a better way to present the periodic table
  • #76
    there is a wealth of data that could be extrapolated from the socionomics documents into applications for Ethericity, such as the 62% / 38% ratio constantly found in the research they conducted (http://www.energeticforum.com/genera...tml#post147637 ) (starts at 42 min )
    62% and 38%
    also from the doc
    it takes 3 waves to make a variation
    If you only knew the magnificence of the 3, 6 and 9, then you would have a key to the universe.
    — Nikola Tesla
    • #77
      Tesla uses three coils in his tesla coil, doesn't he...Id be curious if someone could find the 6 3 9 numbers in the construction of a Tesla coil... for instance
      62 38 95 as dimension/turns etc...
      note:
      6+2=8
      3+8=11=2
      9+5=14=5
      • #78
        my gut is telling me that the tesla coil as Boguslaw puts it for the numbers 3 6 9
        Now you should see it ,right ?
        It has no meaning except shape.... look at shape....
        well for the Tesla Coil, I would say:
        it has no meaning except numbers...look at the numbers
        • #79
          from the socionomics doc : (start at 48 min )
          the segmented human mind:
          human has 3 minds:
          the reptilian mind
          the emotional mind
          and the rational mind
          if you look at mri pic (at 48:14) , the three neural systems (fractal too ) look like 3 coils inside each other, or like the moe-joe cell
          Quite different conditions exist in my system in which the electromagnetic waves or radiations are designedly minimized. the connection of one of, the terminals of the transmitting circuit to the ground having, itself, the effect of reducing the energy of these radiations to about one-half, Under observance of 'proper rules and artifices the distance is of little or no consequence, and by skillful application of the principle of "individualization," repeatedly referred to the messages may be rendered both non-interfering and non-interferable. This invention, which I have described in technical publications, attempts to imitate, in a very crude way, the nervous system in the human body.' Nicolas Tesla
          • #80
            Another great example and most amazing (trust me on that)
            Bobby McFerrin demonstrates the power of the pentatonic scale, using audience participation, at the event "Notes & Neurons: In Search of the Common Chorus", from the 2009 World Science Festival, June 12, 2009.
            ‪World Science Festival 2009: Bobby McFerrin Demonstrates the Power of the Pentatonic Scale‬‏ - YouTube
            enjoy
            • #81
              I got to tell you all , these are the moments when i truly feel alive
              Live Curious
              If you are you breathe.
              If you breathe you talk.
              If you talk you ask.
              If you ask you think.
              If you think you search.
              If you search you experience.
              If you experience you learn.
              If you learn you grow.
              If you grow you wish.
              If you wish you find.
              And if you find you doubt.
              If you doubt you question.
              If you question you understand
              and if you understand you know.
              If you know you want to know more.
              If you want to know more ...then you are alive
              National Geographic
              ‪National Geographic Channel - IF. Live curious.‬‏ - YouTube
              • #82
                from: http://www.energeticforum.com/renewa...llector-8.html
                Originally posted by Slider2732 View Post
                Never apologise for excess energy buddy, that's what we're all looking for lol
                It was a hallelujah moment when I first realised that everything alive pretty much follows the same design shape. A tree, person, frog, cat, centipede. Have to turn some 90 degrees, but they follow the same little rule
                A lesson in perspective, it is not always evident to find "the fractal engine at work", sometimes you have to completely change your references, but luckily you have one clue and an important one in your favor... you know that everything and i mean everything is fractal, so you know what to look for (ie:self similarities etc...) even when you search the INTERNET you do that, think about it
                you start with one key word than add another until you narrow down your search....isn't that fractal (read from left to right )
                actually you have 2 clues: you know that everything and i mean everything is fractal, so you know what to look for (ie:self similarities etc...) and it must obey :
                fractal/constructal system:
                The constructal law puts forth the idea that the generation of design (configuration, pattern, geometry) in nature is a physics phenomenon that unites all animate and inanimate systems, and that this phenomenon is covered by the Constructal Law stated by Adrian Bejan in 1996: "For a finite-size (flow) system to persist in time (to live), its configuration must evolve such that it provides easier access to the imposed currents that flow through it."
                in other words, it should obey the
                E=M3/4
                It is called Kleiber's Law.
                It states that the energy needed by an organism at rest (not doing any specific exercise), is not proportional to its mass, but sub-linear.
                It can be attributed to many factors and one of them is that the more massive an organism/element/wave is, the less surface per volume it present. If the organism is represented par a sphere of diameter D, volume scale with D^3, but surface scales with D^2. But energy produced by the body is proportional to volume, while energy lost is proportional to external surface.
                • #83
                  side note: an awesome doc
                  Pale Blue Dot by Carl Sagan - Episode 1: "Wanderers"
                  Some time before he died in 1996, Carl Sagan recorded a partial audio version of his 1994 book "Pale Blue Dot". Often described as the "sequel" to Cosmos, the audio version of Pale Blue Dot is, at this moment, regrettably out of print. This video is "episode one" of an unauthorized attempt at producing a series of videos based on Carl Sagan's "Pale Blue Dot" audio book combined with a soundtrack and appropriate video and still images intended to recall the feel of the classic documentary series "Ascent of Man" and "Cosmos" Please visit the project website: Pale Blue Dot:An Unauthorized View
                  • #84
                    side note: I have been talking about fractal for quite a while now, and hopefully convinced some of you, I just wanted your opinion for i think that Carl Sagan was already talking about the universe being fractal, just watch the first 10 min of this video.... pay attention to the choice of words
                    ‪Cosmos: A Personal Voyage - Episode 1 (Carl Sagan)‬‏ - YouTube
                    Btw: it was made in the 80's
                    • #85
                      ‪Fractals.Similarities. Patterns. Design.the.Hidden.Dimension.XviD.mp4‬‏ - YouTube
                      • #86
                        note:
                        6+2=8
                        3+8=11=2
                        9+5=14=5
                        Originally posted by AetherScientist View Post
                        That quote remembers me to Searl's Law of Squares. Maybe is some relation?
                        John Searl Solution : The Law of the Squares
                        Also, there is some similarity with vorticular physics and Sympathethic Vibratory Physics.
                        AetherScientist check out this video
                        I ching to Ho Tu to Lo Shu and Well basic introduction. Sum of things
                        ‪I ching to Ho Tu to Lo Shu and Well basic introduction. Sum of things..wmv‬‏ - YouTube
                        Check out this website:
                        Rodin’s Torus and it’s Match to the Lo Shu.
                        The Matching of Lee Burton’s and Paul Martyn-Smith’s working’s on the I Ching and Rodin’s Torus. Part 2:- The LO Shu and the 9 x 9 Square of the Moon.
                        • #87
                          "Think not of what you see, but what it took to produce what you see.” -
                          Benoit Mandelbrot.
                          • #88
                            FYI: read it with fractal in mind:
                            A new translation bypassing the Latin has just been published by Nineveh Shadrach from the original Arabic of Book on the Secret of Creation (also named Book of the Causes) attributed to Apollonius of Tyana.[3]
                            It contains an accurate commentary that can't be doubted.
                            It states: What is the above is from the below and the below is from the above. The work of wonders is from one.
                            And all things sprang from this essence through a single projection. How marvelous is its work! It is the principle [sic] part of the world and its custodian.
                            Its father is the sun and its mother is the moon. Thus the wind bore it within it and the earth nourished it.
                            Father of talismans and keeper of wonders.
                            Perfect in power that reveals the lights.
                            It is a fire that became our earth. Separate the earth from the fire and you shall adhere more to that which is subtle than that which is coarse, through care and wisdom.
                            It ascends from the earth to the heaven. It extracts the lights from the heights and descends to the earth containing the power of the above and the below for it is with the light of the lights. Therefore the darkness flees from it.
                            The greatest power overcomes everything that is subtle and it penetrates all that is coarse.
                            The formation of the microcosm is in accordance with the formation of the macrocosm.
                            The scholars made this their path.
                            This is why Thrice Hermes was exalted with wisdom.
                            This is his last book that he hid in the catacomb.
                            Emerald Tablet - Wikipedia, the free encyclopedia
                            • #89
                              I would like to propose an easy experiment which is based on Sprink's Experiment, repeat the same steps as sprink's experiment, but instead of using electrodes use a rodin coil (with pulser circuit to increase magnetic effect) with a rod placed in its center. I believe that the results will prove to be quite surprising. I will try to set up the experiment but it will take time.
                              inspired by Sprink's experiment and Crook's table of the elements (see attachment)
                              Want to learn how to make a rodin coil, follow the link:
                              YouTube - What Is A Rodin Coil And How To Make One...
                              neospin8 Rodin Coil pulser circuit with Neoball | Real Do it Yourself Energy
                              MonsieruM,
                              Here is another way to wind a Rodin Starship Coil.
                              HHOforVolts at YouTube has done a great job on keeping it simple:
                              Rodin Starship Coil
                              ‪Rodin Starship Coil‬‏ - YouTube
                              IndianaBoys
                              • #90
                                thank you For your contribution IndianaBoys, i truly appreciate it, only if we all work together that we will find the answer...
                                we'll update it now
