Water Sparkplug
This topic is closed.
  • Peter, you were right. The problem is not in the frequency.
    It turned out that the problem is in too large capacitance of the booster side cap. At first I was using a voltage quadrupler with four 100uF 450V caps. I could go up to 1000V on the booster side, but the if the discharge frequency was set to 25Hz (the minimum that I need), then there was an ordinary spark on every discharge, but the intensified spark appeared only on every fourth or fifth discharge. I could ho up with the frequency till 100Hz, but the intensified spark appeared only some 4-5 times a second. So I decreased the booster side capacity. I replaced the quadrupler with a bridge rectifier that charges up a 0.82uF 1000V cap through a light bulb. When I turned the variac to full voltage, there was about 300V in the cap. I turned the primary side ON at 100Hz frequency and there was an intensified spark on every discharge. But the effect was rather small, so I doubled the capacity. This made a bigger plasma and was still capable to handle the 100Hz. I increased the capacitance by 0.82uF on each test and the intensified spark seemed to become brighter and louder with each test. I got the capacity up to 6.56 uF, but the spark was the same as when using only about 4uF. So that must be the right capacity. Unfortunately I have only six of those polypropylene caps so I can not make a voltage doubler keeping the same capacity. I already tried that using two 2.46uF caps for the doubler, each made out of three 0.82uF caps in parallel, the spark was almost the same, maybe a little brighter. So I guess that if I increased the voltage keeping the same capacity, I could get bigger blasts. Also I noticed that the bigger capacity on the booster side, the greater also the power consumption from the variac. At capacitance of 6.56 uF, the power consumption from the variac was about 35W. Also, the more power we feed into the spark from the LV side, the hotter the spark plug electrodes become.
    Here is a small video with the intensified spark about 50Hz:
    YouTube - test8
    Now I need to get some more caps and try the same capacity with a voltage doubler.
    Jetijs
    • Nice important test data you share there Jetijs . What happens if you spray water on that btw?
      Btw has anyone tried to use their own wound coils instead of the ignition coil to see what different kind of ratio windings do to the entire system.
      • Broli,
        Yes I tried to spray water on that 50Hz frequency intensified spark, but I could not hear or see any difference. But if I decreased the frequency to 5-10Hz, there was a bigger bang, when the water was sprayed on. This is interesting
        • Technically the same amount of energy should be released at ever frequency right? There should be indeed a reason the big bang is lost at higher frequencies. Maybe it's due to the ammount of diodes. The higher the frequencie the less time they have to recover (this is pure speculation). So a possible solution could be adding more diodes?
          • Capacitor size
            Thanks for the update Jetijs..... glad you getting it dialed in.
            I thought I would insert this link to a discussion on the Dipole and Capacitance as it has great relevance (imo) to why/what you're doing with your circuit at this moment.
            (but forgive me if I'm way off on this )
            • Originally posted by broli View Post
              Right, as long as I do not go past 50Hz, there should be more than enough time for the caps to fully charge. I am not sure about the diodes, I don't think that 50Hz is high enough for these diodes to stress them. I am using 1N5408 diodes for this setup.
              goldenequity, thanks for the link, I will check that out
              • Hi everyone,
                I started a new topic and ask if you can please have a look: http://www.energeticforum.com/renewa...y-charger.html
                Luc
                  YouTube - test8
                  Jetijs
                  Jetijs,
                  Your video was amazing !! Great Work !!
                  Which circuit is this ? I know you've posted several.....
                  Congratulations on your continuing advancements.
                  Timm
                  • Hi Timm
                    This is the exact circuit that is used in that video:
                    • plasma cdi hall effect control
                      Hi everyone,
                      I've completed the design and testing of a twin Hall effect control for the CDI system I've built. The diagram shows looking down into the distributor with cap and rotor removed. It's somewhat pictorial. One hall effect sensor is for the charge pulse and the other is for the discharge pulse. The 2.2k ohm resistors play a dual role. First, each acts as a pull-up resistor. When one of the magnets (little squares on the rotor) passes by the sensor, the 'minus' wire from the sensor goes to high impedance and the 2.2k resistor yanks the 'plus' side of the Mosfet opto up and turning the Mosfet "on". When the window has passed, the sensor yanks it to ground and the Mosfet is turned "off" again. The other purpose of the 2.2k resistor is as a current limiter for the Mosfet's opto. circuitry.
                      This can also be accomplished with just one sensor but would require a "break before make" inverted signal for the opposite circuit. It's easier to add a sensor and resistor than it is to design, build and troubleshoot a circuit ... for me anyway.
                      Peace,
                      Greg
                      • Greg,
                        Will you have to offset the sensors 45 degs for a 4 cylinder ? (30 for a 6)
                        Timm
                        • offset
                          Originally posted by xpskid View Post
                          Greg,
                          Timm
                          Hi Timm,
                          Yes ... very observant! Halfway between so they don't headbutt. That is to say 45 degrees out of phase. It can be 90 deg + 45 or 180 deg + 45 or 270 deg. + 45, and so on ... depends on the room you have till the next position. I'm close! I'll be posting pics of the installation in a couple of days. I'm getting very excited. Boy wasn't J's video impressive? That plug was screaming!
                          There actually is a frequency problem with 50/60 Hz when you start talking multiple cylinders though and especially if you have a finite charge cycle like I have and the core circuit has. If you watch the scope with just one plug (and without the storage Cap) you can sometime witness a misfire and see the low voltage charge from a trough ... especially on a modified sine wave inverter. Not so much with a pure sine wave ... but its' still there.
                          Thanks for replying,
                          Greg
                          • Great work Jetijs & Greg.
                            • Stanley Meyers Demo House Meetings
                              Selling his technology overseas:
                              Rarely seen movies, 3 hours total:
                              REQUIRES DIVX CODEC TO VIEW, OR DIVX PLAYER
                              Index of /stan_meyer
                              MY OWN ROUGH SUMMARY
                              #### Stanley Meyers ####
                              Old circuit electronics used a dead short situation, where voltage increase was not possible, could not climb, and amperage had to take over to do the work. Current technology allows high voltage to do the work instead of amerage. Voltage Intensifier Circuit (VIC), he restricts the amps and allows HV to take over to do the work. He does not use resistors (dead short), but instead uses coils as a choke, which do not consume energy. Coil in series to capacitor creates resonate charging choke. Placing dyelectric liquid between conductive plates gives you a capacitor. He's using magnetic field to restrict amps, not resistive elements: Resistors consume power, short/amps. Add more windings to resonate charging choke coils to increase voltage, which increases hydrogen production. Normally 0khz to10khz, the resonant frequency to split water molecules is broad. Frequency varies according to type of water and changes during production process.
                              Hydrogen gas is 250% more powerful than gasoline. There is 2.5 million barrels of oil energy in 1 gallon of water. Condensed water is even better for HHO production. High voltage tends to ionize the atoms of the water molecules, therefore producing free electricity in the process (radiant energy, atmospheric, static electricity), which can then be sent back to produce more gas. Columb's Law, 1volt deflection in electronic circuit is equivilent to 1amp energy, simply means that if we can capture 100volts, we can capture 10kw electrical energy. To be able to keep continue extracting energy from water, we must keep it from returning to stable state. Further destabliize the the water moleule by subjecting the HHO gas to high voltage or lazer energy, which then causes implosion which is tremendous energy, releasing the final atomic energy of water. This totally disintegrates/consumes both the oxygen and hydrogen atoms. To adjust, control, and regulate combusion or burn rate, he combines exaust gases with HHO. He also created a quenching device, safety device, to prevent spark-back, fire/explosion, by passing the gas through special tubing along with non combusion gases in order to keep everything safe.
                              In electric motorized generators, there is a need to be able to produce large amounts of electricity using very little fuel. Huge electric motors have always been required to battle the opposing magnetic poles. To eliminate this rotor problem, opposing magnets, Meyers used magnetized gas inside of a ringed or rectanglar tubular structure, which has several coils wrapped around it in 3 or 4 positions. The magnetized gas requires very little energy, and eliminates the back EMF. He uses one of the coils with oscillation to circulate the magnetic gas, to generate electricity in the other coils. He then added the fuel cell HV (ionized laser energy) to the magnetic gas structure in pulses to increase the magnetic field size and and strentgth (overunity). The lazer energy is moving at the speed of light, therefore adding the lazer creates massive generator with very little mass, fuel, or size. Pulsing the lazer energy through the device eliminates the back emf interference. To create the magnetic gases, he runs the same high voltage lazer energy through argon and iron gases in order to liberate argon's electrons, which then cause it to link up with iron gas, to form a gaseous magnetic field, magnetic flux..
                              • Guys for those converting a Briggs & Stratton 4-Cycle Engine, i have the CD rom and can send some links, drop me a mail.
                                ashtweth@gmail.com
                                Briggs & Stratton 4-Cycle Engine Repair/Service Manuel CD
                                This is a Service / Repair Manual for Briggs & Stratton 4-Cycle Engine Repair. Interactive software covers all models from 1981-2006 (4-Cycle Engines). This complete manual will help your repair or troubleshoot every aspect of engine repair. A must have for any Briggs & Stratton owner.
                                Manual Covers:
                                General Information
                                GovernorsS
                                tarting & Charging Systems
                                CarburetionLubrication
                                CrankshaftPistons
                                Cylinders & Bearings
                                Engine Diassembly
                                Engine Assembly
                                IgnitionPLUS MORE..
                                Engines Covered:
                                V-Twin
                                V-Twin Vanguard
                                OHV
                                Single Cylinder
                                L-Head
                                Intc OHV
                                180 Degree Opposed Twin Cylinder
                                LANGUAGE: English
                                COMPATIBLE: Windows
                                FIND IT...PRINT IT...USE IT...then Trash it.
                                Tons of pictures and diagrams at your fingertips!!
                                All pages are printable, so run off what you need.
                                Save Money $$ By doing your own repairs!
                                These manuals make it easy for any skill level WITH THESE VERY EASY TO FOLLOW, STEP-BY-STEP INSTRUCTIONS!
