Technical drawings needed for our hydroxy write up
  • Technical drawings needed for our hydroxy write up
    Guys, your dream hydroxy 101 (17mb!) with every do/ dont, design and faculty information is ready. Problem is we need some drawings for various designs. Can any body draw the following cell with plate measurements?
    I dont think we need CAD , but just some thing that can show the cylindrical cylinder specs, can any one take a look?
    BTW, this is the best booster
    RapidShare: Easy Filehosting
    Please help guys if you can, or you have to put up with me begging
    Hi Ash,
    I have had some graphic design experience and I have the software/hardware to draw up some simple illustrations in Freehand +Photoshop. Files can be optimised for internet viewing or used as a 1 to 1 scale vector based artwork/schematics. Ive attached a simple one I did for my window motor. I got some laser cutting from one of the templates.
    I cant have it all done super fast, but I am happy to draw it up for you when I get time for free. Show me some pics or give me some specs and Ill have a stab at it if you like
      Ill do ur drawing for u with Solid Works
      Hi
      Ill be happy to do your drawings for you anytime
      I use Solid Works 2008 and 3ds max 2008 and I can make you some quality technical drawings
        Ash, Awesome....Glad to see things coming to fruition! This gives me an idea for a thread. A "Share Your Expertise" Topic so we can help each other out in our quests!
        I like the design, the only thing I would add is a note is on the Relay Wiring. The trigger input just says "Ignition On" I would add a Note to make sure it is tapped into a component that only cuts on with the "Ignition On and Not Accessory" like the Fuel Pump fuse.
        But anyways, Great Work!
        RedMeanie
        (psst...Don't Tell Anyone, But I'm Really Not Mean!)
          Thats a good idea Red Meanie!
          We all have our day jobs and little hobbies, you should start that thread up!
          Kinda like a little get to know your peers/talent expo.
          Also may I suggest a more universal document format when its finished? Like PDF maybe?
            Hi Ren, LEE, paradox et all
            Thanks allot Guys , very impressive skills there. And not a bad idea too
            Wait until you see the final document , it has all of ours and others research. Okay now i think Lee can help on the measurements? they are all contained in the document i uploaded. Wouters is basically a clyndrical cell with the spacing and cm of the tubes listed in the document.
            Lee probably knows how to weed them out better then i do
            But if any one cannot understand it please let me know. Thanks lee ill update the doc.
            Perhaps Ren/ Paradox can take instruction form lee on the cylindrical one uploaded?
              .doc file
              Hey ash
              Could you please email that .doc file to me, rapidshare never works for me...
                sure man, can you send me your email?
                ashtweth@gmail.com
                also i found this from the doc
                "To summarize, the unit is a 6 cell unit using 7 tubes (diameters 4" / 3.5" / 3" / 2.5" / 2" / 1.5" / 1") The outer tube is connected to negative and the centre tube is connected to positive. The centre 1" tube is connected to a 8mm (5/16") stainless steel threaded rod with a 1 inch s/steel washer so that the rod provide an easy and secure outside connection to positive.
                The outer tube will be slightly longer than the inner tubes which are all the same length""
                  Also Ren do you wanna drop me a mail too pweez? I have another easy tubular one, paradox could do one and maybe you could look at the second?
                    Hey Ash, Ill send you a pm with my email.
                    I have a mac Dude and I cant open the doc file with pics yet. I drew up a couple of quick pics, are these the shape its reffering to? I wasnt certain which one.
                      Ok i PMd my email to you, Ash
                        Thanx Ren and Alex checking now
                          Just let me know If I can help.....I have read over it and it seems simple. I just dont like the water level problem that seem inevitable with this set up.
                          RedMeanie
                          • #14
                            Why are we staying small?
                            Just curious...all the Meyer cell designs I have seen have all been pretty much the same. Has anyone considered putting ....say 40 tubes in trunk of a car and running a pressure cutoff switch with very little room for expanding air, to make it very much on demand?
                            • #15
                              Capt Crunch. This guy makes bigger Meyers stuff.
                              hydrogen shop water fuel cell
                              This is a hydroxy booster not a Meyers cell
