Lawton's Waveform Generators
  • Lawton's Waveform Generators
    The dual pulse-width modulator, as shown in the Practical Guide and at Panacea University seems at odds with how a water-fuel cell is envisioned to work by resonation of a signal. Once built and pulsing energy through the water, it looks as though the circuit should be manually adjusted to generate bubbles with the dual 10k and 47k potentiometers, although how one is to figure out the correct frequency and mark-space ratio is less than apparent.
    I guess my question is, will this circuit produce electrolysis whether or not it is tuned to the water cell's resonant frequency?
    The phase-lock loop waveform generator, also by D.Lawton appears to be another standalone circuit capable of producing electrolysis with the bifilar electromagnetic coil, raising a further question - Why would anyone build this one when the previous dual-PWM version works great?
    Perhaps it should be the other way around - Why build one when the other works like a charm?
    How is the experimenter to choose which circuit to build?
    Chapter 10 - free-energy-info.co.uk
    Hi Geotron. I would go here GlobalKast.com : Media : Photo's and scroll to the bottom. There is a great many resources there.
    al
      You have to ask your self, why did Stan Meyer have so many individual circuit modules. Is it realitic to think you can fire so many tubes in resonance without having individual control? Is the frequency desired based on a special frequency pertaining to the covalent bond, or is it matched to the environment, the resonant cavity, as a whole? Interesting circuits.
        Hi Kc. You are looking at many years of circuits and diagrams at one glance. Just as any invention as time passes there are improvements. The inventor kept on working to make them better and better. We see it as a pdf with all of them together. He worked on one learned from it then designed a better one and so on.
        As for the tubes you can expect the coil/cap(cell) to hit resonance just fine as any circuit would provided you did your homework beforehand.
        Why not use that inflow of (non user provided)energy directly instead of using it to make dangerous gas? That is the real question.
        The thing is this technology leads you back towards Bedini and some of the others. You don't need the gas if you can get all the electrical energy you need. The energy comes from the same place anyway. Stan was just converting it into a flammable gas.
        al
