Lynnferd Grant HHO Breakthrough
  • #16
    carbon arcing - Thomas Campbell
    Here is one post from Thomas online somewhere:
    carbon arcing is the solution guys to Hydrogen !!!!!
    water has positive Ion's and Negative Ion's so if you use negative charge electrons even when we do not see what is going on in water with the use of the electrons will deionized the positive Ion's out of water which in turn of VAC that it pulses then backs up into a metal body getting a capacitor coupling charged up then you have to send that charge with a switch causing a carbon arcing to accure through the whole mass of Distilled water which breaks from top to bottom single atoms of hydrogen from top to bottom but the single atoms of hydrogen at top then goes into air because of its gaseous weight of it which means it can not bond back into the water in an open fuel cell !!!
    RPX & MWO http://vril.io
    • #17
      Lynnferd's Black Matter
      Thank you so much for this great information. I wanted to inject a thought or idea. What if the "black matter" that Lynnferd refers to is actually the glue that holds everything in the universe together and creates black holes. Please check out Nassim Haramein and The Schwarzschild Proton. Also research Nassim's info regarding Sacred Geometry & Unified Fields. I grew up believing that all of outerspace was a vacuum void of matter, when in fact outer space is completely full. I know this sounds nuts but study Nassim's work and check it out. It is a real eye opener.
