Charles Lindbergh
We can maybe move this to one of the firestorm threads but Krupa said in the interview that when the fuel is leaned to 30:1, at that point, it transmutes with his ignition/plug system from a carbon based fuel to a hydrogen based fuel.
I have a friend here that saw one variation I was working on several months ago. He explained it to his friend who is also here...a world record land speed record holder and is like a Tesla with race car engines.
This person told my friend a story about Charles Lindbergh and lean running engines - I found this same story online:
"Two missions later, on 3 July, the group covered sixteen heavies on a strike against Jefman Island. Lindbergh led Hades Squadron's White Flight as they wove back and forth above the lumbering B-25s. After the attack the Lightnings went barge hunting.
First one, then two pilots reported dwindling fuel and broke off for home. MacDonald ordered the squadron back but because Lindbergh had nursed his fuel, he asked for and received permission to continue the hunt with his wingman. After a few more strafing runs, Lindbergh noticed the other Lightning circling overhead.
Nervously the pilot told Lindbergh that he had only 175 gallons of fuel left. The civilian told him to reduce engine rpms, lean out his fuel mixture, and throttle back. When they landed, the 431st driver had seventy gallons left, Lindbergh had 260. They had started the mission with equal amounts of gas.
Lindbergh talked with MacDonald. The colonel then asked the group's pilots to assemble at the recreation hall that evening. The hall was that in name only, packed dirt floors staring up at a palm thatched roof, one ping pong table and some decks of cards completing the decor. Under the glare of unshaded bulbs, MacDonald got down to business. "Mr. Lindbergh" wanted to explain how to gain more range from the P-38s.
In a pleasant manner Lindbergh explained cruise control techniques he had worked out for the Lightnings: reduce the standard 2,200 rpm to 1,600, set fuel mixtures to "auto-lean," and slightly increase manifold pressures. This, Lindbergh predicted, would stretch the Lightning's radius by 400 hundred miles, a nine-hour flight. When he concluded his talk half an hour later, the room was silent.
The men mulled over several thoughts in the wake of their guest's presentation. The notion of a nine-hour flight literally did not sit well with them, "bum-busters" thought some. Seven hours in a cramped Lightning cockpit, sitting on a parachute, an emergency raft, and an oar was bad, nine hours was inconceivable.
They were right. Later, on 14 October 1944, a 432nd pilot celebrated his twenty-fourth birthday with an eight-hour escort to Balikpapan, Borneo. On touching down, he was so cramped his crew chief had to climb up and help him get out of the cockpit.
The group’s chief concern surfaced quickly, that such procedures would foul sparkplugs and scorch cylinders. Lindbergh methodically gave the answer. The Lightning's technical manual provided all the figures necessary to prove his point; they had been there all along. Nonetheless the 475th remained skeptical. A single factor scotched their reticence.
During their brief encounter, MacDonald had come to respect Lindbergh. Both men pushed hard and had achieved. Both were perfectionists never leaving things half done. And both had inquisitive minds. John Loisel, commanding officer the 432nd, remembered the two men talking for long periods over a multitude of topics beyond aviation.
If, as MacDonald had informed his pilots, better aircraft performance meant a shorter war, then increasing the Lightning's range was worth investigating. Lindbergh provided the idea, but it was MacDonald's endorsement, backed by the enormous respect accorded him by the group, that saw the experiment to fruition.
The next day, the Fourth of July, Lindbergh accompanied the 433rd on a six-hour, forty-minute flight led by Captain "Parky" Parkansky. Upon landing, the lowest fuel level recorded was 160 gallons. In his journal entry Lindbergh felt ". . . that the talk last night was worthwhile. " The 475th had lengthened its stride."
If Lindbergh showed that increased manifold pressure was necessary for this to work in those p38 engines, I wonder if this would be the same as using a turbo or supercharger? They weren't dealing with these plasma ignitions but but his project is about that and it has been shown that under compression, the effect is even bigger. Anyway, just an interesting story I thought.
I found other references that the engines did NOT get hot nor was there damage but the plugs 'could' have shorter life. I thought I read that before when I was searching for that story.
