  • Power amp circuits
    Here are the two power amp circuits with variable output.
    https://cid-c3ba32bd7559553a.photos....BD7559553A!113
    https://cid-c3ba32bd7559553a.photos....BD7559553A!112
    Mike
    • @ All, You will see that the S-AV10L is rated from 135Mhz and as so the VCO will be tuned to this frequency and will give 810Mhz at the 85Y12.
      Aaron I will try to give you a complete circuit diagram of all to be put into one box, but it will be hand drawn, so if anybody can do a pro: job on it, it will be appreciated, as I do not have a cad system for electronics.
      Mike
        I signed up to view this but it tells me: This item might have been deleted, expired, or you might not have permission to view it. Contact the owner of this item for more information.
        I suppose its like Skype and that we have to download it from your computer while it is switched on.
          Sorry about that, it is the first time I have used it, I think it is because I put it for my use only and not public, I will try and change it or post it in another place.
          Mike
          • It's working now!!
            • Voltage control circuit
              Welcome to Windows Live
              This is a standard voltage control circuit
              Mike
              • photobucket
                Mike
                That says I need a Windows Live account - can't view the pic.
                If those are your images you're uploading, Image hosting, free photo sharing & video sharing at Photobucket
                is a free and easy site to upload images all into one place.
                • dream..
                  I have read that thread an Im very surprised because you have accepted immediately that HF theory. Probably that work or probabbly not, however for see that you need to spent some moneys an time. At this point I have some questions.. Don't exist other way for to see if that method for produce hydrogen/oxygen work surely? And why Mike fom 1989, date that this project is stopped, at today don't have build that? For your reference I attach here patent number 4,579,618 dated 1986, is called plasma reactor and is very similar to Mike method.. more similar Regards
                  • Please tell us what that patent is about. It will save me the trouble of reading it.
                    If you think this is the same method to make H2 why do you question Mike's method?
                      Hello,
                      First read patent attached and only after reply. I have written only that methoid used is very similar to Mike system.. Mike know perfectly that system isn't new and however, if work, you create brown gas and not H2 as you write.
                      • Originally posted by tutanka View Post
                        Alex this is no theory, it is real and it can be utilised to do many things depending on how you utilise RF, from killing cancer cells, metal etching as in the patent you quote, to breaking the water molecule. This has been shown by various people including Dr. Stiffler, but we all have our different methods and see the result in different ways, some work better than others and it all depends on the best way to deliver Vbr "vibrational resonance".
                        Yes I was stopped in 1989, paid for this and not to use it for 15 years. In the last two years I have had time to reflect on the past and, this is where the theory comes in, have found other ways to produce what I want but using the basic principles of before in a different way. Before now I was not in a position to build again the same setup as before, I have been fighting to get back to a reasonable financial state of living by working very hard up to 12hrs a day. Now I am semi retired but have a great wife who works and supports us both so as I can concentrate more on future energy inventions.
                        As far as anybody building this, it is up to them, there is no pressure on anybody and as far as cost well it is not that expensive, probably the cost of four or five good meals in a middle class restaurant.
                        I don't need to prove anything, be there, done that, it is up to others to prove it right, and they will find it to be right.
                        Mike
                          Hello,
                          Hi Tutanka and welcome, I’ve just had a quick read through this patent you’ve posted It’s quite a construction!
                          There are undoubtedly folk’s on this forum that could machine those chambers with ease (I’ve seen some phenomenal pictures on this forum) but machine of what? The construction details and sizes are lacking.
                          The fact that VHF and UHF are being selected seems to rankle. I think if you read carefully through the whole post you will find that the most efficient frequency band is yet to be determined.
                          Meyer himself is quoted as “working in KHz “by the commentator in this program Stan Meyer - It Runs On Water ( Full ) Hydrogen Oxygen ( HHO ) - Zero Point Energy also note Tutanka the water hammer heating effect would also be low frequency (compared to the frequency we are using).
                          But there again the physical effects are very different although still OU.
                          Where or what stopped in 1989?
                          I would think this construction is cheap as chips compared to that unknown, untried, untested patent you have posted.
                          However if you’ve actually built a working example please open a separate thread you’ll certainly grab a lot of attention including mine...
                          I have no doubt this construction will work. Expense? Compared to not knowing ….priceless!
                            Mike
                            Mike,
                            That system can work but for me and for you H2 don't have more sense. However at today l know only that you are discontinued in your projects.
                            We have started togheter with new reactor project and from the way you are lost. For my experience I know, and you have write me, that you don't ask completely for security (yours) but only in part, fortunately I don't need your suggestions and at today reactor work properly without your initially concepts. Sorry I don't dsturb you in your thread, I have write only because I have found similar patent with method esposed from you. Regards Alex
                              Mike,
                              Alex if you read the document in my first two posts you will see at the end that I have not changed my direction and I am still working on a direct convertion to a none pure hydrogen and oxygen gas to be used in all types of combustion engines, such as NH3 and N2O.
                              The basic concept of molecular bond breaking is as shown in this thread and will produce H2 and O2 in quantity and using a metal membrane you end up with the separated gases.
                              For those who want to burn these gases in an engine, OK, but be careful it is dangerous. Or can be used in hydrogen cells to generate electricity. I want to create a new fuel that can be used in all the scrap metal that will be lying around after the petrol we now use is so expensive that nobody can afford to buy it.
                              Mike
                                Mike
                                Mike,
                                Please don't explain me nothing about new fuel. You have decided to work in hermit mode and I accept that. The same is for me. Regards Alex
