Hi miroslav13 thanks for this great video. I have been struggling to build a radially wound armature and you have showed me it is far better to wind a radial half toroid. Thanks
What if the rotating magnet where placed inside the coil?
This might explain how Newmans motor works and why he is shorting the coil after each impulse?
Hello
I have already written to work requires the precise geometry. Figures errors at which the device is not working.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I ask everyone to pay attention to what is written in the claims:
The length of the stator’s magnetic core is equal to the length of stator’s winding so that the extreme points of the magnetic armature coincide with the extreme points of the stator winding, and the length of the winding does not exceed the length of the semicircle, and the central angle formed by the central lines of the different induction rotor poles is equal to the central angle that is formed by the extreme points of the winding.
Sincerely Miroslav
Hi Miroslav,
I got a few Questions about the Design. Does it have any reason, that you used at the outer Side 12 Magnets and 18 Coils or is it only for to drive the Wheel.
That 12 Magnets are the same arranged as the inner Magnets with half Circle S and half N poles?
Would any other Design work too for just driving the Disc?
As you did put your device together, the inner Magnets are actually on the side from the Ring, not inside?
How much layers maximal do you suggest on the inner core? I would usual think, as more layers you make there, as more Energy you can extract from it?
Hello Joit. I do not speak English. I use a translator. Unfortunately distorted sense of long sentences. Repeat questions please just do shorter phrases. Sincerely Miroslav
I'll try to answer. The more turns wound onto the core, the greater the energy output. Where is the magnet from the side, from the coil, or inside, is not affected. All the experiments I did, from what I could find. I hope I understood correctly questions. Sincerely Miroslav
Thanks you very much for showing your motor-generator designs. There is a question; Is there some document describing some additional instructions to build the estator and achieve precise geometry?,,,,Or we just have to fix geometry based on pictures, like in your examples.
Hello Unfortunately, detailed assembly instructions not. We are now at the stage of experimental design work. As soon as the results, I'll show you.
Sincerely Miroslav.
