HHO burner heater
  • #16
    Originally posted by Wireguy View Post
    Tutanka,
    Thanks for the great information.
    How important is the water energizer stage prior to the HHO cell?
    Are there any additives (salt) needed in the distilled water with this system?
    Best regards, Wireguy
    Water energized stage is for water activation .. Also Meyer use UV irradiation. Depend what you want obtain from the process.. nothing is magic in nature.
    • #17
      Meyer system simply replicated ...
      Hello,
      That is scheme used from me for replicated simply Meyer system.. Just you add right names to the stages.. to the end new fuel is created for run your scooter or car to 100%.. Today burning test of new fuel mixture to the university have reached in combustion chambre 380atm of pressure. Very impressive!!
      • #18
        Did you go Past unity??
        Tutanka
        How efficient was you replication of Meyers work??
        Thank you
        Chet
        BE that change !!
        • #19
          Tutanka
          Thank you
          Chet
          This system not need of meyer injector but you can create an controlled stechiometric new fuel mixture similar to an carburator and can be burned in all engines benzine or diesel. Is very simple to realize using parts found on internet with little modifications and the mixture inside your combustion chambre burned releasing the" thermal explosive energy" as meyer wrote in all papers
          • #20
            Hydrogen Hydroxy HHO Heat Exchanger from HHOG Labs for Home Heater - YouTube
