Water Sparkplug
  • Originally posted by ashtweth View Post
    Hi Luc, they have done one or two tests on a petrol engine and got 20% but used too much water and are optimizing it ATM, i thought maybe the VAPORIZER they use might work for the spark plug?, seems like a neat unit.
    Ash
    Thanks for the reply Ash
    You're right to think that and goes to prove the results that Greg was getting.
    Thanks for sharing
    Luc
    • Hi Luc
      Okay Rosco and i are looking getting a vaporizer from Ecopra for the aqua pulsa circuit now, another aqua pulsar is on the way to Panacea and Robins NEW plugs will be used with them./ New video is coming re loaded with results and exhaust gas anlysis MPG.The Water spark plug is coming back with a vengeance .
      • Great mate
        Thanks to you and Rosco's for continuing the research
        Luc
        • AND
          Thanks to our LUC for creating a monster
          • Update
            I've managed to source a set of resistorless Brisk Premium LGS plugs for my testing too.
            This will give me an opportunity to compare different plugs, namely FireStorm and Brisk Premium LGS, with the Crane Cams HI6 and PS91 coil, as well as the Aquapulser RPG 4700 plasma gen.
            My Aquapulser unit should be arriving from the USA sometime in the next fortnight. Hopefully the LGS plugs arrive at the same time.
            Ash is right, I'd like to attempt to use parts of the ECOPRA system to deliver a fine water mist, as my current water/methanol injection isn't adequate.
            • Great part about the ECOPRA micro bubbler is that it can make A LOT of mist from the engines exhaust just a matter of regulating it and getting it into the FINE mist.
              • How to Mix High Voltage and High Current
                • Mixing High Voltage and Low Current
                  Little explanation on diagram
                  http://www.energeticforum.com/renewa...plication.html
                  • Originally posted by Shane Jackson View Post
                    As promised here is a short video with crappy audio.
                    YouTube - Vexus Plasma Spark.
                    If you are wondering.... Lysol. I think part of the problem is I did not have the plug grounded very well. All my vice grips are in my spray foam truck.... I may do another video when my new plugs arrive.
                    Are you selling a complete kit or assembled unit?
                    If I buy thr PCB, will it include a parts list and soldering instructions?
                    • Rpg 4700
                      What ever happened to the RPG 4700 thing?
                      • Update
                        Apologies for the lengthy delay in posting up info on the RPG 4700.
                        This link shows a 17 second video of what it yields thus far.
                        YouTube - Aquapulser RPG 4700 with Crane Cams HI6 and PS91 coil, using thick strap Firestorm plug replication.
                        Next step will see this plasma tested with a modified Kiker Wire, as well as resistorless Brisk LGS plugs which have been kindly made available by Brisk for these tests.
                        Steps have also been taken to fabricate a special spark plug which will hopefully take full advantage of this plasma.
                        • I should add...
                          I've encountered a "field" issue when the RPG wires are all attached, so I'm trying to overcome that, prior to moving forward.
                          This "field" is affecting cylinder 4, and only becomes apparent when I connect that particular RPG to diode wire.
                          I've tried everything I can think of to overcome this problem, but it has me beaten thus far.
                          I may have to reposition all of the diodes, which may in turn alter the way this "field" is interacting with the lead array.
                          It doesn't matter if the RPG is switched on or off, the problem with the lead at cyl 4 refuses to go away until I remove that diode to RPG wire, whereupon, that cyl fires again as though nothing is wrong.
                          I've added extra shielding to all relative leads, no joy, I've also added a Faraday Cage to the errant RPG to diode wire, still no good.
                          It appears that the lead to the affected cyl is being influenced by a "field", which is perhaps being emitted from the collective array, so adding Faraday Cages to the other RPG to diode wires is another thing I'm looking at.
                          I can report a slight increase in engine vacuum, as well as a slight increase in engine idle speed thus far. Responsiveness has also been enhanced.
                          I can't give much more than this at this point as I'm only getting plasma to 5 cylinders, and I really need to get it working on all 6 before I can say more.
                          • Original Vexus circuit
                            Remember these? It's all for sale ... $800.00
                            The circuit that was in the Bug and all the plugs ... Beryllium Copper ones and the Nickel ones too plus the lone silver one too.
                            YouTube - 03
                            YouTube - 05
                            Greg
                            • Hi Greg nice to see your still alive man. Got our RPG here to fire up soon.
                              guys check this out
                              OKADAPROJECTS | PRODUCTS | PLASMA BOOSTER | PLASMA DIRECT | PLASMA SPARK | PLASMA GROUND | PLASMA LIFT | PLASMA QUAD PAC
                              Sorry if already been posted.
                              Ash
                              • guys i want to tell you all about the stanley meyer technology including high voltage high recirculating current and ultra low voltage electrolisys
                                here http://www.energeticforum.com/renewa...eyer-true.html
