Sorry Mike I've lost whatever was on my mind with the Mag amp good find re VHF TX. I must have been thinking of much lower frequencies as mag amps are no good where we are. Sorry for the deviation
I can't help but wonder if all of these events mentioned in prior posts here, Meyers et al are not pointing at something I've written about before, except in these cases it could be happening at a molecular level with thermal isolation from neighboring molecules. In other words, the RF is producing pinpoint zones that stimulate thermolysis in that zone while being insulated from a thermal conduction point of view relative to surrounding antinodes.
If so, then those orthohydrogen molecules can cause an exothermic reaction resulting in more energy stored as dissociated H2O than the energy put in to cause the reaction. It is quite possible, that specific EM frequencies provide the necessary magnetic phasing to organize the orthohydrogen into the reaction nodes while positioning the parahydrogen into the non reactive antinodes.
If this is the case, if I am right here, then you have unlocked the key to on-board hydrogen production in moving vehicles. All the evidence seems to be pointing in that direction. Even the Cavitation Heaters seem to doing this in a quite haphazard way.
I have written about the possibility of large scale thermolysis reactors and the requirements to get them functional - but if it is possible to create a web of thermolysis nodes within the chamber that automatically sort the molecules as needed, the implications are huge.
Thanks for sharing this with us
Thanks Harvey for your thoughts on this extreemly important occurance, you can see why I had problems on this quite some time ago. Trying to explain this is difficult, it is theorising on an actual event, not in reverse.
Remember me talking to you in private on the two cap theory, as it was then, well I have gone a little further on this and does now enter into my current work which takes this thread to a higher level. I still have not got it as I want it, but getting there slowly.
Sorry all, going off topic for this thread AT THE MOMENT, but will all come together at the end.
Sorry. R4
Ok . Will the RF not leak through the 10K resistor to the power line?
If you are worried about it put a little ferrite beed with two holes, make one loop, on the R4 resistor to the base of Q1. I have not run this on spice, but will work OK, quite a standard inter amp for driving Linear amps.
Just make sure you read up on PCB's for RF, VERY IMPORTANT, the ground plane is a must.
They are already out of stock!
Somebody buys this stuf up as soon as you post it
Dear Sir:
Thanks for your inquiry ,we have no stock ,sorry
Best Regards
Candy
still over 33 where I informed. he's upped the$ though...If your going to have a bash at this TX board Nvisser pls post the artwork you come up with (if it works) as you’ve worked on UHF TX TV reasonably recently you’ll probably make a better fist of it than me.
I rather hope Mike will post a working sketch of what he has in mind in due course.
I’ve still got bits coming from far and wide and so I’ll be a while anyway.
Hey enjoy the conference I’m afraid I’ve got other commitments but I’m envious.
There’s certainly a few giant’s there
Reason: addition
Since someone is buying up all the posted components as soon as they are posted, you guys are going to have to change the rules of the game. You're going to have to get your heads together and build this device off forum and post your results some time later after you've finished your project. Of course, when you release your details they'll buy up all the components at that time also. So, that's a very bad problem in deed. At least they are not doing any sinister stuff yet that we know of.
The only small Rf circuits I ever constructed was just soldered together as it was small FM transmitters or Tv amps.
The groundplain should not be a problem and keeping the tracks as short as possible also not.
To match the outputs to 50 ohms is the problem. They say you have to know how thick the copper is and then calculate the width of the track.
I think Mike's suggestion of using a short piese of 50 ohm coax cable will be much easier.
Than I suppose you have to run a Feedthrough (via) through the board from the ground plain and connect the coax screen to that. Now I am not sure if you have to split the ground plain to prevent loops.
Maybe Mike can post a drawing of how it should be done
You guys are doing a great job.
Best Regards,
Slovenia
Hi Slovinia you’re doing a great job on the PDFs, Much thanks, The TX amp is really a Minor disturbance I think it’s more important that the information and our efforts are broadcast.
These VHF amps are used in their hundreds every day, without them the police forces around the world would collapse along with a lot of other VHF services.
I know where there are S-AV10Ls and have circulated the information.
Even if they were all bought out world wide it’s easy enough to just change make.
If whoever is buying the things believes it makes a wit of difference if we use Toshiba or Motorola or anything else he’s sadly mistaken. After all if you wanted to go to the shops would you care less if you drove a ford or a Vauxhall? Perhaps they are being sold because lots of people are going to build this project!
As for the “sinister” bit well I’ve had to up my security because of information received.
The bulk of the information is out now anyway. Never mind “locking the stable door after the horse has bolted” This horse is out of is stable and 10 mile up the road!
