I’m getting 120 volts on my outlet and my outlet tester says things are wired correctly . Could the problem be at the neutral on the transformer pole? I read online that could be a problem on the power companies end
Lights get brighter then burn out when I run my table saw
After I spent 40hrs checking all the wiring I did some internet research. A person with similar problem would turn on a microwave and it would burn the light bulbs out. The problem turned out to be on the power companies end I told them they possibly had a bad neutral at the pole at the transformer. Next day I noticed they cut some limbs touching the line... I went inside and power is workin perfectly fine helllll yeah thank god
Now that makes better sense. You were having power feeding in where it should not be and crazy things can happen. Glad you got it working.Originally posted by johnnyfalcon View PostAfter I spent 40hrs checking all the wiring I did some internet research. A person with similar problem would turn on a microwave and it would burn the light bulbs out. The problem turned out to be on the power companies end I told them they possibly had a bad neutral at the pole at the transformer. Next day I noticed they cut some limbs touching the line... I went inside and power is workin perfectly fine helllll yeah thank god
