I am not sure of the calculations to figure out the idle current,
because each half of the sine wave is created by separate mosfets (or sets of them), you have to set the idle current so that the waveform matches up at the zero voltage point.
each mosfet is slightly different, so you need adjustment there anyway...
and you sure don't want to much idle current as that just makes waste heat.
any more questions, or is this all set now and it time to bring up how you match impedance to what ever you are running the output power into ?
