Sell Plans For Reactor Fuel
  • Sell Plans For Reactor Fuel
    People,
    The future fuel for endothermic engines is called hyper-gas
    Power Output vs Power Input
    Tutanka,
    Can you provide a video of you system running a generator or some other device so that we can see the power output for the 150W power input?
    Glad to see you have made some good progress on the system.
    Wireguy
      Estimate of power output
      What size device do you believe the system ( from the plans ) would power? Or is this system to act as an ammonia source for refill system (filling of a larger supply tank) which could then fill your automobile.
      I would like to understand what you envision for this system.
      Wireguy
        Hi Tutanka, in the pictures you show a 70kw reactor, what size of engine will run on this reactor?, what is your best achievement using this technology?
        If you can, please tell us a little more.
        Congrats and best regards.
          You sir....are an ass.
            Hi Alex, there is no doubt that originally when involved with some members here in this forum you were on the right track and i know trustworthy engineers who can vouch for that, we donated a cell for you guys, what is this your mentioning now, is this the WORKING principles based on that work? what tests and info do you have to relate to what your offering?
            Ash
              Originally posted by tutanka
              The reactor on photo can run an 70kW engine.
              Thanks for the info Alex, keep up the good work!
              cheers
              Mike
                You should really just teach them how to make the fuel for this new age coming. Its called the do it yourself age. Because if you rely on man to do it alone he will screw it up.
                  NH3 hybrids (gas and diesel) from Vezna
                  YouTube - Back to a better future: Greenergizing Hydrofuel
                  (half way through)
                    Hey? Tutanka what about those who dont have two hundred euros to spare are we,out of luck? I myself have all kinds of materials and electronics at my disposal, but with what I have read on the thread that covers this system. I just dont have enough knowledge to replicate.
                      Oz Nitro Cell
                      (half way through)
                      Hi Ash,
                      Alex's photos above looks really close to the "Oz Nitro Cell design."
                      Discussed earlier on this forum:
                      http://www.energeticforum.com/renewa...itro-cell.html
                      The plans/drawings of the Nitro Cell by Patrick Kelly's D18 pdf document:
                      http://www.cyberspaceorbit.com/D18.pdf
                      One of the biggest differences to Alex's photos above, is the Nitro Cell has an input port and and output port, while Alex's unit has only one gas port as shown in his 2 pictures of his unit above.
                      They both have the coil wrapped on the outside of the outer tube and input a small amount of current.
                      Patrick Kelly could not find anyone who was successful in replicate the Oz Nitro Cell so he stopped publishing that design. The above url was from someone that saved a copy on the web.
                      Maybe Alex found a way to make that Nitro Cell design work, or changed something that allows it to fuel an engine?
                      cheers
                      Mike
                        NO! Nothing to do with Nitro Cell. The reactor that you see on photos is completely different! Nitrogen is extracted directly from air using an special membrane and is needed distilled water with ph <7. Water and molecular nitrogen (and low percentage of natural catalyst) are processed from two initially stages and after sended inside reactor to low pressure. The reactor in real time split the molecules and transform these in hollow atoms, only externally atoms in special chambre are recomposed into new molecules of ammonia and nitrous oxide. I think that help you to understand. Regards
                        You could make some nice money giving on line internet classes about your work and theory.
                        I know time is an issue but.
                          oops, mistaken post
                          • #14
                            Hi Alex,
                            Thank you for the explanation. Your design looks to be completely different from that Oz Nitro cell design.
                            Not many people were able to get that design to work. In fact no one here in USA. Some speculated that it would be due to the water down in Australia.
                            Will the water and the special catalyst need to be replaced after so many years of use as a maintenance operation in your cell design?
                            cheers
                            Mike
                            • #15
                              Im working on that reactor from two years. Now you are able to replicated that with design and plans, all informations are present here. Regards ALex
                              Yes I know, as I have been following your work with great interest over the years. Great to see that you finally succeeded.
                              cheers
                              Mike
