running? I mean isn't there any electroshocks?
Jetijs
Jetijs
