Creating synthetic fuels. MNE-BEAM REACTOR
  • Creating synthetic fuels. MNE-BEAM REACTOR
    Hi All
    I have decided, due to not so good health at the moment, to publish a white paper on the work that I do.
    This is not giving you plans at this time on how to build this system, but in the near future I will publish a full set of working plans, after I have ironed out the full fabrication problems, which always shows up before any type of production.
    This reactor system does work as is, but I wish to have it 100% perfect so as not to have problems with not getting a usage licence, due to whatever the powers that be might find such as RF leakage that would stop the use or fabrication.
    I have safe gaurded all my work so it will not die with me.
    Building of this system maybe beyond many people, but I think that it can be fabricated for a low acceptable price for individual use as well as industrial use.
    Mike
    PS I will be uploading this to my web site in the next few days and I will give a link here when that is done, this is in case the attachment gets deleated.
    I think I have explained how this is done in the simplest terms possible.
    Thankyou
    Thankyou for allowing us to have this information. Hopefully your health will improve.
    George
      Thank You
      Thank you for sharing this material Mike.
      V
      General D.Eisenhower
      http://www.nvtronics.org
        Web site
        The PDF is now loaded onto my web site. The site is still under construction so sorry for the mess at the moment.
        Here is the link
        http://www.centraflow.yolasite.com/
        Mike
          thank you mike good job. I believe that situation will improve
            Updated web site
            I have updated my web site, I will try and keep it up to date as time permits, please look at the ABOUT US page and look at the video.
            Mike
              Mike
              Extracted from NASA to Methane Blast - NASA Science
              "Although Mars is not rich in methane, methane can be manufactured there via the Sabatier process: Mix some carbon dioxide (CO2) with hydrogen (H), then heat the mixture to produce CH4 and H20--methane and water"
              Simply they use microwaves to heat and ionize the mixture at the same time obtaining the final reaction that you can see on video.
              Meyer use same principle but instead of CO2 use air (O2/N2) and brown gas.
                Yes the Sabatier process is a very very old process, the only problem was of the 400c needed to start the reaction. Microwaves is not a good solution on it's own, molecular vibration through other means is which gives the localised heat required along with nickel as the catylist. The MNE-Beam reactor uses RF waves at low frequency which impact one another within the water molecule creating very high heat with the use of low energy. Microwave ovens are not very efficient and for this would be difficult to control.
                Read ALL of my web sight, it has been private for a year and a half, now I am giving information for the benifit of mankind, we all need a boost as things are getting very very bad in this world.
                Mike
                  Mike
                  Mike,
                  I refer microwaves as RF not as microwave oven .. heterodyne can be an way but some ways are availables for obtain right process.
                    Site updated
                    The site has been updated with a block diagram of the methane system and a not to scale drawing of a MNB-BEAM reactor.
                    You may think that there is a lot to the system and it would cost a lot of money, this depends on how you look at it, infact the components such as compressors are small and would run off 12v, The electronics are not complicated but have to be right.
                    The basic design was made for production in down time of an electric generator, so solar could be used, the resulting gas is compressed into tanks for use in on time.
                    Mike
                      Heat
                      Mike,
                      The idea Alex is to create the heat from inside the molecule, not outside. The reactor runs reasonably cool even with a temperature of up to 1000 degrees in the molecules, the heat seems to be absorbed, some in the nickel mesh which has risen up to 60c on a 30min run and remained stable at that.
                      Mike
                      Might be the last post for a few days as I might be in hospital again for tests tomorrow, we will see, as I am feeling much better at the moment.
                        shock diamonds..
                        Mike... No water gas or magic waves.. Over expansion causes shock diamonds to form in the exhaust because the gases are dropping below supersonic and making 'sonic booms' within the exhaust stream. It’s a fine sight, but reduces thrust.
