Bingo fuel, is it better than efficient electrolysis?
  • Bingo fuel, is it better than efficient electrolysis?
    Bingo fuel site:
    BingoFuel (Alternative Fuels researches) by Jean-Louis Naudin
    The BingoFuel Reactor v1.0 by JL Naudin
    Other name:
    Aquafuel™, Aqualene™, Magnegas™, TrueFuel™, Carbo-hydrogen™
    I just did experiment with sparking carbon. Not exactly the same, I use copper and carbon, not both carbon like mentioned. And I use radiant oscillator output for power, not normal electricity, the benefit is I do not have to worry about impedance and do not have to worry about electrode stick together which would actually reduce the load of the transistor which run cool.
    Video:
    YouTube - Bingofuel replication with radiant oscillator output
    Experiment detail:
    - electrode are replacing the charged battery
    - VR is set between 200 to 800 ohm
    - carbon positive
    - copper negative
    - 11.5V radiant oscillator input
    - maybe 0.3A input, 1A if secondary coil is loaded with CFL which light up at full brightness if radiant output is not utilized.
    - unknown output voltage, it is enough to light up neon bulb with one wire at secondary high voltage (under 240V).
    - tap water
    The result which is not clearly shown in video, the hydrogen bubble generation at copper negative is clearly better when there is no spark. I think normal electrolysis is much better at generating HHO than bingofuel method.
    Anyone has the same opinion?
