a better way to present the periodic table
  • #16
    if you'd like to know more about A Wave Structure for the Electron follow the link:
    Beyond the Point Particle - An Electron Wave Structure
    “Signs and symbols rule the world, not words nor laws.” -Confucius.
    • #17
      As promised, here follows a few experiments conducted by people that were ahead of their time, i believe you can reproduce these(or part of it) if you acquire the right materials. Before you start reading about them, please take the time to read the summary i wrote in previous replies, so as to acquaint yourselves with the theories of The Wave Structure of Matter Theory combined with The Electric Universe theory. if you combine both theories (Wave Structure of Matter), you'll see that is how you can explain the phenomena observed in the various experiments I'll be presenting you.
      Experience is made before the law is formulated, both are related like cause an effect. Nicholas Tesla
      For Starter:
      Leon SPRINK:Space Activator
      Leon Sprink was a Russian engineer who operated a cement manufacturing plant in France circa 1950. He received several patents for a simple method to create a type of electric field that accelerates chemical reactions.
      In one example given by Sprink, “One month after the setting in operation of the apparatus, the duration of the reaction, which normally is 24 hours, had fallen down to 3 hours and the saving in calories to be supplied for the reaction was 50%… The field also affects the states of matter such as solubility and crystallization, distillation, reduction of metallic ores, etc..."
      In the simplest form of the invention, Sprink used a grounded container placed in an electrostatic field. More control and power was obtained with geometric arrays of positive electrodes mounted diagonally from grounded electrodes.
      The form (e.g., a cube) was mounted upright and aligned East-West. 1000 to 5000 KV of positive charge (per meter of electrode separation) was applied for two weeks or longer to establish a zone of activation, spreading up to 60 meters :
      to read more about him:
      Leon Sprink - Antigravity - patents
      found a similar set up made for biological purpose:
      Tszyan KAN'CHZHEN: Microwave Transfer of Biological Information
      Tszyan Kanchgen has lead a series of experiments, which have shown an opportunity of direct transfer of the information from one biological object to another by radio waves [45]. Tszyan Kanchgen has created installation [46], including hollow correct of polyhedron and hollow cones located on its sides. The biological object which is carrying out influence is located in a cavity of polyhedron, its the radiations amplify and are transferred to other alive object by microwaves.
      In experiments with cereal cultures Tszyan Kanchgen placed in the installation green weight of wheat and influenced by radio waves on germinate sabadillas of corn. The "processed" corn had set of lateral stalks. On the place of panicle the original ears with grains similar and on corn, and on wheaten (fig. 26) were formed. The acquired new qualities were steadily transferred to the subsequent generations.
      more on this:
      Tszyan Kanchzhen
      Corson & Zaderej -- Electrogenics : Electrical treatment of seeds -- United States Patent: 4,302,670
      Electrogenic crop stimulation is the name of the game, and though it sounds like man is messing with God's business, it isn't what you might think and the ramifications of this technical revolution are far more beneficial that today's chemical fertilizer, agribusiness methods.
      Based on 5 years of intensive research and exprimental plantings in all areas of the conuntry, the ECSS (Electronic Crop Stimulation System ) accomplished the following:
      1. An increase in the vigor and germination rates of seeds.
      2. Acceleration of the germination and growth rates.
      3. Vastly increased root structures
      4. Increased resistance to adverse weather conditions such as drought, high winds and low temperatures.
      5. Increased resistance to parasites and pests.
      6. Reduced water requirements with irrigated crops.
      7. Improved quality of edible yield.
      8. Vastly increased per acre.
      Additionally, the experimentors now have produced and enzyme that literally reconsitutes soils, meaning that more land around the world can be made productive.
      "If you are a farmer, you doubt what we have to say until you try it. If you are an agricultural professor, you doubt it so much you won't bother to try it. But if you try it, you'll like it".
      Some may say it is impossible, or violates the law of physics (of which we know only a part of) but it is simply called today :
      Magnetochemistry
      Magnetochemistry - Wikipedia, the free encyclopedia
      Magnetochemistry is concerned with the magnetic properties of chemical compounds. Magnetic properties arise from the spin and orbital angular momentum of the electrons contained in a compound. Compounds are diamagnetic when they contain no unpaired electrons. Molecular compounds that contain one or more unpaired electrons are paramagnetic. The magnitude of the paramagnetism is expressed as an effective magnetic moment, μeff. For first-row transition metals the magnitude of μeff is, to a first approximation, a simple function of the number of unpaired electrons, the spin-only formula. In general, spin-orbit coupling causes μeff to deviate from the spin-only formula. For the heavier transition metals, lanthanides and actinides, spin-orbit coupling cannot be ignored. Exchange interaction can occur in clusters and infinite lattices, resulting in ferromagnetism, antiferromagnetism or ferrimagnetism depending on the relative orientations of the individual spins.
      Quantum chemistry - Wikipedia, the free encyclopedia
      Quantum chemistry applies quantum mechanics for explaning and predicting chemical behaviours. The majority of quantum chemical investigations (at the time of writing), use computations based on approximated solutions of the Schrφdinger equation for determining the energy levels of molecules and the molecules' properties such as conductance, charge distribution, and reactivity. Other quantum chemical results include molecular geometry, the strengths and other characteristics of chemical bonds, optical and other spectra, intermolecular forces, and many other chemical properties and features of chemical behaviour.
      http://www.msg.ameslab.gov/tutorials/quantumintro.pdf
      Bionics
      Bionics (also known as biomimicry, biomimetics, bio-inspiration, biognosis, and close to bionical creativity engineering) is the application of biological methods and systems found in nature to the study and design of engineering systems and modern technology.
      I found this periodic table of elements :
      Rafael Poza's Elements and the Magnetosphere
      more on this in post#41
      More to come....
      • #18
        As I keep on searching for clues in Nature that could validate the The Wave Structure of Matter/The Electric Universe theory, i found the following pictures that are another piece of this "cosmic puzzle":
        Cymatics (from Greek: κῦμα "wave") is the study of visible sound and vibration, a subset of modal phenomena.
        You can find out more here:
        Biology :: Cymascope Research
        Music and Geometry:
        Standing Waves form Platonic Solids
        "In 3D standing waves, a structure, with all characteristics of a platonic solid, is formed for each standing wave mode. Within an atom, which is the building block of matter, the platonic solid is not formed by salt or known particles, but by electromagnetic waves in vacuum.
        Both the students of Buckminster Fuller and his protege Dr. Hans Jenny devised clever experiments that showed how the Platonic Solids would form within a vibrating / pulsating 3D sphere.
        link:
        Vibrations, Harmonics, Resonance, Waves and Reality
        Which leads me to our next protagonist, a Nobel price winner:...
        • #19
          best understood as templates that generate the focus of intensity necessary to become fractally attractive, that is, bend the straight energy flow of light into a circle of atomic structured matter.
          the best representation of this is the Rodin Coil, you can watch this 3d representation of the Rodin coil
          YouTube - MotionTrailRodinCoil
          and my hypotheses is that it is not one "light" that wounds around the donut but two "lights" just like you build the Rodin coil with two wires, And I surmise that the third electromagnetic field "light" created by the two opposing"light" is at the origin of the atomic structure.
          watch this starting at 30 min till 31 min
          YouTube - BBC - Everything and Nothing - Nothing
          Walter Russell presented a similar concept:
          Gravitation and Radiation
          Gravitation pulls spirally inward from within to wind light waves into solids to center space. Radiation thrusts spirally outward to unwind dense solids into space to surround solids. Each is an equal reaction of the other. Each becomes the other sequentially.
          Subquantum Kinetics
          The continuous creation of physical reality from the transmuting ether as portrayed in the subquantum kinetics physics methodology
          It further proposes that the concentrations of the substrates composing this ether are the energy potential fields that form the basis of all matter and energy in our universe. The operation of these ether reactions causes wave-like field gradients (spatial concentration patterns) to emerge and form the observable quantum level structures and physical phenomena (e.g., subatomic particles with mass, charge, spin, and force field effects and electromagnetic waves).
          Scientific predictions made by subquantum kinetics
          Electro gravitics
          YouTube - TOAFN's Channel
          Thomas Townsend Brown: Electro-Gravity Devices (Office of Naval Research File #24-185, Sept. 15, 1952 by Willoughby M. Cady)
          Perl -- "Electrogravitics Systems"
          the following theory is my piece de resistance: learn more about it in post#40:
          Garret Lisi explains E8 Geometry
          http://www.energeticforum.com/140438-post40.html
          images of Rodin Coil with good representation of the third "light" in color and rodin Coil with vortex(from microscale (subquantum) to macroscale):
          model of Walter Russell similar to Rodin coil
          Crooks table
          Uploaded with ImageShack.us
          As a man who has devoted his whole life to the most clear headed science, to the study of matter, I can tell you as a result of my research about atoms this much: There is no matter as such. All matter originates and exists only by virtue of a force which brings the particle of an atom to vibration and holds this most minute solar system of the atom together.
          Max Planck
          this website illustrates much better the evolution from micro to macroscale of the vortex/wave theory of matter: (thanks Lamare )
          Free Energy and Free Thinking
          • #20
            now unto our Nobel Price Winner:
            Luc MONTAGNIER DNA Teleportation
            A Nobel Prize winning biologist has ignited controversy after publishing details of an experiment in which a fragment of DNA appeared to 'teleport' or imprint itself between test tubes.
            According to a team headed by Luc Montagnier, previously known for his work on HIV and AIDS, two test tubes, one of which contained a tiny piece of bacterial DNA, the other pure water, were surrounded by a weak electromagnetic field of 7Hz.
            Eighteen hours later, after DNA amplification using a polymerase chain reaction, as if by magic the DNA was detectable in the test tube containing pure water.
            note: looks to me that a zone of activation was created then the dna transfer was accomplished
            and also the weak electromagnetic field of 7Hz used is actually close to Schumann resonances:
            The Schumann resonances (SR) are a set of spectrum peaks in the extremely low frequency (ELF) portion of the Earth's electromagnetic field spectrum. Schumann resonances are global electromagnetic resonances, excited by lightning discharges in the cavity formed by the Earth's surface and the ionosphere....
            ....as distinct peaks at extremely low frequencies (ELF) around 7.83, 14.3, 20.8, 27.3 and 33.8 Hz.
            makes you wonder...
            side note:
            ...it maybe a link with the earth's resonance and a clue to our evolution (hope i am not going too far in saying this )
            it is also one more clue to nature as having a fractal antenna properties, adding to it the same resonance of two identical coils (ie: the water)
            just like Tesla's Experiment
            link:
            http://www.energeticforum.com/energe...tml#post139899
            "Quantum Water" Discovered in Carbon Nanotubes
            Chengdu Organic Chemicals Co. Ltd., Chinese Academy of Sciences
            A new quantum state of water found in carbon nanotubes at room temperature could have important implications for life...
            ...That's a big deal. Reiter and co chose carbon nanotubes because they are an analogue of the conditions water faces when passing through living systems, through ion channels in cell membranes, for example. Biologists have long known that flow through these channels is orders of magnitude greater than conventional fluid dynamics predicts. Perhaps this new state of quantum water is the reason why.
            to read more on this:
            Luc Montagnier -- DNA Teleportation -- article & patent application
            Schumann resonances - Wikipedia, the free encyclopedia
            Update: After some Research Thanks Dave45 , Quartz + Water are key here in the Transfer of Dna
            see:http://www.energeticforum.com/renewa...tml#post148371
            Next up: DNA Music
            • #21
              Joel STERNHEIMER: DNA Music
              When we think of plants being affected by sunlight we are really looking at the effect of a portion of the electromagnetic spectrum on plants that portion which includes visible light. It should not surprise us that sound also impacts plant growth because it is, in essence, an extension to other parts of the electromagnetic spectrum.
              More on This:
              Joel Sternheimer -- Protein Music -- French Patent # 2,136,737
              found new info, it goes as follows:
              more on this:
              Tszyan Kanchzhen
              some more info:
              Three Soviet scientists, S. STSCHURIN, V. P. and L. KAZNACHEJEU Michailova, confirmed after more
              than 5 000 experiments that living cells transmit information through photons (in 1981).
              We can describe the experiments simply as follows:
              - Cells are bathed in a nutrient solution in two spherical flasks made of quartz. The two flasks are touching
              each other
              . If a cell culture is affected by a virus, or poisoned, the cells in the adjacent flask become
              impaired every time and always have the same symptoms, whereas they should be protected from the toxic
              influence of other cells by the quartz side
              s.
              - If you use glass flasks, the second cell colony is protected.
              - The transmission between the two colonies is made by ultraviolet radiation.
              *** These same three Soviet scientists measured the cell radiation using a photomultiplier. "Normally living
              cells emit a constant stream of light rays. When a virus enters cells, radiation changes: it first increases -
              then silence – then new increase, then gradual attenuation of radiation in multiple wavesuntil the cell
              dies. This recalls the cries of pain of an animal.
              *** In 1974, Simon STSCHURIN, said: "The cells affected by different diseases have different radiation
              characteristics. We are convinced that photons are able to inform us long before the onset of pernicious
              degeneration to disclose the presence of a virus ".
              Today, scientists worldwide are exploring this phenomenon:
              - In Australia, the correlation between cancer and ultra-hight- throuhput radiation is under study.
              - In Brazil, fundamental studies are being conducted to understand light transport in cells.
              - In China, the action of light on cells is currently studied.
              - In Japan, research is trying to make an early diagnosis of cancer from cell radiation
              Quartz + Water are key here also
              link:
              Light biology - quetanglais
              more on info found here:
              Biophysics And the Life Process
              Russian student develops method to diagnose early cancer: Voice of Russia
              • #22
                Next is an invention similar to Leon SPRINK:Space Activator
                Francis E. WILKINSON: High-Frequency Transformations
                Dancing electrons, whipped to a jitterbug frenzy, are performing miracles of modern alchemy in a backyard laboratory at Glendale CA. Racing back and forth through coils of wire at frequencies up to 100 megahertz, they transform water, natural gas, cottonseed waste, and potato peelings into new and useful substances for industry.
                More on this:
                Francis E. WILKINSON -- High Frequency Transformations
                note: That gives us ,in a way, reproducibility of Sprink's experiment (which is good, since reproducibility of an experiment is a corner stone of scientific proof that an invention works )
                • #23
                  side note: If anyone of you,readers, is a programmer, it would be great to apply Rodin's Mathematics to computer programming, I'm sure you will discover there is some coherence to " Vortex-Based Mathematics".
                  if you want to know more:
                  Vortex Based Mathematics : Marko Rodin
                  • #24
                    Riddle me this:
                    Observation: copper was considered among alchemist an earthen element, if you look up platonic solids in wikipedia guess which shape corresponds to earth: hexahedron.
                    if you look at the hexahedron (cube) molecules i presented you with, you'll find that a copper molecule takes the shape of a cube. How could Alchemist know in a certain way that Copper was an earthen element (ie: cube shaped) When they did not have access to the technology to determine the shape of molecules as we do today
                    If you want to know more about the golden mean and its overwhelming presence in nature:
                    World Mysteries - Science Mysteries, Fibonacci Numbers and Golden section in Nature
                    Lecture 6: Renaissance Magic
                    the answer lies here
                    Elaborating the Neoplatonist picture. Agrippa accepts the basic Neoplatonic framework sketched above. God has the Forms in his mind. God created "Angelical and Celestial secondary causes," beings Agrippa also calls the "Intelligences," and God "gives the seal of His Ideas to the Intelligences." The Intelligences then use the "heavens and stars as instruments" to send these copies of the Forms down to humans on the Earth. In exactly the way our souls/intellects control our bodies, the Intelligences -- the Celestial souls -- control the body (=the matter) of the universe. So just as my mind "sends commands" to my body in order for the mind to achieve its aims, so too do the Intelligences/ celestial souls use the stars to achieve their ends. Thus Agrippa agrees with Avicen[na], who says "whatever things are done here, must have been before in the motions and conceptions of the stars and orbes." Agrippa says that "quintessence" -- Aristotle's 5th element, aither -- is what conveys the Intelligences' power to material stuffs: the spirit is contained in "the rays of the stars."
                    • #25
                      If you place an iron rod in a dark room and cause it to vibrate at first you'll only be able to tell it is vibrating by touching it.
                      Increasing the vibration to 32Hz will produce a loud and shrill sound and vibration can now be detected by both touch and hearing. Increase that vibration to 40Hz and you can no longer detect the vibration by touch or sound.
                      If you increase the vibration to 1.5MHz you cannot feel or hear the vibration but you can detect the vibration though the rise in temperature in the iron first warm and then the iron rod will glow red hot and can be detected by sight.
                      At 3MHz the rod is now producing violet light; increasing the vibration more will produce ultra-violet rays and other invisible radiations that can only be detected by special instruments.
                      There are so many "vibrations" flowing all around us that are invisible to our 5 senses who can tell how they affect us. Uranium emits and invisible radiation that will kill you. You cannot see it but it is there and kills. Who is to say how the other radiation affects the body and mind.
                      Isn't it possible that the mind radiates its own wireless transmissions that are received by other minds but we just are unaware of that as of yet. There is no scientific proof for or against this theory, yet so many people will just to the conclusion that it cannot exist. There are among the same people that would have disbelieved radio existed before it was proven that is does exist.
                      You MUST keep an open mind and use these methods as those successful have already used them to achieve success. Who are you willing to believe, those who have not succeeded or those who have?
                      Dr. Alexander Graham Bell
                      want to know how vast the electromagnetic spectrum is , Richard Hammonds does an excellent presentation (starts at 10 min):
                      YouTube - Invisible Worlds - Out of Sight 1/4.avi
                      • #26
                        Neurobiologists Find that Weak Electrical Fields in the Brain Help Neurons Fire Together
                        "So far, neural communication has been thought to occur almost entirely via traffic involving synapses, the junctions where one neuron connects to the next one. Our work suggests an additional means of neural communication through the extracellular space independent of synapses."
                        link:
                        Neurobiologists Find that Weak Electrical Fields in the Brain Help Neurons Fire Together - Caltech Media Relations
                        • #27
                          I would like to propose an easy experiment which is based on Sprink's Experiment, repeat the same steps as sprink's experiment, but instead of using electrodes use a rodin coil (with pulser circuit to increase magnetic effect) with a rod placed in its center. I believe that the results will prove to be quite surprising. I will try to set up the experiment but it will take time.
                          inspired by Sprink's experiment and Crook's table of the elements (see attachment)
                          Want to learn how to make a rodin coil, follow the link:
                          ‪Rodin Starship Coil‬‏ - YouTube thank you IndianaBoys
                          YouTube - What Is A Rodin Coil And How To Make One...
                          neospin8 Rodin Coil pulser circuit with Neoball | Real Do it Yourself Energy
                          • #28
                            • #29
                              for instance, a Tetrahedron would require 4 Rodin coils one for each face of the tetrahedron
                              or a different set up, this one inspired from Walter Russell
                              i found a similar set up that i proposed but instead of using rodin coils to create a vortex, he used a cone (which is a simplified vortex, uses also the same principle to capture EM field with cone/vortex as Otto MOHR: Detonator Ray to be found on post#38)
                              more on this in post #18
                              • #30
                                From Wikipedia:
                                Platonic solid - Wikipedia, the free encyclopedia
                                Dual polyhedra
                                A dual pair: cube and octahedron.
                                Every polyhedron has a dual (or "polar") polyhedron with faces and vertices interchanged. The dual of every Platonic solid is another Platonic solid, so that we can arrange the five solids into dual pairs.
                                The tetrahedron is self-dual (i.e. its dual is another tetrahedron).
                                The cube and the octahedron form a dual pair.
                                The dodecahedron and the icosahedron form a dual pair.
                                If a polyhedron has Schlδfli symbol {p, q}, then its dual has the symbol {q, p}. Indeed every combinatorial property of one Platonic solid can be interpreted as another combinatorial property of the dual.
                                One can construct the dual polyhedron by taking the vertices of the dual to be the centers of the faces of the original figure. The edges of the dual are formed by connecting the centers of adjacent faces in the original. In this way, the number of faces and vertices is interchanged, while the number of edges stays the same.
                                I think the field that gets created in Sprink's experiment is the creation of a magnetic field that takes the shape of the dual of the Platonic Solid you set up your electorde/Rodin Coils in. I would really like to have someone try my proposed experiment, for one i have to teach myself how to make circuitry, and electric set ups.
                                find update on this here:
                                http://www.energeticforum.com/141364-post48.html
