OK. Tutanka., Less than 100 watts. How about less than ten watts? Ordinary household Microwave oven. Utilize the magnetron. Cheap and easy. THE THING IS ALREADY BUILT AND THERE ARE MILLIONS DISCARDED EVERYDAY.
Microwave oven?? No sorry I don't use an magnetron
Sure they do..if u r trying to boil a glass of water sitting on a revolving plate inside a 200mm X 300mm Faraday cage.
But what if our enclosure is only 10mm wide? Like a small steel tube for example?
For Meyer patent yes.. for me that mixture can't burn.. remember that all is based on chemical reactions.. for that I repeat for more times that some components are removed from Meyer patents and some words are changed for protect petrol power in the all world.. but they don't have consider that there are some humans with illuminated minds..
Do you also use a"fuel mixing chamber", to mix your gases/water mist before going into engine combustion chamber?
I CREATE NH3 ON DEMAND AND SEND INSIDE ENGINE, DON'T USE WFC INJECTOR PLUG. MY METHOD OF PRODUCTION IS DIFFERENT FROM MEYER BUT USE IN PART MEYER INDICATION , HOWEVER IN MY PROCESS I USE WATER MIST/AIR MIXING ALSO.. JUST FOR PROVE MY THEORY I HAVE BUILD ALSO WFC INJECTOR PLUG FOR USE ON TURBINE INCLUDING POWER SUPPLY CIRCUIT.. REGARDS
100W
electrolier without electrolyte
Nh3 on demand
mixed with water and air (could give NH4+)
Tutanka,
Does your water get hot?? are you using water vapor? or water fogger?
The chain reaction you meant, is what meyer meant by resonance???
could you just describe the only the chain reaction???
NO! I obtain only NH3 .. I can't describe anything.. sorry.. but you don't have found method for obtain high amount of hydrogen? If is true you can create a lot amount of NH3
You as illuminated could shine some more light here to we all. Common no one is going to steal your idea... You don't need to give us info enough to build something so efficient as yours just give an idea...
We have the hydrogen, ok, but as i said i can't release or jail for me.
Don't let berlusconi or worst the generals strategy team steal you before releasing, because if they do so you will be in the same position as me!
Remember that some people like stan, brown... even died for us to be today here looking for free energy. For them "arab oil corp, nuclear plants owners ..." you and me and whosever might try to release something like this, are only small rocks inside their shoes... But together if many people know and know at least how it work and believe it, there is no way for them to silence us further. Together we can become a big rock inside their shoes and they will not be able to smash us.
I've made a huge mistake witch was to believe a country could want this fight, i'm reporting this to you, in a tentative to show you that you can learn from the others mistakes, and try to don't do the same mistakes too.
just that...
Even If you don't choose to share, i still wish you the best luck, and hope you fell free to believe that you already have a future partner in my country whenever you need.
tutanka could you please tell use if you are pumping the water mist through the reaction tube.
