Originally posted by sebosfato
Nuclear fusion - Wikipedia, the free encyclopedia
Nuclear fusion occurs naturally in stars. Artificial fusion in human enterprises has also been achieved, although it has not yet been completely controlled.
When the fusion reaction is a sustained uncontrolled chain, it can result in a thermonuclear explosion, such as that generated by a hydrogen bomb. Reactions which are not self-sustaining can still release considerable energy, as well as large numbers of neutrons.
Research into controlled fusion, with the aim of producing fusion power for the production of electricity, has been conducted for over 50 years. It has been accompanied by extreme scientific and technological difficulties, but has resulted in progress. At present, break-even (self-sustaining) controlled fusion reactions have not been demonstrated in the few tokamak-type reactors around the world.[2] Workable designs for a reactor which will theoretically deliver ten times more fusion energy than the amount needed to heat up plasma to required temperatures (see ITER) are scheduled to be operational in 2018.
It takes considerable energy to force nuclei to fuse, even those of the lightest element, hydrogen. This is because all nuclei have a positive charge (due to their protons), and as like charges repel, nuclei strongly resist being put too close together. Accelerated to high speeds (that is, heated to thermonuclear temperatures), they can overcome this electromagnetic repulsion and get close enough for the attractive nuclear force to be sufficiently strong to achieve fusion. The fusion of lighter nuclei, which creates a heavier nucleus and a free neutron, generally releases more energy than it takes to force the nuclei together; this is an exothermic process that can produce self-sustaining reactions.
Generally cold, locally hot fusion
Accelerator-based light-ion fusion is a technique using particle accelerators to achieve particle kinetic energies sufficient to induce light-ion fusion reactions. Accelerating light ions is relatively easy, and can be done in an efficient manner – all it takes is a vacuum tube, a pair of electrodes, and a high-voltage transformer; fusion can be observed with as little as 10 kV between electrodes. The key problem with accelerator-based fusion (and with cold targets in general) is that fusion cross sections are many orders of magnitude lower than Coulomb interaction cross sections. Therefore the vast majority of ions ends up expending their energy on bremsstrahlung and ionization of atoms of the target.
Despite periodic reports in the popular press by scientists claiming to have invented "table-top" fusion machines, neutron generators have been around for half a century. The sizes of these devices vary but the smallest instruments are often packaged in sizes smaller than a loaf of bread. These devices do not produce a net power output.
The energy released in most nuclear reactions is much larger than that in chemical reactions, because the binding energy that holds a nucleus together is far greater than the energy that holds electrons to a nucleus. For example, the ionization energy gained by adding an electron to a hydrogen nucleus is 13.6 electron volts—less than one-millionth of the 17 MeV released in the D-T (deuterium-tritium) reaction shown in the diagram to the right. Fusion reactions have an energy density many times greater than nuclear fission; i.e., the reactions produce far greater energies per unit of mass even though individual fission reactions are generally much more energetic than individual fusion ones, which are themselves millions of times more energetic than chemical reactions. Only direct conversion of mass into energy, such as that caused by the collision of matter and antimatter, is more energetic per unit of mass than nuclear fusion.
BTW, the Meyer patent that mention a must 2:1 hydrogen/oxygen ratio made me remember high school chemistry titration experiment. Some chemical reaction will only occur if it has the exact proportion. I remember that in group we add liquid drop by drop on a glass. I remember only some manage to do it, because most are to eager and overshoot chemical balance and fail it. Maybe it should be red and an overshoot would result in yellow.
