Hello all,
I am working on a Stanley Mayer system to produce HHO, that i plan to demonstrate in my site (like all of my projects). I am little bit confused with the inductors after the step-up transformer (the ones after the secondary coil of the step-up transformer) I am working on 2 types, toroidal and bifilar.
Toroidal:
I have 2 different coils, NOT on the same core, each one with same wounds (200 rounds each), with 24 AWG wire. The toroid core is 1'' diameter
Bifillar:
I still have not one make yet, because i have found several different designs, and i do not know which one to follow. More specifically, i have seen one type that has both coils turned with the same direction, and another type that has the coils turned in opposite direction.
Please tell me the proper setup that you used. Toroid, bifilar with both coils in same direction, of bifilar with coils turned in different direction?
Regarding the electronic circuit:
I have design myself a very flexible electronic circuit (that i will post details in my site), with 4 op-amps and 2 comparators, based on a previous circuit that i had designed some time ago, which you can find here:
Voltage controlled PWM Generator
If my fuel cell works, i plan to publish an automated controlled circuit with PIC micro, as i am very experienced in using microcontrollers. I will publish full details as i always do with my projects.
Your help will be highly appreciated. Thanks
Giorgos
Toroidal:
Bifillar:
Giorgos
