FOR H2OPOWER:
You wrote:
"The water fuel injectors create micro-mini capacitors out of water by passing the atomized water mist through a high voltage zone. After careful study of the water fuel injector I found out that the inside electrode is surrounded by a column of air at 125 psi so the water mist never comes into direct contact with the center electrode.
How you get voltage to perform work is by physically changing the area, thus changing the charge surface density. This is very important information to know when it comes to understanding how Stanley Meyer got the some of the water mist to break down into hydrogen and oxygen. As the highly charged water mist mixes with the unstable oxygen atoms and recirculated exhaust gases it evaporates, thus changing the surface area allowing voltage to perform work on the water molecule. In a way he set a condition that caused the water molecules to short circuit. "
My question is.. Air to high pressure create an dieletric from positive and negative electrodes, the water mist 90°C or more is pass from negative electrode and is it charge negatively water mist as micro-capacitor. But sorry.. air is precharged into GP and are cut electrons, when it pass trougth central positive electrode it split every electrons for corona effect or have effect the dielectric air??? From Meyer patent design I don' have found any air pressure pump but only water pump. Can you indicate me in how design is present that?? Thanks
