What is the second thing u learn in science class? After the energy lasts forever lesson of course?
A. Heat speeds reaction.
Why are all those Bunsen burners there for?
Average car has 3 built in heat reactors that can be easily tapped.
Combustion chamber
Exhaust manifold
CATalytic converter.
For this thread the CAT is the main focus.
From the CAT we get super hot Nitrogen and Super hot water vapor.
Sounds too good an opportunity to pass up. Especially when u consider its a lot cheaper to visit a muffler shop than it is to get an oil change and tune.
U will need a non conductive high voltage heat resistant processor in the gap.
Google leyden jar/air capacitor/noble gas and than use your imagination.
Remember that exhaust flow out is greater than intake flow. If thats an issue with anyone than go ask a turbocharger.
You are cryptic.. explain what you want ask . clearly..
Looks impressive and complicated. What type of tests will you be performing?
Keep up the good work!
Thanks, Mike
In effect system is an little complicated
We need to start new efficency test. Probably, adding a new low power stage, we have increased a lot the efficency convertion of nitrogen and water into NH3 and N2O that actually is 81.375% per mole of N2 . Regards
Interesting, looking forward to the test results.
I see that you use bottled N2 gas? Can you make your own N2 gas?
To run a 18HP engine electrical generator set, how much N2 gas will be needed?
Modifications on Micronic pre-ionizer stage .. togheter NTP reactor and UV reactor.. new stage is more little and functional and consume low power energy
Can you tell us the name of the components?
What are the gray tubes for? The ones with spark plug yellow and red cables going out from it.
Did i recognize well? Are you passing the nitrogen thru spark plugs?
HI Fabio,
I have changed method an semplify a lot.. with plug you don't have enough time for ionization, more visible vapour go out freely.. now I use an resonance NTP as pre ionizer stage in association with an UV stage first to send nitrogen/water inside reactor for eliminate the dangerous condense and obtain an special transparent gas mixture..
