Originally posted by AtariGenerationX
Is more simple.. thermal plasma in fact is UV + HEAT.. Meyer inside first system, Gas Processor, use non thermal plasma for crack N2 and UV light for ionize that.. I have posted some time ago Lens experiment.. also they use UV 350nm for water dissociation and pressure of 1000atm .. I have posted Meyer Sun diagram because I have study that for more time and finally I have understand how it work. I explain simple to you.. you can use thermal plasma or UV an heat saparately and obtain same result.. UV have an strange interaction with water vapour and nitrogen heated, oxygen present in air start quenching collision inside process but more oxygen cancel reaction, for that Meyer add nitrogen from exaust gas and stabilize reaction. But Meyer have understand that reaction can be reached ALSO directly with the sun light used with sequence stages, using UV + HEAT him obtain very reactive ions mixture and with WFC/ARCJET reached the thermal explosive energy.
Last indication is that inside Meyer injection system apart create reactive ions mixture for obtain reaction inside wfc/arcjet is needed to compress that mixture at 8,5atm -- WITHOUT THAT YOU DON'T REACH ANY RESULT -- as you can see process is very similarry to Lens, you use low pressure because first you create reactive ions mixture. Regards
