Originally posted by Karl
I have given the basics of the way it can be done, there are others such as my e-beam which Alex seems to know how it works and is selling plans
http://www.ems.psu.edu/~radovic/PLW/...ola_Carbon.pdf
This is a link to a paper "please note the date" which was so close to making synthetic fuel, the problem was they went about it in the wrong way and was not continued that I know of until I started with it.
The basic concept was right, but the application was wrong, it wasn't until about three years ago that I realised what was needed and took me a year longer to get to a very primative working test model. Even that has changed as it did use a very high vacuum of which Harvey has seen the results of a very bad burn on my arm from a combination of X ray and high RF field.
I had to change from a vacuum to normal atmosferic pressure and still produce the e-beam that I wanted, this has been achieved and does work and I call this the secound generation reactor after the RF reactor. It still uses RF, but also very high voltage to produce the e-beam of very high energy for the reforming of gases and the splitting of the water molecule.
All will just have to be patient, it will be out there in the very near future, but when all the POSSIBLE side effects have been dealt with and building very much simplified.
The one thing that is of concern and that is any approval or certificate that this would need and that is why all the problems will be sorted as near as possible BEFORE it is known how to do it, if not it will die under a pile of papers.
Mike
