Water Sparkplug
  • Suckewer | Knite.com
    Welcome to Knite, Inc.
    Looks like they removed all references to their patent #'s, etc... All the Suckewer plasma ignition patents are what Knite's ignition systems are based on.
    • spark duration
      Originally posted by Kinetix View Post
      Hi everybody.
      If the plasma spark is added to a stock transistorized ignition system, I would be very interrested if the plasma spark alters in any way the normal spark on wich it is added.
      Does the duration gets shorted? I am talking about the triggering spark, not about the plasma one. The answer is more easily to find for those who have an osciloscope.
      Thank you.
      Hi Kinetix,
      I have many traces of the VexUs discharge cycle. I am trying to figure out a way to capture a regular spark's discharge duration. It might be useful to compare different capacitor value substituted in VexUs circuit and then look for a trend ... delta durations ... so to speak.
      What thinks ye?
      Greg
      • cap discharging faster
        Originally posted by smw1998a View Post
        There was a post aimed at me about spark duration. (I have been inactive for several months) The spark duration of an inductive ignition coil is around 120uS to 140uS (micro seconds). This is true whether you inductively charge the coil as designed with points and condenser or in my circuit dumping 300v across the primary from a 4uf capacitor (without the HV diode). I’m not sure, but I think modern CDI is around 60uS because the coils are constructed differently.
        Anyway, the addition of the HV diode in my circuit reduced the spark duration from 140uS to 10uS. Not because of the plasma in the discharge, but because the energy stored in the capacitor discharging across the primary winding went short circuit via the HV diode the instant the arc formed. Thus, creating the plasma effect and instantly robbing the primary winding of all power and terminating the arc.
        Lee,
        Your finding that the diode effect here making the cap discharge quicker is what I believe is happening exactly in the Gray tube. The HV source discharges faster because of the slamming into a diode of lower voltage potential and having it shut off. It is like there is a vacuum created on the line that sucks the potential from the HV source quicker.
        Anyway, when I have time to do it, I intend to prove you right on the Gray Tube application as well.
        This is the thread that I have this at:
        http://www.energeticforum.com/renewa...plication.html
        • Memories
          Way back in th early '80s, I played with the CDI circuits of that time in my country of origin (far east): ~300VDC, .5uF capacitor, and SCR. Some cars showed improvement in acceleration, but I was not able to gather mileage improvement. However, most engines don't like it, you can feel it mis-firing at certain rpms and mileage became worse. Increasing the duration by increasing the capacitance to 1.5 or even 2 uF eliminated the misfires on most car models. The higher capacitance required the inverter to be more powerful. Still six cylinders was a problem. My conclusion then was that the improvement in acceleration is due to the faster leading edge of the voltage generating the spark with the CDI than with the kettering system, but the duration is shorter causing misfires on some engines. And that was that.
          During that time also, I vaguely remember a British company that sells a unit that combines both CDI and transistorized ignition in one package. the CDI generates the fast leading edge and the transistorized section extends the duration. I wish I still have that info.
          And that is all I can remember. End of story.
          • water sparkplug videos
            These are just the old original vids I posted and put them up on youtube just for archive purposes:
            YouTube - Water Sparkplug Circuit Verification
            YouTube - Water Sparkplug Isolated Capacitor
            YouTube - Water Sparkplug Test on Lawnmower
            You can read the full descriptions on them for details. These might be good for any beginners here.
            • GEET up and running
              GEET is up and running, adding hydroxy and the plasma spark plug to it
              at a later date. We will also be doing reactor rod extraction tests
              with it. I expect to tipple the fuel economy, then we will be moving
              onto a carby auto with the same hydroxy /plasma experiments. Its
              already ready running on 2/3's water and petrol.
              ImageShack - Image Hosting :: geethr3.png
              Full rep details here
              Panacea University
              Paul Pantone's GEET technology (PDF) - updated December 17 2008
              Fuel reforming method for fuel saving and reduction of pollution.
              Energy saving & pollution cutting applications include: cars,
              tractors, trucks, generators, boats, helicopters, any Internal
              Combustion Engine application.
              Panacea-BOCAF reference page.
              Ash
              • Good work Ash,
                Any videos?
                • Thanks Chris, am anxious to try the hydroxy and plasma spark on it, especially with Gregs new invert. We will do a video of cause my friend , ATM, our timing chain went on the car and the GEET is in the back , being so close to Christmas we wont get it back for another week
                  This is going to be a dress rehearsal for a GEET/Hydroxy plasma spark auto..
                  will upload a vid as soon as we get the car back. Dam timing chain
                  • patent
                    Hi Aaron
                    From their website the say that there product is based on the princeton univ patents. check this out to see if it gels into what you are trying to achieve.
                    Patent 5,704,321
                    Link to United States Patent: 5704321
                    • plasma patents
                      Thanks Doc,
                      I posted this here in the past:
                      http://www.esmhome.org/library/water...ionpatents.zip
                      It has all the Suckewer patents, NASA's and others.
                      The Suckewer patents got around plug wear by doing multiple discharges per cycle...dividing large blasts between multiple pulses.
                      Like MSD (multiple spark discharge) but I guess it would literally be
                      MPD (multiple plasma discharge)
                      That is in their patent to cover the concept but isn't necessarily what they're doing with Knite.com
                      • Plasma Oscilator Based worked on SUV
                        Originally posted by revizal View Post
                        Hi Everyone,
                        I just tested above Oscilator on my motorbike (Yamaha Mio 113 cc). It worked good both supply 12 Volt DC from an adaptor and directly from bike's battery. No heat found on transformer anymore but little warm on 2N3055 transistors (still not a problem).
                        This below is the video link posted on youtube.
                        YouTube - Plasma Oscilator works on motorbike
                        Rev.
                        All,
                        Today I tried to connect above oscilator-inverter to get plasma effect on my SUV. Here below is the video:
                        YouTube - Plasma Booster w/ Oscilator inverter on SUV-1
                        I used it together with fuel vaporizer and homemade kiker wires. Basically it worked OK with some concern. I thought my diodes string got some cross talk between its. When I increase RPM near to 1500, the engine look like unsteady. But when it reach 2000 RPM or more, the engine runs smooth. And bad insulation of my kiker wires make distorsion to car audio.
                        Need more adjustment on it.
                        Rev.
                        • suv
                          All,
                          Rev.
                          Hi Rev,
                          YES! You do nice work. It makes me happy to see we now have a system that can be tested with confidence.
                          Thanks for making the video and sharing.
                          Peace,
                          Greg
                          • Originally posted by gmeast View Post
                            Hi Rev,
                            Peace,
                            Greg
                            Thanks Greg. Actually I don't have enough background in electronics, but I like to learn about and built some curcuits. That's why I was pleased to see your progress on oscilator and try to built one. Yeah, it worked very well. Thanks again for your effort to make it solved.
                            Rev.
                            • Keep up the great work
                              Excellent results over the past month everyone. Keep up the great work and looking forward to bigger and better results in the New Year.
                              PS. In the open source world the general rule of thumb is "don't feed the trolls"...
                              • Is that an "MJ2455" you are using and not the 1n3055?
