Channeled Writings from the Archangels & Ascended Masters
  • Archangel Michael for June 2009 - Ronna Herman Pt 1
    Message from Archangel Michael
    June 2009 * LM-6-2009
    "LIVING YOUR PERSONAL REVEALED TRUTHS"
    Transmitted Through Ronna Herman
    Beloved masters, there is a Light Path that will lead you out of the density into the LIGHTNESS OF THE SPIRITUAL REALMS. The key that allows you to traverse this sacred path is within you, and it is called your Energy Signature or your Soul Song. Your vibrational patterns or energetic signature has resonance, cadence, tones and vibrancy, just like a song; and your original Soul Song was in perfect harmony with the Celestial Soul Song of the universe. Each dimension has a unique resonance and an identifiable harmonic sound pattern. Your physical existence is a reality focused on harmony and balance or the lack thereof; and the further you move into density, the more discordant your vibrational patterns become. In your material plane reality you habitually focus on tangible things which have substance or density, a time/space orientation of cause and effect. That each of you is the creator of your own reality is gradually permeating the mass consciousness belief patterns.
    As you refine your resonance, you are gradually becoming multi-dimensional, which means that you are tapping into the frequency patterns of several dimensions at once. In order to make room for the refined frequencies of the multiple levels of the fourth, fifth and higher dimensions, there must be a clearing/cleansing process. Via the lessons and instructions we have given you over the years, we are endeavoring to give you the knowledge and the tools needed to traverse the path of ascension with ease and grace.
    When you achieve a certain level of harmony within, you open the physical body gateways or portals to the higher dimensions: the ascension chakra or medulla oblongata at the base of the skull, the back portal of your Sacred Heart, and the expansion of the opening of the crown chakra. These are major steps in the ascension process, for they re-establishes your connection with the River of Life which contains the Living Light particles of Creation called Adamantine Particles. At that point, you begin to build a force field of full-spectrum Light as you strive to become a master of Self and a conscious cocreator who only creates those things which are for the greatest benefit of all. From that time forward, your breathing exercises and affirmations take on a whole new meaning.
    The basic seven etheric chakras or ‘spinning wheels of electromagnetic energy’ were placed within the physical body as receptacles for the attributes, qualities and virtues of God Consciousness which were radiated forth from the heart center of our Father / Mother God via the universal great Central Sun. As you strive to return to balance and harmony within the four lower bodily systems: physical, mental, emotional and etheric, you will gradually refine your vibrational patterns and begin the process of ascension into the higher frequencies of Light. The chakra system begins to take on the radiance of the five higher Rays of galactic God Consciousness which become available when your Energetic Signature is refined enough to tap into some of the frequency patterns of the fifth and sixth dimensions and eventually higher. The five higher Rays will have a profound effect on the seven chakras of the third- / fourth-dimensional physical vessel. First of all, the reserve supply of Adamantine Particles of Light stored in a sphere of Light within each chakra will be released. The Kundalini or Serpent of Sacred Fire stored at the base of the root chakra begins to rise and the process called Opening the Seven Seals of Higher Consciousness is initiated. The chakras will begin to spin truly instead of out-of-balance, they change colors as they attune to the higher frequencies of God Consciousness, and they become iridescent, for they will be infused with the vibrancy and glowing luminescence of Creator Light.
    The different colored luminescent Rays will assist in integrating and balancing the higher frequency patterns of galactic consciousness. The more you balance, harmonize and strengthen your chakra system, the more Divine Light you can absorb. The Spinal Column will eventually become a Rod of Light through which the Streams of Creator Light can flow freely unimpeded, whereby the process of ascension will be greatly accelerated.
    There are many higher frequency Rays of Divine Light throughout this universe; however, during the present round of experience, humanity has had access to only the twelve major Rays of God Consciousness. That will change as you move into the more refined realms of Light, just as the Divine Blueprint has changed whereby in your future reality all three God Rays will Overlight you in a combination of attributes, qualities and virtues of God Consciousness, and your physical vessels will be programmed to contain a greater number of active chakras and frequency patterns. It is important to understand the physical schematic you were born with; however, it is now time to become aware of what your Divine Blueprint will be in the future instead of what you were in the past. You are evolving, my friends, and you are destined to assume the next level of human expression. We will speak more of this in the future. Suffice it to say, in time, you will be greatly pleased with your new refined and more radiant physical vessel.
    Theta Healing
    Paths 2 Potential
    "We are the one's we've been waiting for"
    • Archangel Michael for June 2009 - Ronna Herman Pt 2
      GUIDELINES TO HELP FREE YOU FROM SELF- IMPOSED LIMITATIONS:
      * FIRST, YOU MUST STRIVE TO BECOME HEART-CENTERED AND SOUL-FOCUSED.
      * AFFIRMATIONS WILL ASSIST YOU IN REPROGRAMMING YOUR SUBCONSCIOUS AND CONSCIOUS MINDS, AND WILL HELP YOU ESTABLISH A NEW SET OF GUIDELINES TO LIVE BY.
      * YOU MUST RETURN TO AN ACCEPTED VIBRATIONAL PATTERN OF POLARITY SO THAT YOU CAN ACCESS THE HIGHEST FOURTH- AND LOWER FIFTH-DIMENSIONAL ENVIRONMENTS.
      * BEFORE YOU ACCEPT ANYTHING AS YOUR TRUTH, YOU MUST DISCERN: WHAT VALUE IS THERE IN THIS INFORMATION? DOES IT RING TRUE WITH MY INNER GUIDANCE?
      * THERE ARE MANY PATHS THAT LEAD TO THE SAME DESTINATION, BACK INTO THE REALMS OF LIGHT FROM WHENCE YOU CAME.
      * DO NOT JUDGE THOSE CONCEPTS THAT DO NOT RESONATE AS YOUR TRUTH. CHOOSE THE PATH THAT IS RIGHT FOR YOU AND ALLOW OTHERS TO DO THE SAME.
      * KNOW THAT YOUR HIGHER SELF WILL MONITOR YOU VIA THAT SMALL VOICE WITHIN: WHEN YOU DO SOMETHING THAT IS NOT IN ALIGNMENT WITH YOUR PHILOSOPHY OF LIFE, YOU WILL FEEL A HEAVINESS OR A SENSE OF DIS-EASE WITHIN THE HEART CENTER / SOLAR PLEXUS AREA.
      * WHEN SOMETHING YOU READ, HEAR OR OBSERVE IS IN ALIGNMENT WITH YOUR SET OF BELIEFS OR PRINCIPLES, YOU WILL FEEL A LIGHTNESS OR EXPANSION WITHIN THE HEART-CENTER OR, PERHAPS, RIPPLES OF ENERGY ON THE SURFACE OF THE SKIN OFTEN CALLED ‘ANGEL BUMPS’ BY OUR MESSENGER.
      * REMEMBER, HOWEVER, THERE IS ONE IMMUTABLE TRUTH THAT YOUR PHILOSOPHY OF LIFE MUST INCLUDE, AND THAT IS THE COMMANDMENT: ‘YOU WILL DO HARM TO NO ONE, INCLUDING YOURSELF.’
      * WHEN TRUE UNIVERSAL LAW FILTERS INTO YOUR CONSCIOUSNESS, IT EVENTUALLY ERASES ALL ERRONEOUS THOUGHT. THROUGH THE PROCESS OF EVOLUTION, HIGHER MORE REFINED CONCEPTS ARE MADE AVAILABLE SO THAT GRADUALLY HUMANITY WILL REVERT BACK TO IMMUTABLE UNIVERSAL LAW / TRUTH.
      * FOR THREE MILLION YEARS HUMANKIND HAS BEEN LIVING IN THE SHADOWLANDS. VERY FEW SOULS HAVE BEEN PRIVILEGED TO HAVE ACCESS TO THE WISDOM TEACHINGS OF ASCENSION THAT ARE AVAILABLE TO YOU TODAY.
      * WHAT GOOD IS INFORMATION WHEN YOU DO NOT USE THE KNOWLEDGE TO GAIN THE WISDOM? YOU MUST DRAW FORTH MORE GOD PARTICLES OF CREATION TO ASSIST YOU IN YOUR ADVANCEMENT ON THE SPIRAL OF ASCENSION. YOU MUST THEN SHARE YOUR NEWLY ACQUIRED WISDOM WITH OTHERS IN ORDER TO PROCEED TO THE NEXT LEVEL OF EN-LIGHTEN-MENT.
      * IF YOU DO NOT CONSCIOUSLY ALLOW A PORTION OF YOUR ADAMANTINE PARTICLES TO FLOW FORTH FROM YOUR HEART CENTER OUT INTO THE WORLD, AFTER THEY HAVE BEEN ACTIVATED BY YOUR UNCONDITIONAL LOVE, THE FLOW OF GOD PARTICLES TO YOU WILL SLOWLY DIMINISH.
      * AS A STARSEED ON THE PATH OF ASCENSION, YOU ARE SEEKING SELF-MASTERY AND MUST LEARN TO TAKE BACK YOUR SPIRITUAL POWER VIA THE FIRST RAY OF DIVINE WILL / POWER.
      GUIDELINES TO HELP YOU DEVELOP SPIRITUAL DISCIPLINE:
      LEARN THAT IT IS WISE TO SOMETIMES DELAY GRATIFICATION
      * PRACTICE ACCEPTANCE OF RESPONSIBILITY
      * DEDICATION TO THE TRUTH * BE REALISTIC
      * ALWAYS STRIVE TO MAINTAIN BALANCE IN ALL THINGS
      * IF YOU ARE NOT DISCIPLINED AND IN CONTROL OF YOUR LIFE, YOUR LIFE WILL CONTROL YOU
      * IF LIFE BECOMES TOO EASY, INERTIA SETS IN AND YOU WILL BECOME NON-PRODUCTIVE.
      * LIFE SHOULD BE A CHALLENGE, ALWAYS UNFOLDING AS YOU SEEK TO IMPROVE SELF * BECOME A PROBLEM SOLVER BY FACING YOUR CHALLENGES DIRECTLY
      * DEVELOP A WIN-WIN PHILOSOPHY, INSTEAD OF THE WINNER - LOSER CONCEPT OF THE THIRD-DIMENSIONAL REALITY.
      Remember, beloveds, as has been stated many times before, it is not power that corrupts but the misuse of power. Acquiring power and wealth tests your inner strength and your spiritual maturity. It magnifies the positive or negative qualities that you already have. If you are functioning from greed, selfishness and an "I, ME, MY" point of view, it will reveal and expand those traits. If you are spiritually centered in a "WE, OUR, UNITY" state of Being, your virtues and positive attributes will be magnified and expanded. The wise ones do not struggle or focus on money alone; neither do they see poverty as a virtue. They begin by turning inward and focusing on magnifying their inner resources, gaining wisdom so they can be good stewards of universal abundance of all kinds. You are of no value to yourself and you cannot truly be empowered and of service to others if you are functioning from a poverty consciousness. You must be an example for those around you as you learn to live and express your own revealed truths.
      In closing, we would like to clarify an old concept which has puzzled many students who have been led to study the wisdom teachings of the past. In the occult wisdom teachings of the 1900's, The Great White Brotherhood was often mentioned. It was not intended that the term White Brotherhood was to define a color or race, but was a reference to the Light of God which is expressed as being crystalline white. Nor was it meant to infer that it was exclusively a masculine group, for there were/are many female masters who have always served in high-level positions in what has been called the Spiritual Hierarchy or the Cosmic Board.
      The members of the ancient, cosmic Great White Brotherhood are a part of the Order of Melchizedek and consist of numerous ascended masters of the Earth, both male and female, as well as highly evolved, non-physical Spiritual Beings from all areas of this universe. In the past, they assisted humanity from within the various retreats and ashrams which were strategically placed around the world. These exalted Beings now reside in the various Celestial Cities of Light around the world. Those of you who are actively on the ascension path and have integrated a measure of fifth-dimensional frequencies within your physical vessel may now make nightly sojourns in your etheric body to the classrooms within the Light Cities in order to accelerate the ascension process.
      It is to be known that, henceforth, this prestigious group will be called THE COSMIC COUNCIL OF LIGHT to reflect the evolving universal consciousness. Whether you accept it as your truth or not, beloveds, you are becoming galactic citizens and one of the future steps of en-LIGHTEN-ment will be the reunion with many members of your solar and galactic family of Light. At a future time, be assured that some of you will be asked to join the Council of Light as representatives of ascending humanity and the Earth.
      My faithful warriors, you are awakening from a twilight dream-state whereby for many aeons of time you have existed on a starvation diet of half-spectrum Light. Open your hearts and your minds, and expand your vision to incorporate your full endowment of the virtues, attributes and qualities of God-Consciousness. It is our great pleasure to assist, inspire and protect you on your journey back into the realms of Light. Know that you are loved most profoundly,
      Transmitted through Ronna Herman * Copy freely and share. However, I claim the universal copyright for this article in the name of Archangel Michael. WE OFFER ARCHANGEL MICHAEL’S MESSAGES ON OUR WEBSITE AS A GIFT; HOWEVER, WE DO APPRECIATE YOUR DONATIONS TO HELP DEFRAY OPERATING EXPENSES AND POSTAGE FEES FOR THE FREE LOVE PACKETS WE SEND AROUND THE WORLD.
      Love, Light & Blessings
      Sharyn
      Theta Healing
      Paths 2 Potential
      • Golden Rule
        Thanks Sharyn,
        Love your friend as yourself is in there...
        A good precept for higher love. To summ a rise
        According to Christ... 1. Love God.
        2. Love your neighbor as yourself.
        On these are all the laws!
        Acts 1:8
        • Important! - Get Ready for the July 7th Energies
          July 5, 2009
          Sananda: Connect With Nature, Practice Feeling Joy and Gratitude
          Beloved Lightworkers,
          This day I wish to speak with you about the energies of the next few days. During the Lunar Eclipse on July 7th, there will be a Cosmic opening, a Cosmic download of the highest frequency energies that have ever rained down upon the Earth and all upon Her, and it behooves each and every one to prepare themselves by raising their frequency levels to the highest they could possibly go each day. These downloads are available for the asking, Dear Ones, so if you wish to be further activated with further Light codes and Light packages and DNA upgrades, then ask and you shall receive.
          The Lunar Eclipse occurs on July 7th but the energies have already started to make their presence known within many of you. This will be a very intense time within the next two weeks or so. It is an opportune time to ensure that you are connected with Nature, that you are outdoors as much as possible, sitting next to the tree family. for the tree family is able to remove energies that need to be cleared, in a harmonious and balanced manner, and they impart, in turn, these balanced energies to their Human counterparts.
          It is an exciting time to be alive upon the Earth in a physical body, but also a very challenging time, so we encourage, Beloved Lightworkers, that you are kind and good to yourselves, and each other. Try to cultivate feelings of joy and gratitude as much as possible, for in these energies you will receive one hundred percent of all the downloads that are being offered at this time, and rest assured, Dear Ones, that you will receive only that which you can safely integrate and assimilate at any given time. Do remember to ask each day for your downloads and these shall be given to you incrementally in order to facilitate grace and ease as much as possible.
          To make the most of this opportune time in this next two week period until the Solar Eclipse closes this Cosmic Door, it is only important that you INTEND to receive and benefit from these energies and it shall be given unto you, but, you must have that intent. Going within, becoming still, is another very important way that will allow you to assimilate and integrate these New energies. These energies will stimulate remembrance within many of you. Be diligent with your daily hygiene, cleanse yourselves within and without. Drink pure water, at least two liters every day and sometimes you will require even more, as you are processing these energies. Eat the purest food that you are able to obtain and prepare for yourselves, for this facilitates the integration of these energies in a more graceful manner, with ease and comfort.
          Feel a Golden Christ Light, a sphere of it, in your heart chakras, and visualize this as much as possible and know that as you do this, you are anchoring the Christ Consciousness within your hearts and this Consciousness will grow and expand. Many of you are already walking in Christ Consciousness in your hearts. Many of you have already purified your minds and bodies, motivations and intentions. Many of you are ready for the next step, the next phase and this next phase will soon become apparent, not just for Lightworkers, but for all of Humanity. The time of The Great Awakening is at hand.
          Be at peace, Dear Ones. Practice stillness and centeredness within your Beings. Know that each of you are Loved beyond measure.
          I AM Sananda
          ©2009 Marlene Swetlishoff
          This Message may be shared with others provided that Scribe's name, copyright, and this link, WELCOME! is included.
          Sharyn
          Theta Healing
          Paths 2 Potential
          • Archangel Michael thru Celia Fenn - July 2009 Pt1
            REBIRTHING INTO THE DIAMOND LIGHT
            Archangel Michael through Celia Fenn
            Beloved Lightworkers, the month of July will be one filled with the energies of Change and Transformation. The Diamond Light continues to bring illumination and awakening to the Planet, and at the same time, there are new Light Codes for the evolution of the Planet that will be activated in the Collective Consciousness at the Full Moon and Lunar Eclipse on the 7th of July, and the New Moon and Solar Eclipse on the 22nd of July as well as the Lion's Gate which opens on the 23rd of July.
            It will indeed be a powerful time, and one in which you will need to hold the Diamond Light in your Heart and hold your energy in Peace and Calm as the changes occur and the New Earth energy facilitates the disintegration of the old energy and the birthing of the New Earth. In this process, you will find that your own inner energies are in the process of rebirthing in order to be able to take form in the higher frequencies of the New Earth. This Rebirthing process will affect the energies of the lower chakras, as the Diamond Light frequecies are activated within the three lower chakras to allow for the radiance and clarity of Cosmic Consciousness to become part of Material Reality in the New Earth.
            So it is, Beloved Lightworkers, that at the Full Moon and Lunar Eclipse, the Masculine energies of Planet Earth will be rebirthed into the Higher Frequencies of the Light. The Collective Consciousness will embrace the more gentle and Ascended and Christed Masculine energies. This will be facilitated by the Lunar Code activations of the Full Moon and Eclipse in Capricorn, assisted by the powerful transformative energy of Pluto in Capricorn. The "Lunar Codes" for the Masculine energy that have been absent from Earth Reality for so long will be fully restored and activated at the New Cosmic Christ level.
            At this time, the Divine Masculine energy within the Collective Consciousness will begin to express into form, through Co-Creation, the ascended energies of Unconditional Love, Sharing and Empowerment for All. This shift within the Collective will raise to the surface much anxiety and stress, as the old is released and the new takes form. These energies will create an opportunity for the release of old patterns and the embracing of new patterns of being and relationship.
            These new Light Code Activations will affect the lower three chakras, and there will be a releasing of old energy and an alignment with the Diamond Light energies that are held within the Diamond of the Heart and are radiated into the lower Chakras to "tune" the frequencies of these chakras to the new Diamond Light frequencies.
            These shifts may be felt on the physical level as vibrations and pains within the lower part of the body as the incoming energies restructures and realigns the lower chakras. Other feelingts may be hyperactivity or extreme fatigue as the chakras recalibrate their frequencies. There may be extreme mood shifts and emotions as the emotional cleansing and realignment occurs, and some of you may feel very tearful with the desire to cry for no reason as you release old sadness and move into the new joy. On the mental level, there may be extreme anxiety as old patterns of fear are release and replaced with new patterns of Love and Sharing.
            At this time, Beloved Ones, you may also experience the closing and completion of many relationships as the ole energy patterns of relationship are replaced with the new Ascended Energy of the Sacred Heart as the basis for relating and relationship.
            This will mean, dearest Lightworkers, that the old energies around Money, Sexuality and Power will be replaced with the new higher energies that you have held for the Collective. In place of the distorted energies of Greed and Fear around Money, the new energies will introduce the higher frequencies of Abundance, sharing and Enough for All. The Ascended Human Angel will be quietly confident that he or she will alwasy be able to manifest exactly what is needed to provide for life, and that he or she will always have enough to share with others who may not as yet perfected the skills of manifestation in this time of transformation and change. These energies will be introduced by a realignment of the Base Chakra energies.
            The new energy around Sexuality will replace the distorted energies of ownership and control through manipulation of the creative and reproductive energies. As the Sacral chakra aligns with the Diamond Light from the Sacred Heart, the new energies will create Sacred Relationships in which every relationship will be held sacred and will be a reflection of the Divine Union of energies. At the heart of Relationship will be the energies of Unconditional Love, Acceptance and Commitment. Each Relationship will have a focus of energy and that will be the focus of the Sacred Commitment within the Relationship. The energy of Creativity that is the purpose of the Sacral Chakra will be used within Sacred Relationships to manifest the energies of the Sacred in the New Earth. And, because you are now Co-Creators on the Planet, each of you will decide within your Relationships what is the Sacred purpose and focus of your partnerships and how you will express this in alignment with the Mastery of your Diamond Light energy.
            The old energy of Power as a means of control and manipulation will be replaced at the Solar Plexus Chakra by the new ascended Christ energy of Personal Empowerment and the ability to hold the energy of Unconditional Love in the Heart at all times. The frequency of Love transmitted through the Diamond of the Heart will manifest as the ability to flow your personal energy in any situation without needing to exert control and domination. The Flow of Unconditional Love ensures that each being is able to express their needs and desires without fear and to have those needs met in love by those with whom he or she connects. The essence of the New Earth is negotiation and co-operation as a way of manifesting for the highest good at all times. Beloved Ones, you will learn the skills of working together as groups to ensure that everyone is able to manifest what they need and desire at all times, and that you can support the process of manifestation, not just for yourself, but for others as well. In this case, learning how to create Harmony through Oneness will be the essential skill that will bring the energy of the Solar Plexus into alignment with the Diamond Light of the Heart.
            So, Beloved Ones, on the 22nd of July, the New Moon will be in Cancer and there will be a Solar Eclipse which will also activate New Solar Light Codes. These will be the Activations for the Solar Feminine energies, the Ascended Feminine Christ energis that are being encoded into the Diamond Heart of the Planet and into the Diamond Heart of each Awakened and Ascended Human Angel on the Earth at this time.
            At this time, the old "victim" energies of the Feminine in the old energies will be replaced in the Collective Consciousness with the Ascended energy of Empowerment and Creation with Spirit. The New Human Angel will be open to Receiving with Grace and Gratitude the Abundance that is offered by the Cosmic River of Life. The Base Chakra will be realigned from the lack and poverty of the old consciousness and will be set at the frequency of Acceptance and Gratitude, within the knowledge that Abundance is always present and that lack is an illusion. On the level of the Sacral Chakra and the Sexual and Creative energy, the New Code will allow the Feminine energy to be empowered to express Passion and Creativity and to receive these energies from others with Grace and Gratitude. At the level of the Solar Plexus Chakra, the new Light Codes will allow the Feminine energy to express its power and empowerment through the energies of Equality and Sharing. Giving and Receiving will be held in balance at this point, and the new Light Codes will enable the Human Angel to ensure that he or she Receives and Gives in a balanced and loving way that honors the essence of each individual within the group or community.
            Within the Collective Consciousness, Beloved Ones, the old energies of Polarity and Duality will be replaced by the Yin and Yang of Complementarity and Co-Creation.
            And then, on the 23rd of July, when the Sun moves into Leo, the "Lion's Gate" will open to bring through the new Evolutionary Codes for the New Earth from the Cosmic Portals of Sirius, Alcyon and Arcturius, and to bring new codes to the Heart of Humanity from the Galactic Center and the Andromedan Consciousness. As the New Earth manifests, the Stellar, Galactic and Cosmic Codes for Light Frequency Evolution will also be encoded into the Human Collective Consciousness through the Diamond Light Frequencies. At this time, those of you who are fully Awakened to your Cosmic Consciousness will begin the process of integrating your Stellar and Cosmic Codes and co-creating with the Galactic and Stellar Consciousnes. Initially, this will be through the Dream states, and many of you will be called to meeting and councils in your dream states to share in the new Galactic Council that includes the New Earth and her Ascended population. But, as the Cosmic energy becomes stronger, you will be empowered to participate in Galactic Council gatherings in more conscious ways.
            So, Beloved Lightworkers, you can perceive that the energies of the New are very strong right now, and that the old ways of being and perceiving with their third dimensional limitations will not serve you now. It is indeed time to fully embrace your multi-dimensional self and to move into the new consciousness and the new reality as it is birthed in you through the Language of the Cosmic Soul, which is Light and Sound and Patterns of Consciousness.
            Theta Healing
            Paths 2 Potential
            • Archangel Michael thru Celia Fenn - July 2009 Pt2
              The Diamond Light Children : Supporting the New Consciousness
              At this time, this powerful changing of Light Codes and consciousness is being supported by the arrival of the Diamond Light children on the Planet. These are the Cosmic Master souls who have been incarnating on the Earth in this year of 2009. As more of them arrive, they are facilitating transformation and change, and mnay of the Crystal Children are "upgrading" their consciousness so as to be able to enter into the Diamond Light energy of Full Cosmic Consciousness. Their support is enabling the rest of the Human Collective to make similar shifts into Cosmic Consciousness and fully align with the Diamond Light.
              And so, at this time, the Human Collective is living within two simaltaneous realities. The Old Reality with its old energies is disintegrating and falling away. The old Light Codes and Energy patterns are becoming increasingly worthless as ways of Being on the Planet. This gives rise to deep anxiety and panic in many, and an increasing fear of disasters and catastrophes. This energy is perhaps necessary as a means by which the Collective can express the transformation and work through the fears and anxieties that arise. Many are replaying old survival fears and anxieties around the endings of Lemuria and Atlantis. But, at the same time, the New Dream and the New Earth are being birthed into the Collective Conscious and into each awakened Human Angel, so that the New Reality can manifest and take form. Beloved Ones, each of you has now to choose which Reality you will inhabit, according to your ability to be conscious and awake and to engage your Creative energy and work with Spirit. The Diamond Children are here to welcome you into the New Reality.
              Beloved Ones, many of you ask how you will know when you have achieved the New Consciousness. How will you know when you have opened to the full energy of the Fifth Dimensional New Earth. Well, we would say that firstly, you will become aware of your inner Divinity and your Cosmic Consciousness. You will feel the "I AM" energy of Soul and Spirit that lives in the Diamond within the Heart. Secondly, you will haev absolute trust in your ability to Co-create and Manifest with Spirit and to provide all that you need on Earth within your Reality and to live in comfort and abundance. Thirdly, you will have entered into an awareness of the Infinite nature of Time and Space. You will live fully in the Present Moment, knowing that past and future are illusions, and that Now is the only Reality. You will have no fear of death as you will feel absolute confidence to face all the transitions and transformations in your existence with grace and peace. And, lastly, you will feel yourself to be a Master of your own destiny, knowing that you create your own Reality at all times. Andf you will know that if you do not feel comfortable within a creation, that you can change it at any time and create another Reality.
              Indeed, Beloved Ones, we can only say " "Welcome to the New Earth!"
              The Energies for July 2009
              On the 7th of July, the Full Moon will be in Capricorn with the Sun in Cancer. There will also be a Lunar Eclipse for the Activation of the New Lunar Masculine Light Codes. The energy of Cancer and Capricorn emphasizes the energy of the Mother and the Father, or the Divine Masculine and Feminine energies. It is a time to celebrate the emergence and rebirth of the Ascended Masculine energies of the Christ. On the 22nd of July there will be a Solar Eclipse in Cancer, in which the Solar Feminine Codes of the Empowered Feminine Christ energies will be encoded into the Collective Consciousness. The Lunar Goddess will assist in the rebirthing of the Full Solar Consciousness of the Fire or Solar Goddesses, which will be expressed more fully in August when there will be a Lunar Eclipse in Leo and Aquarius on the 6th of August at the Full Moon in the middle of the Lion's Gate period. This will be another powerful nexus of Cosmic energies and Light Code Activations.
              On the 23rd of July the Sun moves into Leo, and the Lion's Gate portal for 2009 opens. The Cosmic energies for the Evolution of Divine Consciousness for the next annual cycle will begin to be received by those on the Earth!
              And so, we wish you a journey filled with Light, Love and Laughter in July of 2009!
              © 2009-10 Celia Fenn and Starchild Global
              This work is licensed under a Creative Commons License.
              www.starchildglobal.com
              Sharyn
              Theta Healing
              Paths 2 Potential
              • Steve Rother & the group - July 15th 2009 Pt 1
                ~ Re-minders from Home ~
                From Steve:
                Steve Rother
                In this message the group covers two important but what may seem to be unrelated topics. It’s always my job at the end to put a label on the message that can describe it to all of you. That is difficult in this case as the topics they covered were varied but in the end you can see how they are closely related.
                One of the items they talked about was the economy. They said that all of the air was not yet out of the bag, and until it was a solid foundation could not be made to build lasting growth. They made a point to say that our economic systems were based solely on perception. They actually say these systems are based on perception of perception. The group needed to make this point in order for the next part of this message to be understood. They said we are at a crossroads right now and in the immediate future.
                Since 1998 when they first channeled about the Crystal Children, they said when the Crystal Children begin to enter there will be NO MORE SECRETS. That we are seeing today. That is what is happening in Iran and many other places on Earth at this moment.
                The group said a critical mass is about to be reached in the US when many of these secrets from many different sources will be revealed. When that happens, how we deal with it and how we perceive it will determine the future of our economies over the next ten years. The next ten years will determine the direction our economies over the next one hundred years. If there is transparency and honesty as these truths are revealed it can be a positive perception. Even though the initial reaction will most likely be anger and mistrust, the global perception can be positive overall as a clearing of something that once revealed can never happen again. If there are attempts to hide or manipulate this coming wave of raw truth, mistrust will reign and the rest of the air will come out of the bag in our economies. It is our choice and we can all have an active role in what is coming. For examples of how to make a difference and make your voice heard, we need only look to the brave souls in Iran.
                The second important point they covered was the Pineal Crystals forming in humans as part of the re-wire process and what that can mean to all of us. The group has been talking for years about humans becoming crystalline, and this is the first solid evidence that it is happening in humans. In fact, medical science has even coined a word for it now: “Biomineralization.” Now that you all have an image of rock people walking around, let me say that the group explains that once activated this can be a physical step toward what can result in new forms of telepathic communication, time travel, multidimensional awareness and controlling the physical ageing process. Basically, it is the next step in our evolution. Ready?
                I guess that in a way these two topics are related, because if the Pineal Crystals are activated it will no longer be possible to keep secrets in the first place.
                Big hugs and have a great July!
                Theta Healing
                Paths 2 Potential
                • Steve Rother & the group - July 15th 2009 Pt 2
                  Greetings from Home
                  There is much to cover. We will give somewhat of a diverse message this day, because so much is happening on planet Earth. It is a magical time for humans, for you awaken from the dream not only as an individual, but as a race of spirits pretending to wear a physical bubble of biology. What is taking place is that all humans everywhere are raising their vibrations. Yes, you look around and see the low vibrations on the planet and it is often these lower vibrations that make the headlines. We have told you that your human advancement is limited by the lowest vibration on your planet. Even so, you are not restricted by that. Because as you raise the collective vibration within that segment of that vibrational range, when you reach a new level, you pull the lowest level up automatically. Do not concern yourself with going out and saving the world or changing an individual person. Look at yourself and focus within. Look at what you can do to activate that light in your eyes. Do what you can to find a purpose within your heart that you can stay with, and that you can move toward. Now more than ever before, that is becoming critical on this planet.
                  Most of you have time-activated contracts and you had to be here at a very specific time, in order to do the work that your soul and your spirit really wanted you to do. The good news is you made it. Now let us get on with it, and start owning who you are. Let us help reflect your energy, so that you may re-member who you really are. The physical body is in a state of change and it is happening now in many different ways. The physical re-wire on this planet has already begun in many people and you are starting to be activated in ways which you are not yet aware. There are levels of your own dimensions that have been separated for eons of time. As you re-wire, all these divisions of separation start to go away and that is why we are telling you that each one of you are starting to become consciously multidimensional. You are starting to realize that you are not the only person in there. There are 11 different dimensions of time and space that you exist in. Those dimensions are starting to come together very quietly as the divisional markers between each one of those levels are starting to disintegrate. As the re-wire continues your own physical body will begin to perceive things through your own eyes, ears, nose and mouth that you never have before.
                  Pineal Crystals
                  There are events taking place right now as the physical body re-wires, especially in the brain. The physical body is evolving and one of those changes is taking place in the pineal gland, although is not limited to that one location. Crystals are forming in the pineal gland; these are crystalline structures that you call calcite crystals which are forming in the brains of humans everywhere. These crystals can be tuned to receive electromagnetic frequencies. You have communicated with each other through electromagnetic frequencies (radio waves) that travel through your body. Without even hampering you many electromagnetic frequencies are running through all of your physical bodies right now, yet you are unaware of them. That will now change. In the beginning, you may become hyper-aware which can also be problematic. The idea is to bring it into your comfort zone to activate yourself. This is not a race, dear ones. Please take your time and do not push your bodies too fast because they can only take so much. Yet you will do it, and do it well.
                  The crystals that have formed in your brain have been there for some time. The reality is that you started a second wave of empowerment about 60 years ago, and at the same time these crystals started to form. These crystals have been lying dormant in your body waiting to be activated. Medical science is now starting to see them and you can actually look at pictures of these crystals forming in the pineal gland. They are problematic according to medical science, because they are causing difficulties and challenges with the human physiological structure. You believe that it is something that you have done wrong. We tell you it is a natural part of your evolution and incredibly exciting, because now you can see. You have talked about internal communication and telepathy, you have even practiced it. Even though most know it to be real, it has always been just out of reach for most but no longer. How can you activate the crystals and use them to your highest purpose? And more importantly, how do you tune it to just one station at a time? That is the challenge that many of you will start working with as you activate these crystals. Crystals are living; the Earth is living. She is a sentient being, very conscious. And if crystals are the highest vibrational level of the mineral kingdom, you could easily say that in planet Earth the crystals are the brain. In fact, the crystals are the pineal gland of planet Earth. The crystals that you are most familiar with are the highest vibrational level of the mineral kingdom. It is the reason many of you talk to crystals, receive messages from crystals, or hold records within crystals. You have the highest vibrational range of the animal kingdom the same way crystals have the highest of the mineral kingdom.
                  Humans are becoming Crystal
                  You have heard about the Crystal Children and the Indigo Children that come in with telepathic communications already built in. They do not know how to use it, but they have an internal communication that with a little bit of work they can fine-tune and use. You have that, too. That is the formation of these crystals. Learning to use these crystals and how to adaptsto them will have a very interesting effect on humanity. We tell you, it is not just the human kingdom we are talking about because if you look at the cellular structure of plant life, you will see that more and more of plant life is becoming crystalline in nature. You are starting to see plants and animals take on characteristics of crystalline energy that has never happened before on this planet. This is part of your natural evolution; you are becoming crystal.
                  It is not a difficult shift. If you would see one of your periodic charts, you would know that the carbon-based structures you currently have and the silicon structure are actually only a few molecules away. With a few re-arrangements, you have a shift from one to another. That is happening not only throughout all of Earth, but also the plant , insect and animal kingdoms are taking on crystalline structures. The interesting part is that there will come a time when you will not need the physical crystals and they will start dissolving. These are temporary situations for you, but you are right at the point where they are beginning to form.
                  There have been calcium deposits on the pineal glands of most humans. You have a lot of reasons for these deposits. Your science believes it has to do with fluoride in your water. At the beginning of cell phone use on your planet, there was evidence of tumors forming and a lot of discussion. We tell you that was very real, yet it never really materialized to become the big problem that was expected. It was the pineal gland that was vulnerable to a new frequency being held too close, but that has already changed. Because of the mass appeal of cell phones, the human body adapted and learned to tune out that singular frequency. You are starting to adapt in many ways. That adaptation was out of survival and at an unconscious level. Now you will learn to tune it in a conscious level. You will be able to communicate not only with yourselves, but with the rest of Earth. You will be able to have conversations through a crystal. There are many ways that you are going to start to activate this, but the physical evidence is now showing up on this planet. This is happening with throughout all of humanity, with old and young alike.
                  Theta Healing
                  Paths 2 Potential
                  • Steve Rother & the group - July 15th 2009 Pt 3
                    Perception and Economics
                    Let us take a moment and address another important situation, your economic structures on this planet. You have all gone through major changes in the last few months with the economies of planet Earth. You have been expecting this and have known about it for some time. You have talked about new structures, new formations and new ways you would deal with money—new, exciting ideas. It is happening and now the opportunity is opening up. From our perspective, many economies on Earth looked like a bag full of hot air. Being full of hot air made the bags appear much larger than they actually were. The largest of these bags was the economic system in the United States, where what took place was some of that air leaked out of that bag. That was really wonderful because what you are seeing is the possibility to build on a more stable foundation. Even with the cushion gone, there is some air still in the bag. There is an event coming very soon, so let us speak to you about that and how it will impact your economic structures. What we tell you is that your economic structures are based on perception only. There is little basis of fact in most of your economic structures. There is nothing wrong with that, for it was the way you chose to play the game. When the Keeper first started receiving information from us he said, “I have these beings on my shoulder who can see everything. I’m going to ask them about the stock market.” We laughed hysterically. We thought it hilarious that he would ask us about the stock market, because the stock market is a human game made inside of another game inside of another game, based on perception of perception of perception and you want us to tell you where it is going? We thought that was quite funny. It is a game of your own creation and that is how you play it. It could only be predicted by the creators of the game, and you are not doing really well with that. You can play that game on the vibrational level but nobody else can. So let us speak to you about this, because it is an important piece.
                    NO MORE SECRETS
                    All economies are based on perception and you are about to pull away part of the veil and see things that you have never seen before. It will happen in many different areas. You will find out things about the event that you call 9-11. You will find out many of the hidden structures that have been on this planet. The veil is being pulled away, so there will be no more secrets on planet Earth. It is that simple. Even though many of your leaders do not know that yet, they are finding out very quickly for it is not possible to be totally out of integrity and be in front of telepathic beings on planet Earth. That is what many of your governments are finding out. This very day it is seen in the country of Iran. They are finding out that all eyes are upon them and, therefore, change must happen or they will disintegrate. It is that simple. It may take time, but that is the process that is happening. It is the part that you have created to be able to communicate through your telephones, televisions, Internet and through all the other parts of it. You are connecting hearts and now you will be able to do it through the pineal gland as well. As this evolves you will not need the technology. With practice you will be able to release some of the outside pieces and do it all internally.
                    There is an event coming on planet Earth that will be of great proportions. All the truth must come out, so it will be an unveiling of sorts. You will see and feel the truth even if no one admits to it. Humans everywhere are starting to see truth in themselves. As a result of many lies and misdirections of energy much has happened that was not public knowledge. These are the areas that will now come into the light. You will start to perceive and everyone will know very quickly what took place and what happened. How that is perceived by the world at large will determine the immediate future of the economy, beginning first in the United States and quickly spreading to the rest of the world. Not only are your hearts permanently stitched together because you are actually one person, but your economies are stitched together too and that is very healthy.
                    The End of Separation
                    You are beginning to see that no one is ever alone. No one can segregate themselves completely, and these illusions of separation have been quietly undermining and killing humanity. Now is the time to press the re-set button. Search for ways that you are like each other, rather than look for the ways you are different. You can then see others on the same path that you can reach out a hand and say, “Come. We found a door. Let us go through this together.” That is what is taking place on planet Earth, right now.
                    This is going to activate soon as we see it, for a critical mass is being reached in the area of truth. The people demand that the truth to be told. The final outcome will not matter much, as it will be the perception of this event that will determine the future of your economy for the next ten years. When you look back at your history, you will see major changes in every one of you right now.
                    You will also start to become more multidimensional as these crystals activate, because they do not exist in one dimension alone. They are multidimensional in nature as all crystals are. As you start using this more, you will become more comfortable and more powerful with it. You will be able to use it consciously and that will give you a sense of security, a feeling of never being alone on this planet. That will give you more confidence in a spirit walking around pretending to be a human than you have ever had before. You are now starting to carry more of your spirit in your physical body than was ever thought possible when you developed these physical forms. It is happening; you are adapting it. That is what is taking place and this is a time for adaptation, a time to roll with the punches. This is a time to find the light even in the darkness. It is the time to reach out to find that light and passion within. Moving even the slightest bit in that direction will change your lives overnight.
                    We watch some of the struggles. We feel your pain, your loneliness. We feel your energy sometimes when you cannot find a complementary vibration to validate your own vibration. We know you feel very alone, but you could not be alone if you tried. We will come down and tickle your funny bone just to remind you we are here, because we love you more than you will ever know. You are changing the course of the universe. You are evolving god, and we are so very proud to watch the humans of planet Earth as they become godlike. Your energy fields will change. Most of you are healers or teachers in some fashion. Therefore, when you find something that works for you, turn around and share it. Figure out a way to show it to someone else. Move that energy through, because you are opening doors for all of humanity to follow.
                    It’s Up to You
                    Please do not get wrapped up in the dramas or the fears, because there will be many. Much was hidden on planet Earth. Many of the conspiracies that some people thought were true, might turn out to be true. The challenge here is to see things the way they really are rather than get wrapped into the drama. It will be difficult to trust leaders of any kind immediately after that happens. We tell you, that is perfect because leaders are not going to change your lives. You are. You are the only ones that can take responsibility for that, and that is what you are about to find out. Each of you has an opportunity to determine your own fate as these energies move. You can be anywhere you want, and you can change it any time you want. All you need to know is that you actually have the choice and it is on a conscious level.
                    Dear ones, your energy has grown so rapidly. You are so incredibly beautiful. You carry that light within your being and letting it come through puts an energy on the light from Home which gives it the most beautiful, human flavor. It is magical and we celebrate you all the time. We will celebrate you Home, when you decide to return Home. Many will choose that, as the times ahead will be very stressful. Some will simply say, “I need to go Home.” There is no right or wrong about going Home. It is absolutely the most beautiful, human experience you will ever have. Returning Home is the greatest peace. All of you can do that without leaving your physical bodies now, for that is what is directly ahead. Enjoy this ride and hang on, because it is going to be quite a ride.
                    It is with the greatest of honor that we ask you to treat each other with respect. Nurture one another at every opportunity and re-member it is a game. Play well together.
                    Espavo
                    The group
                    www.lightworker.org
                    Sharyn
                    Theta Healing
                    Paths 2 Potential
                    • Technology Download ~ A Cosmic Event
                      Hello Sharyn
                      Do you know anything about the so called Technology Download ?
                      Here is an article about it:
                      Technology Download ~ A Cosmic Event > Lightworker
                      Do you think it is real?
                      If it is i will have to stay awake and see if i can come up with some new invention
                      Marcoz.
                      • Originally posted by Marcoz View Post
                        Hello Sharyn
                        I don't know anything about this event, but I would say it is quite possible, after I have been reading the books of David Wilcock lately. He has done a really good job in connecting all the dots from "sacret geometry", harmonics, etc. up to the channeled material by Seth and Ra.
                        Shift of the Ages
                        Shift of the Ages by David Wilcock
                        Science of One
                        Science of Oneness - businessbranding
                        The Divine Cosmos
                        The Divine Cosmos by David Wilcock
                        I have read the Divine Cosmos, and am currently reading the Shift of the Ages. Really awesome books that challenge the technology-download-capacity of your brain
                        • Thanks so much for posting the links to David Wilcock's books! He is one person who I think is truly gifted and most of what he writes resonates with me.
                          I did not know that those books were available online to be read at any time so I really appreciate the links. I am reading The Divine Cosmos first.
                          Namaste,
                          Pamela
                          Discover the Single Greatest Health Science Breakthrough of the Century
                          • Your Light Is Needed NOW!
                            Thought to share this message which highly resonated with me:
                            by Patricia Diane Cota-Robles
                            Era of Peace
                            It is difficult to fathom with our finite minds the magnitude of the opportunity that is being presented to Humanity at this time. This summer we have experienced several events that have resulted in the greatest influx of Light the Earth has ever been able to withstand. These events involved celestial alignments, as well as the unified efforts of embodied Lightworkers and the entire Company of Heaven.
                            Now it is up to you and me to fulfill the next step of the Divine Plan. This is something we have been trained to accomplish for aeons of time. Know that you have all of the skill, strength, courage, and ability you need to succeed God Victoriously. All that is necessary now is your WILLINGNESS to invoke the Light of God and to be the Open Door through which that Light will flow to transmute the negativity that is being pushed to the surface to be healed.
                            We are One with ALL Life. There is NO separation. Every facet of Life on Earth is interconnected, interdependent, and interrelated. Consequently, we cannot just say cancel, cancel and eliminate the past. Instead we need to invoke the Light of God and transmute the distorted, human miscreations that are manifesting now as Humanity's pain and suffering.
                            What is occurring this very moment is that the Light of God is increasing on Earth in unprecedented ways. This Light is entering the core of purity in every atomic and subatomic particle and wave of Life on Earth. This is causing everything that conflicts with God's Light to be pushed to the surface, so that it can be healed and transmuted back into its original perfection. From outer appearances this process looks like things are getting worse, but nothing could be further from the Truth.
                            We can easily see the negativity that is being pushed to the surface. All we have to do is watch the news or observe the challenging things taking place in our own lives or in the lives of people all over the world. What we do not see as easily is the incredible Light that is pushing the negativity to the surface to be healed. Transmuting this surfacing negativity, before it overwhelms the planet, is by far the greatest need of the hour. This, Precious Hearts, is the next phase of the unfolding Divine Plan.
                            We are being asked by the Company of Heaven to use the building momentum of the 22nd anniversary of Harmonic Convergence to quickly purge the planet of the surfacing negativity. The Divine Intent of this activity of Light is to clear the way for the tangible manifestation of the patterns of perfection for the New Earth. Twenty-two is the master number that reflects power on all planes and the ability to change the course of history. This is our moment! With perfect synchronicity and in Divine Timing, all is in readiness.
                            During the week of August 15-20, 2009, Lightworkers will be gathered within the portal of Healing Through the Power of Infinite Transmutation in Tucson, Arizona. The vehicle for this gathering is the 23rd Annual World Congress on Illumination. These selfless Lightworkers will be joined in consciousness by hundreds of thousands of willing people, like you, all over the world. Together we will form a mighty transformer through which the most powerful Healing Light available to Humanity will flow to quickly purge and transmute the surfacing negativity.
                            This is a global activity of Light, and we will all be in our right and perfect place. If you are not able to be physically present with us at the 23rd Annual World Congress on Illumination, know that we are One, and that you can add your precious Light to this facet of the Divine Plan no matter where you are.
                            As the World Congress On Illumination unfolds each day, the Beings of Light in the Realms of Illumined Truth guide us step by step through the various facets of the unfolding Divine Plan. For this reason, we do not have a lot of information about the specific Divine Ceremonies in advance. I encourage you to listen to your heart, and KNOW that you too will be guided through each day by your I AM Presence and the Company of Heaven. Stay focused in THE ETERNAL MOMENT OF NOW, and know that whenever you are able to join in consciousness with us will be right and perfect. It does not matter if you are joining with us at the exact same time that we are in our sessions. When we are focused in the Eternal Moment of Now, we are joined together in perfect synchronicity.
                            The momentum of Light will build from the opening ceremonies on August 15th through the closing ceremonies on August 20th. Your Divine Intention is what matters. Know that if you intend to be the most powerful force of Light you are capable of being during this miraculous facet of the Divine Plan, you will be. Trust yourself!
                            Thank you for your heartfelt desire to assist Humanity and this precious planet. Your Light and Love are needed and gratefully accepted by Mother Earth and ALL Life evolving upon her.
                            One of the most important things for us to comprehend at this time is that the activities of Light that have taken place this summer have GREATLY EMPOWERED OUR CREATIVE FACULTIES OF THOUGHT AND FEELING.
                            This means that whatever we are focusing our attention on is being greatly amplified and empowered. It is critical that we hold our attention on what we want to cocreate, not what we do not want.
                            During this Cosmic Moment, our omniscient, omnipresent, omnipotent Father-Mother God are sounding a Fiat throughout the Universe for Humanity:
                            STAY FOCUSED ON THE LIGHT!!
                            The following is an invocation that has been given to Humanity by the Beings of Light in the Realms of Illumined Truth to assist us with this facet of the Divine Plan.
                            INVOKING THE VIOLET FLAME OF INFINITE TRANSMUTATION
                            On behalf of myself and ALL Humanity, I AM invoking the 5th-Dimensional frequencies of the Violet Flame of Infinite Transmutation. I AM projecting this Sacred Fire through every atomic and subatomic particle and wave of Life on Earth that is vibrating at a frequency less than the harmony and balance of God.
                            Through the Beloved Presence of God, I AM, blazing in every Heart Flame, I invoke Beloved Saint Germain and ALL of the Legions of Light throughout infinity who are associated with the new 5th-Dimensional frequencies of the Violet Flame of God’s Infinite Transmutation.
                            Blessed Ones, I invoke the most intensified activity of this Violet Flame that Cosmic Law will allow for myself, my Loved Ones, and ALL Humanity.
                            Beloved I AM, blaze, blaze, blaze the full momentum of this Sacred Violet Fire in, through, and around every electron of precious Life energy Humanity has ever misqualified in any time frame or dimension, both known and unknown. Instantly transmute these patterns of imperfection cause, core, effect, record, and memory into God’s Infinite Perfection.
                            Beloved I AM, blaze the 5th-Dimensional frequencies of the Violet Flame through every thought, word, action, and feeling Humanity has ever expressed that reflects anything less than the Immaculate Concept of our full Divine Potential.
                            Beloved I AM, look into my life and the lives of ALL Humanity and see what yet remains to be balanced by us to any person, place, condition, or thing we may have wronged at any time, in any way, for any reason whatsoever.
                            Beloved I AM, reach your great loving hands of Light into all of the positively qualified energy we have released throughout our Earthly sojourns, and draw forth a thousand times as much perfection as we have ever done wrong.
                            Fashion from this substance of perfection a Gift of Divine Love, whatever is necessary to balance every debt we have created which still remains unpaid to any part of Life.
                            Beloved I AM, I ask you to forgive every person, place, condition or thing which may have wronged me or Humanity in any way, and balance all debts owed to us by Life everywhere.
                            I accept this God Victoriously accomplished right here and right now through the Power of God I AM. And so it is. (end)
                            Dear One, I deeply appreciate YOU and your willingness to add to the Light of the world during this vitally important facet of the Divine Plan.
                            Remember, the Light of God is ALWAYS Victorious, and WE are that Light.
                            Victory is ours! Victory is ours! Victory is ours!
                            God Bless You,
                            Patricia Cota-Robles
                            http://blog.hexaheart.org
                            • My dear Millennium,
                              All those faces posted are even painful to gaze upon for they bear the
                              lifeless pallor of men who are already the living dead......they all have
                              the look of dark minds and loveless hearts. Their time is surely up....
                              their pale pallor and dull eyes reveal their near end. Let them go.
                              Give no attention to them. Give attention to Life and Beauty.
                              All these men will fall away like flies as the Light is pouring in, there
                              will be an organic and natural process of elimination. ....loveless men
                              cannot handle the higher frequencies coming in now.....all deadened and
                              black hearts will malfunction ....literally. .....and all those who do not
                              love the Mother or Feminine or at least respect Her, will also malfunction
                              in many different ways via any organs of their toxic bodies or strange
                              occurrences. For their bodies are made of the Mother Earth and those who
                              do not love what they are made of call in decay and death. Those who love
                              their bodies and Mother call in Life. It is simply the nature of the Living
                              Cells.
                              Love of the Feminine is Life giving. Patriarchy is death promoting...
                              as all their history of war making reveals.
                              In the past, as Mother was renounced, the dark energies prevailed and
                              proliferated like a cancer on Earth.....sometimes the cancer wins the host
                              country or even planet. Not this time, not anymore.
                              Because of these historical times in the Universe, the staggering amounts
                              of Light coming into Earth, built into patriarchy is the code of death.....
                              especially when Earth is receiving so much Light....anything going
                              against the Light of the Feminine will die. Have no worries. Be at peace.
                              The lover of life is impervious to darkness.
                              Patriarchal thoughts and all their endeavors, will disintegrate into
                              nothingness
                              for there is nothing in the universe anymore to support it. The media is
                              only
                              spouting old holograms of their villainous fantasies. Kill the TV, and
                              some websites too.
                              Listen to beautiful soothing music.
                              Spend time with large old trees and children who laugh.
                              Buy flowers and plant green plants.
                              Anoint your body temples with fragrant natural essential oils.
                              Dance like no one is watching.
                              Sing like no one is hearing.
                              Make of yourselves a thing of fragrance and harmony.
                              These things of Beauty will bring in more Beauty.
                              The Goddess Mother is waiting for others to join in her dance of reverie and
                              of Life
                              Rest your breath and life in the lap of the Mother.....find the woman....
                              and rest in her embrace.
                              Blessings of magic and beauty
                              Lady of the Woods.
                              Keep your mind on the aether www.PathsToSucceed.com
                              • The inner doorway, knowing;
                                By my way of knowing, the positive realms of the source/creator/god are in process of expansion. This realm of the physical (a negative realm, the memory of its creation tickles the back of my consciousness) is being drawn closer or more accurately, being overtaken by the higher vibratory levels. There are other levels of creation already in existence for those who need the older vibratory levels for their growth and learning. This is not to say this level will be a positive realm, yet it will shift to a higher level of operation and from a point of relativity will be much more positive than has been previously demonstrated.
                                There are many who have come to assist in the shift and to anchor the new frequencies until the dust settles so to say, many of them accomplished masters. These masters may live next door and you may never know it, the master that matters most is the one that resides within your self.
                                Try to understand that you/we are existing on all levels of creation all at the same instant that is now, meaning we are connected to the source and exist there as well as here, and every where in between. It is only where you focus your awareness that differentiates your so called reality. (Positive/Negative like a battery) there is no good/bad, right/wrong, just experience.
                                If you lift your awareness a few levels up there is no masculine/feminine but rather a individualized oneness. (Individualized awareness of the one). If you lift it many levels, the being of all that is,is you.
                                It grows late and I have many journeys to make, I wish you all pleasant night travels.
                                Love & Light
                                David
                                P.S. a little something to try
                                Beyond the chatter of the mind and the upheavals that are the emotions lies a place of stillness, seek this place within. Sitting here tune to your own breath, do this to a count of 4, count of 4 on the inhale, hold for a count of 4, count of 4 on the exhale, hold empty for a count of 4; repeat.
                                When you feel in tune with your breath after a few moments on an exhale hold it a little longer and pay attention to what is breathing you.
                                This exercise assists in connecting to the inner master and the source
