Bill William’s 5X5 CDGSC Gas splitter dry cell
  • #16
    Hey Im currently researching how to build a splitter cell, have some questions if anyone can answer that would be greatly appreciated. So first bill's splitter cell I see there is a link to the membrane matterial 100% ripstop nylon there are 2 differnt types here 1.1 and 1.9 wondering the differences in these 2 uncoated fabrics UNCOATED RIPSTOP ..................... a local company has some ripstop nylon but Im not 100% sure on the specifics of this material. Also as far as the EDPM gasket material I understand it is a pond liner I have found it online but it is 1/16 which is actually .0625....... not .065 like stated in bills copywritten document. Im wondering is this a misprint is it actually 1/16.....0625 not .065
    not a big difference but I dont want to build a DUD my first go around that would be slightly discuraging. Other information I am searching is this silkscreen material for membrane is this just silk screen made out of silk or is there more to it???? I understand the silk screen process for shirt design logo's I am assuming that this is the material. Also wondering why shimms are required when using this method with neoprean gaskets. I guess the laser cutter is required because it has to be so accurately cut???? Also I can find 316 type L steal 22G and will most likely build out of this material first run but am looking for titanium MMO coating for anode and cathode at some point as far as titanium I could prolly order online but wondering about the process of this MMO coating is this something done at the manufacturer or something that is put on after buying?
    Any Help would be appreciated
    H2O ---------> Fuel
    • #17
      Hi M8 sorry i missed this one.
      Okee. Not sure about Bill;s specs there, drop me an email and ill forward and get a CC to Bill my friend. Yes the laser cutting is for accuracy, i dont recommend trying to cut it with out a machine if using silk screen, you could get a leak and mix of the gases. Now never tested the MMO/Ti so dont know how well they will hold up, we are testing a pure TI negative plate dry cell,
      I think they have around the same resistance of SS. Never seen how the MMO's hold up , if you can get pure Ti i would go with that.
      Ash
      • #18
        Parts for the GSC
        Hello everyone,
        I have the following items available for the Bill Williams' GSC (ready to assemble) shipped from TX, USA:
        1/16" thick EPDM 8"x8" pre-cut & contoured gaskets - $3.50 each
        8x8" 20 gauge precision laser cut 316L SS plates, drilled with 4 holes (1/2" dia each) and some with connection tab - $8 each, $9 for plates with connection tab
        8x8" separation membranes (rip-stop), with 4 holes (1/2" dia each) - $3 each
        Let me know which parts you need and what quantity. I accept Paypal/Chase quick money transfer or check (needs to clear)
        Thank you
        • #19
          cowboyrx,
          Do you have a kit to build a complete cell?
          IndianaBoys
          Originally posted by cowboyrx View Post
          Hello everyone,
          Thank you
          • #20
            Hydrogen separation
            I've been working on a dry cell, which separates hydrogen from oxygen.
            Through the system of alternate gasket, and nylon membranes
            Video: YouTube - ‪Dry Cell Hydrogen puro‬‏
            in the list some of the advantages, which I have obtained with your design.
            I am currently conducting tests without installing even in my car.
            In what I have currently installed that produces HHO dry cell
            This has the following setup, 316 plates 6 "x6" + nnnn-nnnn-nnnn + nnnn-
            I hope you look, my video and comment.
            He estado trabajando en una dry cell ,que separa el hidrógeno del oxigeno.
            Mediante el sistema, de juntas alternadas y las membranas de nylon
            En el enumero algunas de las ventajas, que creo haber obtenido, con su diseño.
            Actualmente, estoy realizando pruebas, sin instalar aun en mi vehículo.
            En el que actualmente tengo instalada una dry cell que produce HHO
            Esta tiene la siguiente setup, plates 316L 6"x6", -nnnn+nnnn-nnnn+nnnn-
            Espero miren mi vídeo y sus comentarios.
            • #21
              Your cell seems to have not enough flow for the gases. I had this with previous designs. You might consider changing the design by making the input at the front and the output at the back of the cell.
              YouTube - ‪gas splitter cell (GSC) part1‬‏
              • #22
                http://www.panaceauniversity.org navigation question
                ashtweth i noticed that there are some pdf's from Panacea University - Home that cant be found on the site under course's (is where i looked) i want to look at as many as i can so is there a spot that i can go to see more ??? this one is an example that i cant find on the site but you have a link to it thanks
                • #23
                  Hi Unite and ALL
                  If you go to the courses Panacea University - Courses
                  Then click the Hydroxy course all of the hydrogen (Bills is hydrogen not hydorxy ) PDF's are contained INSIDE THAT COURSE
                  http://www.panaceauniversity.org/Hydroxy%20Boosters.pdf
                  Any probs let me know, were you just looking for Bil's? What PDF's were you after?
                  Ash
                  • #24
                    Thanks gassplitter think putting water inlet and exhaust on the front and the back len improved, this because expedite the flow, taking into account.
                    • #25
                      ty
                      hi thanks ashtweth for the reply im after them all my friend. i want to learn, create and help the earth. Right now im on my self-educate phase next experiment and prove, then get it out there to help all of humanity i believe i should be able to find everything now ty
                      • #26
                        HHO Generator Hydrogen Separator HFS 12 Volt Cell
                        Here's a Hydrogen separator selling on ebay:
                        HHO Generator Hydrogen Separator HFS 12 Volt Cell | eBay
                        • #27
                          WTF!
                          Patent Pending
                          The hydrofuelsys Separator Cell is our first to market Hydrogen and Oxygen cell that separates the gasses to 99.9999% purity. It is more efficient and makes all other HHO cells OBSOLETE.
                          • #28
                            Separator Cell Installed on a Toyota Supra
                            Bills design
                            ‪Separator Cell Installed on a Toyota Supra‬‏ - YouTube
                            Ash
                            • #29
                              Compressor
                              Anyone know of a source for a reasonably priced compressor to store the hydrogen?
                              • #30
                                Hi Ash
                                Did you receive a reply relating to this?
                                Patent Pending an open source design Hmmm?????
                                Bill
