Water Sparkplug
    Here is the post with the patents zip link:
    http://www.energeticforum.com/27633-post749.html
    "Also make note of how the windings on the ignition coil is less. " That is also in the Suckewer patent(s). Many of these plasma ignition patents have modified ignition coils, something I'm not sure if anyone has delved into.
    ASH - Maybe try
    wear
    gap
    growth
    damage
    Thanks Warren and Aaron.Adding them to your docs. Also guys we are on day 3 of Rev's plug circuit running with the booster, allot of power and no hic ups, average of two 30 minute trips a day. Its funny to see us take off in second gear and then straight to 4th
    • Rev's circuit
      Hi Ash,
      Is Rev's circuit the one with the light bulb feeding the bridge rectifier?
      Greg
      • Originally posted by gmeast View Post
        Hi Ash,
        Greg
        Greg,
        You are correct. Here is a copy from the panacea pdf document.
        LapperL
        • Hi Greg, lapperl and all
          So far this circuit has held up well after 3 days, we just need one fill up to see MPG benefits, it drew slightly less with 50uf. (6-8amps DC peak 13.8 volts). We have 20 amps from the booster already so we didn't want to go over 30 amps on the alternator as it might take away the benefits.
          It makes sense to us to start with the spark plug, Kupra gets 40% alone with the energy from the car ignition system! Work that out!
          • to Ash
            How about radio and other electronic in Your vehicle? Is there noise in Your radio stations? How about music player?
            Thanks.
            • Hi all. I have made numerous tests over the weekend and used up about 20 liters of gasoline in these tests. So far my genset is not working properly and I can't get a stable data, but some things I observed are obvious and interesting. I used a vexus circuit to boost the spark. I used 100uF caps for the voltage doubler (about 600v) a 75w light bulb as a resistor between caps and 10uF pulse caps as the CDI cap. According to my wall plug meter (kinda like kill-a-watt), it consumed 170w of power. It is strange, shouldn't the light bulb limit the power going in the circuit? Anyway, that is TOO MUCH power (too big capacity) for the plug, because here's what happens:
              I had some problems with the genset, the carburetor or something else was not working fine and suddenly it started to consume more fuel no matter if I used stock ignition and timings or custom ignition. Maybe this was due to a bad fuel. Bust as soon as I connected the water spark at this high power, the fuel consumption went down more and more after each test. After 5-6 tests and about 3 liters or consumed fuel, the generator consumed about 41% less gasoline than in the first test. Then I removed the vexus circuit to see how it would now work on an ordinary spark. It worked much better and also about 30% better that in the first test. So seems that the water spark kinda cleaned the engine somehow and made the engine work better. Then I attached the selfmade water injector and the engine started to run a bit more efficient than with water spark alone and the power consumption went down from 170w to 120w only.
              Will test more
              • Hi All,
                I have also made a test (crazy test) according to my last issue (adding NaOH solution to the plasma booster engine). I used 200 ml water and one tea spoon NaOH as the solution. I knew that NaOH is very corrosive, but I need to know the effect on a GEET-Plasma Booster Engine. May be, this is the only way to know what will happen if we add NaOH solution to the spark?
                So, I run the genset on GEET + Plasma Booster with gasoline supplied from a bubbler and suck to the reactor thru air mixed valve for the first test. NaOH solution stored from the carburetor (plastic fuel tank) in closed valve position. Supply valve NaOH opened gradually to the reactor and engine while checking the effect.
                I got good respond till valve 25% open, but when valve position reach near 50% open (high rate NaOH solution flow into the engine), the engine RPM goes down. I tried to keep around 25-30% open (moderate NaOH flow rate) for keep table running. I got the closest diode string broken off due to high temperature that never before when I run the engine in GEET + Plasma without NaOH solution. I thought this give information that NaOH make a Hot Spark and high RPM with very low resistant between the spark gap make just like short circuit cause the melting soldering.
                After that I drain the NaOH solution from all the lines and reservoir and run the engine on 100% gasoline to flash remaining NaOH from the engine.
                Revizal.
                • Hi all.
                  I made some plug wear tests. I tried to limit the current by using a smaller wattage light bulb. I replaced the 75w bulb with a 40w bulb, but it burned out. Then I tried to replace the 75w (50 Ohm) bulb with a 1k power resistor. But this also did not help, the power consumption stayed the same. Then I made the CDI cap size smaller - from 10uF to 4uF. This decreased the power consumption from 170w to 100w. Then I decreased the voltage doubler caps from 200uF to 100uF, this had no effect on the current consumption. So it seems that the only way to decrease the power consumption of the circuit is decreasing the CDI cap value. Now I am using just 2uF CDI cap and this setup consumes just 30w from the wall plug, but the effect appeared to be just as intense, maybe little less. With the 170w power consumption, the spark plug got over 100 degree hot and after just 30 minutes of firing at 50Hz, there already was signs of wear. Now I will try the same test with just 30w power consumption. Then I will try a voltage tripler and quadrupler and decrease the CDI cap value even more.
                  • Bulb effect comparation
                    All,
                    I've completed a test using 25 watt, 60 watt, and 100 watt bulb as resistor to see the effect on plasma booster. The higher the bulb's power the louder the effect and the bigger plasma result. Here is the video link:
                    YouTube - Plasma Bulb Comparation Effect on Motorcycle
                    I hope this make a clear information about requirement of a restriction.
                    Revizal.
                    • gotoluc, are you still here?
                      I have a question. Remember those tests you made of two different voltages on the primary cap, where the energy in joles was the same in both tests but the test with higher voltage and lower capacity showed a bigger effect? What circuit were you using? The basic one where there is only one primary cap that is dumped into ignition coil and the cap positiveterminal is connected to the HV output via a diode string? Or was ir a circuit with a separate booster side? Because I have a suspicion that there is a big difference in both circuits. Because I can't see almost any improvement in the plasma if I double the voltage on the booster side keeping the same capacity. The plasma seems the same no matter if you use 300v or 1000v on the booster side. If you used the basic circuit for your testsm then this should be investigated because so far it seems that the booster circuit needs more capacity (thus more amps and faster electrode wear) to get stronger effect, but the original circuit seems all about the voltage and the higher the voltage.
                      Jetijs
                      • Originally posted by revizal View Post
                        All,
                        Revizal.
                        Of course the higher wattage bulbs will give more effect, but this is not because they are letting more current to the smaller cap, the smaller CDI cap is fully charged even with 20watt bulb, but if you use bigger bulbs, you decrease the resistance and kinda let the storage cap partially act like a CDI cap along with the original CDI cap. And as you increase the bulb wattage, the storage caps get more and more discharged along with the CDI cap on each spark.
                        Thanks for the video
                        good luck
                        • soon it will arc
                          good luck
                          Hi J,
                          ... and eventually, too high a bulb power it will just arc and melt the plug. Another thing I have captured on my scope is the resonance resulting from using NO storage cap and running at a frequency synchronous to the inverter frequency. Here you have random places where the ignition spark happens at or near the crossing of the inverter AC. Here you get a plasma misfire (no plasma). The only way around this is to operate the inverter (like I can operate my power oscillator) at a multiple of an RC time constant ... preferable about 3 - 5 x sparking frequency ... 200 - 500 CPS (4-cyl engine 6000 RPM). This has worked well with both versions of VexUs ... storage cap and NO storage cap.
                          Peace,
                          Greg
                          • What would these plasma spark plugs do underwater?
                            • I'm still here, only by God's grace...........
                              Hey guys,
                              I had a BAD mishap Saturday afternoon here in the shop. I have been moving into a new house for the last couple weeks. It cut sharply into my sleep time, so I've been very tired lately. Only got a few hours sleep Friday night, thus made an almost fatal mistake on the bench. My VexUs circuit charges to 450VDC. By not being as careful as I should have been, I accidentally left the circuit live while hooking up a diode. I then became the solid path to ground and the circuit proceeded to light me up, HARD. Today is day three, and I can finally raise my left arm over my head again, painfully, but at least it works again. When I got loose from the circuit, it threw me about 6 or 8 feet backward so hard I put three dents in the side of the Suburban when I hit it. I fought hard for a couple minutes to stay conscious because I was scared that if I passed out I might not wake back up. I have ALWAYS had plenty of respect for electricity, that's not the issue, I guess that's why it's called an ACCIDENT right? I now have a re-newed outlook on life in general. Guys, PLEASE be SUPER careful with these HV circuits, I will take extra time from now on to ensure safety at a heightened level, that's for sure. I'll be fine in a few days, I've always had quick recovery, since I was little. I will continue testing, at a little slower pace maybe.
                              Back to the Suburban, I am working on hooking this thing up a new way, think I was getting interference in the engine bay. I am implementing quad shielding and installing the diodes within two inches of the plug ends. I'll see soon if it works like I hope. Well, back to hooking up wires, with NO voltage present, of course! Later......................................Mike
                              IF IT DOESN'T EXIST, CREATE IT!!!
                              • BTW,
                                I just completed extensive tests on the PULSTAR spark plugs. I tested in open air, as well as under 125 psi pressure in my chamber. I tested with normal ignition circuit and also with plasma circuit. The internal resistor in their plug does NOT allow the plasma event to take place.
                                I must say....................WHAT A JOKE!!!! these plugs are. I'm sure everyone has seen the CGI video depiction online of what these plugs are supposed to deliver as a spark increase over a factory plug. (no wonder they don't offer actual video footage of their spark!)
                                In open air on the bench, there was NO DIFFERENCE in spark than the factory Champion plug I had it firing next to. Under pressure at 125 psi in the chamber, the Pulstar spark was a little better than the factory Champion plug. And I do mean "ONLY A LITTLE". It was slightly brighter, therefore more visible in the chamber. They claim up to 10% increase across the board using their plugs. Looking at their spark VS. our plasma, if they can get 10% with that.........we should get 1000% with ours!!!
                                At $25 a pop, my personal opinion is that it's nothing more than a well advertised case of fraud! Quite franctly, I just don't see it. Anyway, there's my 2 cents worth on the subject.....................................Mike
