I have been lurking around this forum for over a year and have learned a lot from various members posts. I have built and have been experimenting with the Lawton size cell and circuit, while incorporating a transformer, diode, and resonant chokes. I believe I have hit a dead end, as many have, in finding resonance or high voltage and it appears that it is a more efficient form of a Faraday type process but not the Meyer's way.
I have read through Meyer's tech brief yet again and have set up a new experiment based on it. I am curious to know if anyone has attempted to set up a single tube cell as Stan calls for in a patent 4936961 and drive it with opposite voltage potential with an isolated ground as called for in the tech brief 8-6.
I am not ready to provide actual figures as to voltage, current, frequency, or actual size/dimensions of components yet because I have just thrown together various pieces to see if anything would happen.
The following is to give a rough idea as to what I am working with at the moment and the results achieved.
The transformer I wound consist of one primary coil and two secondary coils. Not sure of the turns ratio but I do know it is close to a 5:1 step up. The primary is driven by the Lawton circuit at 12vdc pulsed with variable freq & mark/space. The secondary output is +560 - 0 - -560 peak-peak and 180 out of phase. The circuit uses an isolated ground as Meyer specified and currently I do not have resonant choke in place. I use a 1n4007 diode on each leg going to the cell. When I operate this set up I get a small amount of HHO produced with no measurable current on either leg to the cell using an AC or DC amp clamp. I have also witnessed a step charge while gating (possibly what he calls Dynamic State Space). While the gating is turned off it would create what he calls Static State Space. When the power is turned off the charge that the water has taken on can be seen and it takes several seconds for the charge to decrease from several volts to close to zero. The charge the water takes on can also be seen during the off cycle in gated operation. When the frequency is adjusted with the cell in the water bath I can obtain 150-600 volts. Possibly tuning into the resonance of the transformer?
So far with thrown together parts and at first glance it appears to be functioning close to what Meyer's claims. Further testing will tell.
I have seen others state that once they get a working system they will post it full disclosure but when they "get it working" they never post or duck back into the shadows. I am here because I want to learn more and share my experiments and experiences. Any insight or comments positive or negative will be welcomed.
Also, before I get bashed by someone. The transformer was measured with a scope from the high side to ct and the ct to the low side in open circuit configuration and the voltage did not change much when the cell was placed into the water bath.
Smallengtech
Smallengtech
