HHO Enriched Water
Hi Colinjlyon,
HHO Enriched Water, originated, as far as I know, with George Wiseman when he published information on the health benefits of water that had Browns Gas (HHO), made is a Single Ducted Electrolyzer, bubbled into ordinary water. All the information on these types of systems has been deliberatly placed in the PUBLIC DOMAINE. First by George Wiseman in the late 1990's and then in 2007 when Bill Lang, Tom Lang and Ozzie Freedom went on Blog Talk Radio with James Roby and released all the pertinant details, which were immediately published on the www under the protocols of General Public Licence and GNU. Anyone who knows how to make an electrolyzer can make, use and sell devices that bubble HHO into water.
At the time we were focused on using "Charged Water" (HHO Enriched Water) chiefly in car engines but I was very aware of the Health Benefits of Charged Water that George Wiseman had so clearly spelled out. We came up with the first Charged Water Systems. I though I could save my life by drinking this water. I got fed up with going down to the Garage to get a quart of Charged Water to drink and figured I would be more good off if I just made up some type of unit that would work on my kitch counter top. I still have a drawer full of low volt/amp transformers that I burnt up down in the garage. It worked. Charged Water did save my life. So Charged Water does have extreme health benefits and there is no down side to drinking water with
Browns Gas (HHO) bubbled into it. The Bare Maximum amount of Charged Water to drink is 1/2 your body weight in Ounces. The electrical setting on a 500 mA (Milliamp) transformer is 4.5 V (Volts).
Water is H2O which is H+ H+ O-! What is HHO Enriched Water or Charged Water? It is H- H- O+. That is the SIMPLICITY of it.
When you bubble H-H-O+ into water (H+H+O-) you have got Charged Water. The charge STAYS in the water for a long time. It is almost impossible to get the charge out of the water. The charge put into the water can easily be measured with a common VOM (Volt Ohm Meter) such as the Velleman AVM360, when set to measure OHM's @ Rx10,000. (Cooper & Lang 2008) The usual charge imparted to tap water when Browns Gas (HHO) is bubbled into it is -3mV. So when we say Charged Water we mean NEGATIVELY Charged Water. This is extremely important because many of the health benefits that come from drinking the water are a result of the NEGATIVLY CHARGED HYDROGEN ION or the H- Ion. See the work of Vinny Pinto on the Negative Hydrogen Ion (H-) on the www.
Cells in the body start to die or become cancerous in the -30 mV range. Today it is well understood that HEALING IS VOLTAGE. It is poor idea to be running around with a Negative Cell Voltage of less than -100mv. This is especially so because all you have to do to stay in that range is drink enough HHO Enriched Water or Charged Water. The charge in the cells of the body can also be read on the VOM (Volt Ohm Meter) by holding the leads between your thumb and 1st finger. Drinking Charged Water for about a week will restore the -mV charge in the 6 or 7 trillion cells in the body. The cells are HEALING WITH NEGATIVE VOLTAGE. If you take vitamins or supplements they work about 1/3 better with charged water. The array of benefits from
Charged Water are so substantial that one might easily conclude that Browns Gas or HHO IS LIFE FORCE ENERGY. Anyway that is my working hypothesis.
See a lot of time and research went into running engines on HHO and few realized that a vast new range of health devices were possible and would stem from the research done here in the US, on HHO, over the last ten years. The fundamental situation has changed dramatically. The US has the largest proven reserves of Natural Gas and Oil on the planet. I do not see a problem with the US also having the healthiest citizens and the best water on the planet either.
There is a lot more to this story and I will do my best to flesh out the details. Back up information can be found at:
Charged Water Drinking Systems for Better Health and a Sharper Mind | ChargedforLife HHO & Brown's Gas Water Technology
Water to Gas - Brown's Gas & HHO Water Gas Technology | Improve Gas Mileage up to 50%!
Bill Lang
Hi Colinjlyon,
Bill Lang
He's probably very capable of producing ASEA at home
