Fuel cell and atomic hydrogen
  • #46
    Tachyon, do you think you could patent this device?
    Do not violate any laws of physics, we do not create energy out of nothing,
    but with a trick amplify the input energy
    • #47
      Will have to test it to make sure it works but I dont see any volunteers will I have to make everything by myself?. We can use 150nm laser and 900nm to cover oxygen nitrogen and hydrogen frequencies.
      Be careful you must not look at high energy uv beam and don't let the uv beam radiate your skin.
      The pure in heart will see the light.
      • #48
        With deuterium can be equally recombination of atoms and then heat, with the atomic oxygen can oxidize the silver, but with the rising nitrogen you can do?
        • #49
          nitrogen needs twice the energy for dissociation , I was saying maybe use nitrogen or carbon to make other chemical formulas in another chamber using other reaction.
          for deuterium we need even lower frequency in the ~80nm and ~480nm
          If we had a bond of a gas with oxygen we could use strong magnetic field and UV to dissociate this bond later with minimal energy.
          • #50
            Tachyon, what would happen if we send in our reactor CO2?
            • #51
              It's possible this:
              • #52
                Ok I made simple drawing.. ring magnets and mirror cylinder..
                • #53
                  Possibly we seperate carbon from oxygen and gain energy from O2 recombination but NEED to test.. CO2 -> C+O+O -> C+O2.
                  • #54
                    interesg thread guys. Franco did you tried that schematic that you've said about hydrogen with laser to heat water?
                    • #55
                      laser is not for heating water tank.. maybe we can try water vapour but there will be some diffusion inside chamber, lasers are 40$ anyone care to make a donation ?
                      • #56
                        for the CO2 you can use the cans for bicycles
                        • #57
                          like this:
                          • #58
                            Tachyon, but if I send Elio4 in the reactor, produce Elio3?
                            • #59
                              do you mean helium-4 , don't know probably not.. :/
                              • #60
                                But helium3 is scarce on earth should be used to clean fusion reactors,
                                certenly not at home...
