How N2O is made:
So if what was said is true then there is a whole new way to make N2O and nobel prize should be given right away. Science shows that the two atoms don't come together like that, what will be formed first is NO at around 750-950 degrees C then that can break down into N2O. But if you get the temps up the high it will be 250 C past hydrogens flash point and any hydrogen in the system will pop off no waiting for any controled spark from any source.
My main point is Nitrogen and Oxygen don't seem to come together in this fassion but Hydrogen and Oxygen does. But if it does then come together like this a full peir review paper should be made of the reaction so other scientist can duplicate the reaction. On one hand you have a hydrogen + oxygen reaction and the other you have nitrogen + oxygen reaction and as far as I can tell the later can't combine like that. The hydrogen reaction one of the oxygen atoms has been striped of electrons and is highly reactive far more so than the O2 floating around in the system.
In an internal combustion engine you don't want any hot spots when hydrogen is present for anything over 500 degrees C will make hydrogen flash at the point of the hot spot. If your running a diesel then you need to directly inject the hydrogen into the combustion chamber and the rapid compression will reach hydrogens flash point during compression, but it has to also be kept down from hydrogens flash point. If any spot in the intake system reaches hydrogens flashpoint it will set off the reaction so great care must be made to keep the intake system below hydrogens flash point.
h2opower.
From here: Nitrous oxide - Wikipedia, the free encyclopedia
NH4NO3 (s) → 2 H2O (g) + N2O (g)
This reaction occurs between 170 - 240°C, temperatures where ammonium nitrate is a moderately sensitive explosive and a very powerful oxidizer. Above 240 °C the exothermic reaction may accelerate to the point of detonation, so the mixture must be cooled to avoid such a disaster. Superheated steam is used to reach reaction temperature in some turnkey production plants.[4]
Downstream, the hot, corrosive mixture of gases must be cooled to condense the steam, and filtered to remove higher oxides of nitrogen. Ammonium nitrate smoke, as an extremely persistent colloid, will also have to be removed. The cleanup is often done in a train of 3 gas washes; namely base, acid and base again. Any significant amounts of nitric oxide (NO) may not necessarily be absorbed directly by the base (sodium hydroxide) washes.
The nitric oxide impurity is sometimes chelated out with ferrous sulfate, reduced with iron metal, or oxidised and absorbed in base as a higher oxide. The first base wash may (or may not) react out much of the ammonium nitrate smoke, however this reaction generates ammonia gas, which may have to be absorbed in the acid wash.
[edit] Other routes
The direct oxidation of ammonia may someday rival the ammonium nitrate pyrolysis synthesis of nitrous oxide mentioned above. This capital-intensive process, which originates in Japan, uses a manganese dioxide-bismuth oxide catalyst:[5]
2 NH3 + 2 O2 → N2O + 3 H2O
Higher oxides of nitrogen are formed as impurities. In comparison, uncatalyzed ammonia oxidation (i.e. combustion or explosion) goes primarily to N2 and H2O.
Nitrous oxide can be made by heating a solution of sulfamic acid and nitric acid. Many gases are made this way in Bulgaria.[citation needed][6]
HNO3 + NH2SO3H → N2O + H2SO4 + H2O
There is no explosive hazard in this reaction if the mixing rate is controlled. However, as usual, toxic higher oxides of nitrogen form.
Nitrous oxide is produced in large volumes as a by-product in the synthesis of adipic acid; one of the two reactants used in nylon manufacture.[7][8] This might become a major commercial source, but will require the removal of higher oxides of nitrogen and organic impurities. Currently much of the gas is decomposed before release for environmental protection. Greener processes may prevail that substitute hydrogen peroxide for nitric acid oxidation; hence no generation of oxide of nitrogen by-products.
Hydroxylammonium chloride can react with sodium nitrite to produce N2O as well:
NH3OH+Cl− + NaNO2 → N2O + NaCl + 2 H2O
If the nitrite is added to the hydroxylamine solution, the only remaining byproduct is salt water. However, if the hydroxylamine solution is added to the nitrite solution (nitrite is in excess), then toxic higher oxides of nitrogen are also formed.
Manufacture
Nitrous oxide is most commonly prepared by careful heating of ammonium nitrate, which decomposes into nitrous oxide and water vapor.[2] The addition of various phosphates favors formation of a purer gas at slightly lower temperatures. One of the earliest commercial producers was George Poe in Trenton, New Jersey.[3]NH4NO3 (s) → 2 H2O (g) + N2O (g)
[edit] Other routes
h2opower.
