Originally posted by tutanka
As you can see the Gas Processor will be different in use with your theory as it will have more wavelengths of light in it for ionization of both oxygen and nitrogen. Now the cost of those LEDs in the UV range is very high, and the IR are also not all that cheap. The wavelengths I am going to use are not the best absorbed by oxygen but the 410 nm LEDs have a 450 absorbance into the oxygen atoms as well as the 635 nm and 560 nm and 465 nm wavelengths are around 200 and above in absorbance into the oxygen atoms. So I'm hoping for a cumulative effect as seen in nature when you get sun burned.
Now with the correct pulsing of the LEDs the BEMF will be taking place at the same time the LEDs are pulsed on. So the electrical energy will be coming down as the light energy is being introduced. This is an overlapping of the two energies as spec'd out by the patent. These two forms of energy are different in that light is a higher form of energy than any other form of energy to be used with this patent so getting it at the right wavelengths to be absorbed by the atoms is a key step.
Now since you are going with the WFC I would suggest that you add on another gas processor to the gas that it produces so just like the gas gun you will have the highest energy content being injected into the cylinders for combustion. You must make sure you make the quenching circuits just right for if you get a back blast with the added gas processor on the gases produce by the WFC that could do some harsh damage to all of your hard work as most of it would be blown up if that occurred. Be safe not sorry.
But note you will need the circuit as we all are going to need that, just throwing high voltage at it is not going to work it all has to be done exactly as Meyer did it for us to get the same results. No part can be taken out until it has been tested or mathematically found not to be needed. I have found out mathematically that some things can and should be changed in how some of his systems work especially with the WFC. The positive should be in direct contact with the water and the negative should be coated and not be allowed to be in direct contact with the water. That may sound like a small change but it is really a big change as to how it all really works treating water as a dielectric liquid fully with no Dr. Faraday type electrolysis being given a chance to take place. And that goes for the water fuel injectors too he negative electrode should be coated with glass and the positive in direct contact with the water mist and resulting gases that are created by the process Therine. Taking things down to formula the way I did shed a lot of light on how things really work in the Meyer patents, and that formula is the self-ionization of water for the most part.
Hope this helps aid you in your efforts,
best of luck in getting around the conservation of mass problems I found,
h2opower.
