Dear everyone here
I think that most of us have heard something about LED panel light, or someone has applied LED T8 into our life, then would like to know more about it? Here I will share some information with you.
There are different kinds of LED panel light both in domestic and international markets, such as a LED T8. They are different in sizes, colors, brands, materials and so on. So, there are many choices for you actually. You can find it very easily when you need it, because there are some led light panel manufacturers in the world who have been always tried their best to make great progress in the lights. The panels can still work well even though it is under clear or frosted glass or plastic surfaces and work in light conditions from darkness to sunlight. The panels are stand-alone devices. The panels are power supported but there is no control of computer or other control actually. And the panels can be connected together if you need a larger display.
The materials of LED panel light panel include metal, plastic, PMMA, PS and so on. Generally speaking, the dimension of the panel may differ greatly, like 300*600mm and so on. Taking our 300*600mm panel for an example, the luminous flux can be 1750lm and the beam angle is 120 degree. With infrared remote dimmer for dimming 0~100m, can be ceiling or wall surface-mounted. And the color temperature(K) is White5500-6000; Warm White version is available too; No UV and IR radiation. The ambient temperature of the panel is 20-40 Degree.
The LED panel light can be applied to many situations. For example, it is widely used for commercial lighting, office lighting, warehouse lighting and supermarket lighting, leisure squares, family, hotels, shopping malls, office space and so on. Also it can be used for advertising signs, stage scenery, home decoration and other occasions and so forth. Light Green is one of the leading producer of the led panel light and its panel.
Now, after what I have said, are youfamiliar with LED panel light? Or do you have an interest in LED T8? We may have a further discussion.
