If splitting nitrogen and having enough electrons stripped from nitrogen,
it seems pretty easy to set up a system to combine that nitrogen ion
with hydrogen so that nh3 can form.
Shamus spelled out that very important clue but everyone seems to
ignore it. To me, that is the mystery and not how to produce NH3.
Yes, that is correct but in all case you need an controlled chain reaction
Well Aaron, since you've thrown it out there, I might as well take a stab at it...
An N2 molecule has 14 electrons between them, 3 of which are shared between the two atoms. The outer valence shells are full; the atoms are happy. Now when you break those guys apart, you still have 14 electrons; seven in each atom with five in the outer valence shell. Now the atomic nitrogen atoms very much want their outer valence shells to be full, and they each have space for three electrons.
Those electrons can come from just about anywhere: A passing electron, or another atom looking to do the electron swapping thing like an atom of hydrogen. If the outer valence shells of the atomic nitrogen fill up with free electrons (what some might call a "natural electron extraction circuit") you end up with an atomic nitrogen ion with a 3e- charge. If the outer valence shells find hydrogen atoms, then covalent bonds are formed and you have a molecule of ammonia. Other combinations are of course possible, depending on energy levels among other things. But that's the basics as far as I understand them.
So which is it then, nitrogen ions or ammonia? I think it's probably both, though the proportions are probably heavily dependent on just what's flying around your reaction vessel.
I see Tut has given a thumbs-up to this statement, but I'm puzzled because I really don't see anything easy or simple here. I can understand the reaction of dissociating the N2 into atoms, and then reacting these atoms with hydrogen to get NH3, but what is the stripping of electrons all about?
Afterall, you can't get NH3 unless all the elements are atoms. A nitrogen atom stripped of it's valence electrons would then no longer have the required electrons for covalent bonding to hydrogen in order to form NH3. Put simply the reaction to NH3 would no longer occur.
If you somehow ionise the nitrogen atom to make it N+, then it would require 4 hydrogen atoms to covalent bond - hence you would not get ammonia, but the NH4+ ammonium ion.
I'm not nay-saying here to spoil the party, I'm simply pointing out the obvious.
edit: changing question...
If you break n2's triple bond, what does it try to attract to itself in that state?
If that atomic nitrogen is in the presence of atomic hydrogen, can nh3 form?
If n2 is split is the atomic nitrogen an ATOM of nitrogen, ION of nitrogen or both
at the same time?
I'm studying molecular and atomic physics in the university, and in the last class i had a discussion on my theory about creating oh oh instead of h2o as exhaust and they think that it is possible if we ionize the oxygen negatively adding to it 1 electron because it would fill one of the 2 holes of the oxygen, allowing only one hydrogen to bound per oxygen atom. Thus combusting the hydrogen with more oxygen than that from electrolysis... Actually i thought that if we could fill both holes we would not allow the reformation of the H20.
However if we think that we are again, charging the oxygen positively lets say leaving it with a deficiency of 1 electron we would have H3O+ formation witch would be more likely to be what meyer said because it would lead to the formation of half the molecules of water used as output. Witch would also relate to a decrease in mass!!! A huge decrease, as oxygen represents the 88% of water weight! This would generate oxygen too! but would really consume the water! than water would evaporate receive sun rays and bound with other oxygen becoming water molecules stable again..
How about this tutanka???
The H3O+ ion getting inside the water become an electrolyte... maybe??
Meyer create ions with steam resonator but I have found another simple solution, in all case you need to create controlled chain reaction using right water and right sequence of process ionization. The theory on nitrogen atomic is correct, that bond simply when found atomic hydrogen atoms. Regards
You mean by right sequence of ionization: to 1° ionize negatively and than positively... ? Imbalance? Have you thought about emitter like lithium cesium or sodium, potassium metal inside vacuum ss cylinder? Meyer told us he used a mix of argon and cesium for something i guess... He said that a hot filament would emit electrons (ions)...
I was thinking that if also the Nitrogen was positively charged it could actually form maybe N2H2 or even NH3 inside the combustion chamber during the explosion.. couldn't it?
Nitrogen have 5 holes that can be filled, right?
Lithium nitride
From Wikipedia, the free encyclopedia
Lithium nitride
Identifiers
CAS number 26134-62-3
PubChem 520242
EC number 247-475-2
ChEBI 30525
InChI
[show]
Properties
Molecular formula Li3N
Molar mass 34.83 g/mol
Appearance red, purple solid
Density 1.270 g/cm3
Melting point
813 °C, 1086 K, 1495 °F
Solubility in water reacts
log P 3.24
Hazards
EU Index Not listed
Main hazards reacts with water to release ammonia
Related compounds
Other anions Lithium oxide
Other cations Sodium nitride
Related compounds Lithium amide
(what is this?) (verify)
Except where noted otherwise, data are given for materials in their standard state (at 25 °C, 100 kPa)
Infobox references
Lithium nitride is a compound of lithium and nitrogen with the formula Li3N. It is the only stable alkali metal nitride. The solid is a red or purple color and has a high melting point.
Li3N has an unusual crystal structure that consists of two types of layers, one sheet has the composition Li2N− contains 6-coordinate Li centers and the other sheet consist only of lithium cations. Solid lithium nitride is a fast ion conductor and has the highest conductivity of any inorganic lithium salt. It has been studied extensively as a solid electrolyte and an anode material for use in batteries.[1] It can be formed by direct reaction of the elements, either by burning lithium metal in pure nitrogen gas or by reacting nitrogen gas with lithium dissolved in liquid sodium metal.[2] The second method gives a purer product. Lithium nitride reacts violently with water to produce ammonia:
Li3N (s) + 3 H2O (l) → 3 LiOH (aq) + NH3 (g)
Other alkali and alkaline earth nitrides also react in this manner, due to the high basicity of the nitride. The hypothetical nitride ion, N3−, would be an extremely strong Brønsted base, easily qualifying as a superbase. It is, in fact, a stronger base than the hydride ion, and so deprotonates hydrogen itself:
Li3N (s) + 2 H2 (g) → LiNH2 (s) + 2 LiH (s)
Lithium nitride is being investigated as a potential storage medium for hydrogen gas, as the reaction is reversible at 270 °C. Up to 11.5% by weight absorption of hydrogen has been achieved.[3]
Lithium forms a small amount of lithium nitride (along with lithium oxide, lithium hydroxide, and lithium carbonate) when it is exposed to air.
