Your perspective on the material is clearly too narrow and biased for any productive detailed discussion. I will elaborate on that issue however, since you are not alone in your fixation on data sets and other minutia while ignoring the concept itself.
As an analogy I offer the idea of a system claimed to produce water from a 'seed' supply of, let's say 1 cupful. We might allow that the prototype unit delivers some significant amount of water greater than 1 cup after only a few minutes, without having any power or substance added or applied to it. Sounds like a good idea if it were possible, there are a number of countries where such a device would be useful, and the production of abundant fresh clean water starting from a lesser amount might even be thought quite miraculous.
While we may not have a complete data set for the process, if we can show that the unit produces 1 cup of water and in addition some significant amount beyond that, then the unit has achieved 'overunity' in terms of the production of water. This is such a straightforward concept that it should require no explanation or supporting data other than the fact itself, but since some are ill-disposed to anything beyond their expectation and understanding, in similar circumstances objections are often raised and any discussion tends to focus on convention and minutia.
I have data which indicates more mass in motion than could be expected by convention. Mass in motion equates to energy. I have visual confirmation of the phenomena. I have a logical theoretical explanation for the phenomena. All this and more I have made available for scrutiny, and assume that anyone interested in the material should have little trouble replicating my results. Yet for the most part there is silence, aside from an occasional hostile rebuttal bearing the common element of complete ignorance of the significant fact, which is not far removed from the production of something more than a cupful of water in my earlier analogy.
So while I understand that such matters attract a certain amount of uninformed skepticism and even hostility, I would recommend that you study the entire thesis in detail, with an open mind, having particular care to consider honestly those aspects causing you discomfort, else you have no basis either for criticism or complaint.
