time
Everything happened in an infinite point so there is no linear time. What we perceive is just that, a perception of the movement of light and depending on the aetheric density the light is traveling through, the light will be slower or faster but to the observer in time/space of high or low aetheric density, their perception apparatus will see light going the speed of light. It will always appear that way even though if it was compared to a baseline light speed reading, it would be much slower or much faster. The higher the density, the slower the light can move through it and therefore a slower "movement" of time. The less the density, the faster the light can travel and the faster the "movement" of time.
If you wound up a rubber band propeller and let it go in some water, it would spin around pretty quick. That is like low density aether with fast light movement and fast time ticking. If you let the propeller go in a bowl of jello, it would be very slow or no movement at all representing very high density of aether, high gravity, very slow movement of light and therefore a very slow movement of time.
