HHO and volcanoes....
  • HHO and volcanoes....
    Hi, I have an idea about HHO and the inner earth core.
    Let us assume the inner core is made up of a gaseous substance(H and O among others) near the crust. We know 95% ofthe magnetic field arises from near the surface. Rotation speed is obviously at maximum near the earth crust.
    This means if you rotate H and O very quickly near the surface you could get HHO" when the gas pressure drops from the rotation speed, HHO is assumed to be magnetic.. If we assume a lot of neutrinos pass through the earth and they encounter quickly rotating HHO an electron could be formed(Konstantin Meyl book "Scalar waves") and ignite HHO - BOOM. If we weld HHO on iron or any other metal the result is a frightening temperature with explosive consequences. Also the HHO gas turns magnetic energy into electric energy at contact with the material, thus the intense heat.
    So maybe the deep drillers are not that stupid after all when they report colder and colder temperatures the deeper they drill.
    That means if we make HHO(ie Stan Meyer method) and rotate it quickly we could sit on an unlimited resource of electricity(rotating magnetic field), heat, steam and explosive power.
    Maybe I am stupid but this idea is simple and clean and gives me a much better explanation of the reports from the drillers at work. So everyone should try to master the Meyer circuit which is not too hard, then try to rotate the gas to make power.
    What about Lightening
    It is the general belief that the thunder from Lightening is a sonic boom or shock wave.
    How would you like to entertain the thought that a high energy discharge is splitting the water contained in Clouds into Hyrdrogen and Oxygen and igniting it causing the Thunder we hear?
    controversial ...... of course!
    professor
