I am noticing very strange things so I thought I'd share what I'm seeing in case maybe someone else has also experienced the same thing, or if not maybe it could be worth investigating further.
To explain a bit about what's going on, I went to a guy's house on thursday evening who mentioned Stan Meyer and had built a crude and simple water fuel cell, consisting of 4 short rods poking through the bottom of the cell. I did some research (youtube) on friday afternoon and returned to his house with my SG and hooked it up to his fuel cell. The thing worked and was producing hydrogen and oxygen bubbles.
So, now that I saw it was simple and worked, I came home and repeated the experiment with an even cruder cell by cutting 2 pieces of 6mm steel rods and put them in water in a glass jar, connected the output of the SG to each rod, and turned it on. The neons lit up, so I added salt as they slowly faded out until they went off. The voltmeter showed around 8.75v across the SG output, and 40v spikes on the scope. Some fizzing and a stream of small bubbles coming off the rod connected to the negative. The potentiometer works normally, as it would if the SG was connected to a battery, varying the frequency and current and what not. I haven't tried this test while measuring the input or output current so I don't know about the input or output. The rotor spins pretty fast, but I forgot to look at the frequency.
But this is where it gets strange. Friday I went shopping for some steel tubes, I got different sizes mainly to try a Joe Cell, but I built a simple thing for basic electrolysis I thought using a 6mm rod placed inside a 10mm tube, which are both negative (the rod extends out of the water for connecting), which fits inside a 25mm tube which is positive (as per Stan Meyer's basic design), and the whole thing is held together with plastic bottle tops on either end, with appropriate holes cut in them for obvious reasons.
So I dip this contraption in the water. No more small fizzing bubbles. Now it's doing something strange, creating a sort of foam of bigger bubbles on the surface of the water.
Also a very strange and different waveform on the scope. 20v spikes, 1.8v showing on the meter. Increasing the SG trigger resistance in the upper 50% of the pot range causes the rotor to slow down, and input current drops to 100mA minimum, while output is 100mA minimum. Input and output remain pretty much even up until 150mA input, then output climbs faster than input.
The lower 50% of the pot doesn't alter the speed, the maximum it will do is 123Hz. But the lower 50% range does change the input and output current. At 680 ohms, input is 375mA, and output is 450mA.
So I have no clue what's going on here
But it's given me a couple of ideas for things to try, and I'm about to put another electrolysis tube contraption together and play around to see what effect different configurations (use separate containers or put both in the same water, parallel or series on the SG output etc) has. Also I'll make sealed containers with a way of attaching a pipe to get some way of being able to see how much gas is being produced.
I'm using a standard monopole circuit, tri-filar coil with 2 parallel circuits, and a rectifier made up of 4 diodes across each coil. Standard SG hooked up to steel placed in water with a bit of salt instead of a charging battery basically. Apart from the input and output current numbers, I found the difference in electrolysis effect between using the rods and then using a tube inside another tube curious in itself. Though there are still one or two things I'll have to modify in order to rule out what the cause might be. But the fact I can't get the rotor to speed up, and the voltmeter is only displaying 1.8v is also curious. I don't know why this is. It doesn't make sense in my mind that a simple (and small) change in surface area through going from long rods to short tubes would have such an effect.
Anyway, if anyone knows what the hell is going on here or wants to give it a try and see what they come up with, be my guest
