None Electrolytic Splitting Of H2o
  • additional questions
    Has the reactor have the ability to separate the NH3 and N2O?
    I wouldn't want the N2O, due to technical issue's modern cars are heaving with additional O in the burning process and adding more fuel to the mix. (I don't want to use a Volo (EIFA) device.
    On-demand H2O drycel already have working design of having 2 outputs (pure hydrogen and oxygen)
    • Originally posted by Majestic81 View Post
      You don't need. The sensor don't sniff N2O
      • TEN MONTHS Nunnerly, where is it? success stories? Clips/vids etc. lets have them mate
        shill, we must but try
        http://www.energeticforum.com/renewa...correct-2.html
        • Originally posted by Karl View Post
          Why such hostility Karl?
          This seems inappropriate. The mechanism was given, the method of accomplishment, even much of the basic parts were outlined. Are you owed more? What have you shared with such certainty?
          My fiance's grandparents watch fox news quite often, and I start to wonder, why people would pay attention to other people who seem to radiate anger, and hostility; pretty clear sign of frustrated soul who does does not realize their internal locus of control.
          • It appears that tossing stones and generally stirring is a way of operating for some.
            I find it interesting to watch those that run around and blow out "candles", they frantically try to be the brightest, by making them the only apparent light around. The sad fact, is that they are never the brightest, for they soon find themselves as the last!
            Having been working on my bike - and getting 20mpg more - on my first 100 mile run, leads me to KNOW that there is truth in this whole subject.
            Experiment onwards!
              Why you want separated NH3 from N2O? You obtain an good stechiometric fuel mixture that burn with only 0,07mJ of activation energy. Differently from hydrogen/oxygen ammonia and nitrous oxide can be compressed at lot without problems because you have nitrogen as carrier
              • You already debunked the reason for splitting the NH3 and N2O.
                I would really like to produce the reactor described in this thread, but I guess we all have to wait for the knowledge to be shared in detail.
                • How much BTU at which PSI does NH3/N2O have?
                  You mentioned to use 200 Watts as a starter, is the reaction self-substainable after this?
                  How much are you getting out of the reaction process in KW/efficiency %?
                  Do you still sell these plans and do these plans contain the whole design, with parts-list so I can build a workable prototype myself?
                  Do you have any vidz or pictures of your protoype?
                  Greetings,
                  Majestic
                  • I too am interested in anymore plans or information that can be shared. I am reading about RF design and concepts. I know its difficult to work with when I don't have enough experience. Does the circuit need to be continually tuned or adjusted once its built? Like a dial to tune the inductance? Or is it all solid state once the impedence matching is done? I don't expect to receive all this information for free as far as plans I am willing pay for it too just so you know.
                    Chris
                      Joseph H. Cater comments: The experiments of Schauberger and others have confirmed the enormous and almost unlimited quantities of electricity housed in water. The following is an absurdly simple and practical method of extracting this energy. It employs the “Coanda” or “cloud-buster” effect.
                      A plastic tube 14” to 16” (350 mm to 400 mm) long and about 2.5” (65 mm) in diameter is filled with distilled water. At each end, exposed to the water, is a copper terminal which is used for both the electrical input and output. Rechargeable dry cells of suitable voltage are connected in series with the input terminals. When the two output terminals are short-circuited or connected to a load, electricity starts flowing. This is current entrained by the input current. When high voltage is applied, the output voltage is almost as great as the input voltage. However, the amperage is inadequate. The answer to the problem is ultrasonics. It is an experimental fact that ultrasound of 600,000 Hz focussed on a container of water causes the water to boil. This means that sound of this frequency disintegrates large quantities of “soft” electrons in the water. The sudden release of “hard” electrons produces tremendous thermal agitation of the water molecules.
                      A DC ultrasonic transducer attached to the tube would produce sufficient free electrons to be entrained for the unit to have almost unlimited output potential. The tube functions like a sounding board. Mr Cater has been given powerful evidence that two different individuals who received this information got sensational results from the generator. They had access to such a transducer. They tried to set up in business but the vested interests saw to it that they were put out of business and persuaded to remain silent ever since.
                      An associate of Mr Cater built a fist-sized siren which generated a frequency of 600 kHz. When focussed on a small container of water, the water boiled. This demonstrated that it could be used instead of a solid-state DC ultrasonic transducer on the water generator. A small DC motor could operate the siren. It would be far more effective as it produces a much more intense sound.
                      If one were to make this device with a 600khz transducer and the water starts boiling, would it blow apart?
                      • Proof of Concept 1939
                        This link was found in another thread I apologize and thank the person that first posted the link. I saved it and could not locate its origins.
                        I would like to post it in None Electrolytic Splitting of H2O; it is a Popular Science article from March 1939. Francis Wilkinson,” Back yard Alchemist creates new substances with high frequency electricity”. There is a lot of information on his processes and hardware. He never used it to disassociate water but it looks like he used it on everything else.
                        If the RF experts could look at this and comment, we may be able to put a spark back into this thread. Pun intended, speaking of sparks check, out the spark gaps in his oscillator circuits.
                        Francis E. WILKINSON -- High Frequency Transformations
                        • what is the status?
                          I am still interested in knowing more about your working prototype.
                          Any pictures or vidz of it working?
                          What is the status of the E-Beam project?
                          Greetings,
                          Raymundo
                          • Hey Mike
                            Hey Mike sorry to hear about you son. I will purchase one of the vids from Aaron to help you with some fund raising.
                            I am wondering if you ever messed with these toroids of meyer design. Have you seen them? I never knew what these looked like until recently.
                            Why are we not talking about these? How they work, how to build, this is what we are all after.
                            pics available here:
                            Index of /rwg42985/russ
                            Under stanley meyers epg high quality pics
                            Chris
                            • e-beam and my son Mark
                              Chris
                              Thank you, my work had to come to a stop for a while, but now I am having to slowly start again and make some money as the only person in the family that makes money is my wife.
                              E-beam has had to be turned into a commercial development, not what I wanted but I have to get income from somewhere. E-beam is very very real which involves a lot of my past and present work.
                              I will maintain full control of this, and it will not be assigned to one single entity, I want it to be available to all and at a reasonable price.
                              E-beam one day might be the molecular convertion reactor that powers both your home and your car. It does not have to be big as a small one can be powered from solar during the day and the gas produced compressed and used at a later time, the primary gas that I am working on is methane, but also ammonia can be made. Compressing is not a problem, there are many taxi's and buses using natural gas today which is compressed into cylinders in the buses and cars at the time of fillup.
                              Money is the problem for me at the moment as Mark, my son, comes first, "hospital fees are 10,000 euros a month", this will be recovered from the insurance of the driver I hope, but that is going to take up to two years in the courts to get it back, and I am nearly 61 years old and Mark 16 years old and may have to have perminent help for the rest of his life (you see the problem).
                              If anybody wants to give a direct donation they can make it via paypal at algar.stay@hotmail.com and mark it "Marks fund", it will all go to helping him now and in the future.
                              Thank you in antisipation
                              Mike
                              • Pic's
                                Yes I have seen the item in person, it is an electric generator that works on gas in the toroid, "H1 H2" in a magnetic environment.
                                Mike
