Stan states in the Tech Brief that the Water Fuel Injectors
(tapered resonant cavity/voltage wave guide) split the water molecule, but how?
How can the water molecule be split in an injector (capacitor) which has only 1 wire going to it (one voltage polarity)when Stan states High Voltage of Opposite Polarity is what split’s the water molecule.
How can there be a negative charge when the Injector is threaded into the engine block, thus grounding it?
In the Tech Brief on page 8-3 Stan states:
“Opposite negative Voltage Pulse Train is similarly formed since “Electron Clustering Effect” produces a Negative Electrical Voltage Intensity in equal magnitude to the Positive Electrical Voltage Intensity.”
And, if you look at Andrija Puharich’s water fuel injector patent # 4,394,230 in paragraph 7 you’ll read:
"...the two electrodes undergo states of polarization.....the inner surface of the outer ring electrode (the electrode that is in contact with the fluid) becomes negatively charged"
Both inventors claim the same effect in their Water Fuel Injectors, But what exactly is electron clustering? And how does a negative charge just form?
The answer is known in physics as ELECTROSTATIC INDUCTION!
Electrostatic induction is when one charged object charges another nearby object.
If I have an object which has a positive charge (lack of electrons) and I put it toward another object the positive charge will attract electrons toward it, creating a negative charge (defined as an area with an excess of electrons) (Stan calls it electron clustering) on the surface closest to the positive charged object.
Electrostatic induction - Wikipedia, the free encyclopedia
Electrostatics - Wikipedia, the free encyclopedia
YouTube - electrostatic induction
Now we know that the Water Fuel Injectors have both a positive and negative voltage, and that they split the water molecule in the same way the original WFC did. Using high voltage of opposite polarity while restricting current.
Why the Injectors are Tapered
The purpose of the taper of the injector should be easily understood after reading this.
In page 6-1 (Water Fuel Injector) of the Tech Brief we read:
“At each progressive point of diminishing circumference area voltage amplitude intensity increases”
The reason for the taper in the Injectors, as stated above is to amplify the voltage even further. As the high voltage travels down the tapered surface the area becomes smaller and smaller, causing the charge density (charge/area) to increase.
The Quenching Circuit
In both Stan Meyers and Andrija Puharich’s Injectors we will find something called Quenching.
Quenching refers to a specific distance that will not allow a flame to form or travel through. The quenching distance of hydrogen is anything below .024”.
In the Injectors Meyer and Puharich used the hydrogen quenching distance to prevent damage to the injectors and system, as well as pre-ignition.
Tech Brief page 7-1
"Capacitor should remain relatively small due to the dielectric value of water to obtain maximum thermal explosive energy yield and subsequently establishing quenching circuit to prevent gas ignition inside traveling voltage wave guide"
![](http://i642.photobucket.com/albums/uu141/Hms-776/InjectorDWG1.jpg)
The design above was done after hours of research on Stan Meyers Tech Brief, Patents, Pictures, and from people who have seen them first hand.
The tapered section is a uniform (smooth) taper, the drawing shows it stepped, but that's as best as I could get with the drawing program I have.
The injector tapered section can be expected to have a capacitance range of 1000-5000pF (with the dielectric constant being 20-60) with a length of 4", a large dia of 1/2", and a small dia of 1/16" with a .01 spacing between the plates.
NOTE: The dimensions I mentiond above has not been confirmed yet. I need to figure out what the flow rate will be using the deimensions above, just as with conventional injectors the flow rate and pressure determine HP!
200SX S13 ~ Injector Size Calculation
Please read the following threads for more understanding on Stan Meyers Water Fuel Injectors:
http://www.energeticforum.com/renewa...injectors.html
http://www.energeticforum.com/renewa...resonance.html
Tech Brief page 7-1
