None Electrolytic Splitting Of H2o
  • Updated PDF File
    The most recent pdf file of this thread has been uploaded to page 3 of this thread if you want it.
    • Wow Duncan
      Do you plan a TV transmitter station?
      • See you there
        @ All
        See you there, we need to talk about quite a few things and what is planed for the future
        Going to pack my case, leave tomorrow at 5am from my house and it is now 6pm here, long three plane journey. Be sure to bring warm cloths , it is cold out there but for sure a warm welcome for all.
        Mike
        • Wish I could have been there. NARF said they would like to send me, but they wanted "Lot's of Pictures" to go with my writeup on the conference. After I wrote them that pictures are absolutely restricted as are cell phones, I have not heard back from them. Air fare has doubled since my first request so at this point I guess it's a no go
          I know you all will have a good time
          • Thanks to all
            @ All
            May I just thank all that were at the conference and the warm welcome that I had from 30+ people for the 11/2hr talk on the none eletrolytic splitting of the H2O molecule, even though we were interupted by a security guard.
            During my stay I have sorted out the possible production of the RF part of the system and this is currently being worked on and hope to have available in the not too distant future.
            Working in the background, Aaron and co hope to have a full replication of my 1989 prototype for my 60th birthday, 11th jan They are well on the way with completing the original jet engine and running first time which I saw while I was there, a big hand for Aaron an Jeff whom have taken 9 months to build it from my instruction. It runs better than mine did at very low 5000 RPM up to very high 20000+ RPM, and is quieter than a vacuum cleaner yet makes a very good leaf blower
            Will keep all posted as and when there is more to say, there is a lot of work to be done.
            Mike
            • Thank you!!
              I feel like the real thanks should go to you for being willing to share with us. I learned a lot from you in the few minutes we spent together. It sure didn't seem like an hour and half. Thanks again for taking the time and having the patience to share with us.
              Carroll
              • focus on the rf
                Just advice to everyone - have at least a 12" diameter lathe to give enough
                clearance to turn a 6.5" OD heavy steel tube. Can always be built with semi
                exhaust pipe, etc..., but I'd recommend building it with good quality materials
                and make it rugged - instead of just good enough to make it run.
                My 9X19 lathe was only good for some of the project and had to have a friend
                do the big tube on his large equipment - for free thankfully.
                With the right tools, probably 1-2 week job to make one really good.
                If you all get the RF circuit running first and prove that out, the sky is
                the limit or maybe the moon. You can apply it to many applications but
                a jet engine is the simplest. Make sure to check out that turbojet thread
                I started here and check out the references like the yahoo group.
                Anyway, please focus on the RF "reactor" since that is the KEY.
                RPX & MWO http://vril.io
                • Hi All
                  I am home at last. It was great to meet all you guys!!
                  For some dark unexplainable reason I missed the meeting at the conference and when I made it back there I did not know where you were.
                  Is there any way that some of the details about the RF part (at least) could be repeated here on the thread?
                  Vissie
                  • molecule creation
                    Hi Vissie,
                    We were way in the back past the fire place in the lobby.
                    The concept is in this thread, Mike just went into a lot more detail.
                    Water vapor coming up - vapor for more surface area to absorb the RF.
                    2 antennas that it moves up through.
                    One antenna with 100mhz the other with 600mhz (6 times spread is
                    required). They interfere with each other can create a difference and
                    sum of those frequencies. 500mhz and 700mhz.
                    All 4 frequencies mix and effect the water molecules. Bonds are weakened
                    in the nitrogen molecules (bubbled from exhaust - or pumped in from a
                    nitrogen tank, etc...) and h2o bonds are weakened. Instead of necessarily
                    splitting, the elongated weakened bonds swap between each other like
                    a boiling stew (in vapor not submerged).
                    So H bonds to N for nh3, some o bonds to n for n2o, etc...
                    • (H bonds to N for nh3, some o bonds to n for n2o, etc...)
                      Does this means that without nitrogen the process will not work. Are the n2o and n3h the fuel now.
                      Will hydroxy not be formed without the nitrogen?
                      I think I lost you now.
                      • nitrogen is the key
                        Nvisser,
                        The key has always been nitrogen.
                        Hydroxy (hho, etc...) all explode then turn back into water right away
                        so you get no real "thermal combustive energy".
                        With nitrogen, it gets in the way of h & o forming back to water. There
                        will be h2o in exhaust but not much. Nitrogen in a way plays the part of
                        an EEC (Meyer's electron extraction circuit) so to speak. Any atomic nitrogen
                        is seeking 3 electrons to balance so can suck them up so the h&o doesn't
                        have access to them.
                        Nitrogen molecule has strongest molecular bond (triple electron bond).
                        So when split, it has the strongest suction for anything negatively charged.
                        3 H's can join to Nitrogen to make nh3. N is just a carrier for 3 atomic
                        hydrogens just as C is the carrier for hydrogen in carbon based fuels.
                        When burning, you crack 3 atomic H's off the ammonia and atomic
                        hydrogen gives you 3 times the power when burning compared to molecular
                        hydrogen.
                        You need the plasma ignition running with the water fuel - the plasma
                        can crack the H from the NH3 easily.
                        nh3 and n2o have always been the real water fuel. Other nitrogen oxygen
                        compounds are formed as well. The emissions are just nitrogen and
                        some water moisture.
                        Meyer called the nitrogen "non-combustible gases". He said you need that
                        in order to SLOW down the burn rate of the water fuel. That means you
                        get the thermal energy out of it as described above. Without, you get a
                        quick hho brown's gas pop that turns back into water - just a waste of
                        time.
                        All the self-proclaimed Meyer Guru's refuse to acknowledge the above and
                        I provided all the proof based on Meyer's own words in the Ionization
                        thread but they still want to debate it. They are lost because they
                        just want to focus on making as much as hho as possible while refusing
                        to recognize the more important key - Nitrogen.
                        I also posted references that go back to the early 1800's - the first was
                        Davy that showed that Nitrogen will bind to electrolytic hydrogen in
                        the presence of water
                        . Basically, it has been known for 200 years that
                        you can make nh3 (ammonia) out of air, water and electricity at low
                        power, low heat and low pressure.
                        You need nitrogen bubbling up in the water mix as the water is "split".
                        • Aaron I am flabergasted
                          Aaron what a great explination, you have really learnt the system.
                          Just one thing to add, what happens when the molecules vibrate is that they internally heat up and they can reach very high temperatures inside and only radiate a small amount of this heat, this increases the N and H bonding.
                          As far as producing H2 and O2, yes it will, but not the way to go as I have explained time and time again.
                          What is better than a fuel that will run an engine with very simple adjustments as from petrol, a H2 and O2 perfect mix ON IT'S OWN is a very dangerous field to be in and your engine will not like it either.
                          Mike
                            Nvisser,
                            The key has always been nitrogen.......
                            Aaron,
                            Probably you and some peoples think that for dissociated NH3 you need to use thermal plasma from capacitor discharge and tungsten plugs for not consume electrode!! This is wrong!! You need to use non-equilibrium plasma or simply called non-thermal plasma. ONLY with that released energy you can "crack" NH3 molecule into NH2+H, in that way you don't produce any hydrogen outside but all reaction appear inside the chambre of combustion that is safety and simple to control. If in your mixture of NH3/air you add nitrous oxide you obtain an strange reaction, in fact hydrogen atoms released from NH3 (NH2+H) acts as catalyst on nitrous oxide releasing an great amount of energy, much more than gasoline! But attention that reaction appear only with an mixture of ammonia, nitrous oxide and air; if you use an mixture of hydrogen/air and you add nitrous oxide that reaction don't appear
                            • thank!
                              Thanks Mike!
                              Thanks for the reference paper Alex - I will look over that tonight.
                              Need to catch up on some sleep
                                Hi All
                                Vissie
                                I was distracted else where too Vissie, I guess we’ll have to hang for a while now and wait for information to trickle through.
                                As you say Vissie a really great group and a pleasure to meet many of them and be able to put faces to the names!
