A new configuration for a electromagnet a electromagnet with a rod magnet surrounded by a soft iron shell .it puts out 4 times in put
There's the set up a rod magnet or stack of button magnets neos .then a iron structure around that a tube then copper windings around the iron shell or tube .when not powered up the flux field is flowing though the iron shell bascily shorting out the power .but when turned on and the iron she'll becomes a magnet and all the magnet domains are used up and it match's the polarity of the neos there's noware for the neos flux field to go so its added to the electro magnets flux field .making a out put 4 times input . very simple and could change everything .I've seen something similar in the guys that put neos under a bedini coil .some have thought its a type of reset for the core but this is showing a different action .a motor set up should go over unity easy. And cheap.
