Hi Aaron,
I'm sorry to don't be here now to write something related to tutanka technology, but i think that there are too many pages of pure guessing here and i think that faraday is kinda right when he says that there is no science in this.
I know people that ran engines with only hho and it work just fine, no gas into the pistons or this kind of things...
Hydrogen in the atmosphere is about only 0.6 parts per million.
And I would say that thermal energy meyer said is not reduce the burn rate of the hydrogen but is meant to be use the hydrogen avoiding water reformation allowing him to get enormous amounts of energy...
The fact that you reduce the hho speed by having it mixed with air is all you need to get the explosion expansion ... What one might call thermal expansion energy, This happens when hho recombine into water witch do not become vacuum (never) but high temperature steam witch heats up the air around inside the engine rising it's temperature and so the pressure forcing the piston to go down...
I hardly believe that nitrogen has not much to do with any gain ... only the fact that it reduce the speed that hho recombine if its well mixed. I've done some tests and many have done many tests and i watched almost all you can find on internet about.
We know that dissociating events are endothermic and so absorb energy from the environment for the dissociation so if the process is to use the heat loss in the engine to create the NH3 ok but if is to use electrical energy to do it i believe is not the way to go... However what i believe does not matter here...
Facts are NH3 or HHO you still need quite a lot to run an engine...
Here we should talk about science not science fiction.
I don't know if hydrazine killed stan... I still believe he was murdered...
I still believe tutanka have something on his hand, not hydrazine, not NH3, something else.. . I still believe i have something in my hand.
