MMS - Miracle Mineral Solution - Another cure for AIDS, Cancer, Viruses, Malaria
General D.Eisenhower
http://www.nvtronics.org
Miracle tonic business shut down by Health Canada
Website was selling Miracle Mineral Solution for the past 4 years
Health Canada says the chemical is not fit for human consumption and is only authorized for use as a germicide for veterinarians or as a disinfectant.
It has been also approved for water purificationEven if we describe a mild diarrhea as "adverse condition", what about "serious" adverse conditions caused by Health Canada approve drugs, including chemo! Of course, they loyally advise by small print on the back about possible side effects.
Miracle tonic business shut down by Health Canada - Calgary - CBC News
Bullocks!
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
Abscessed tooth
How to Overcome an Abscessed Tooth in 3 Days - YouTube
I'm sure Jim meant to say "3 oz" not three drops of water.
CDS - New Instructions (Chlorine Dioxide Solution)
CDS - New Instructions (Chlorine Dioxide Solution) - YouTube
Sounds like big phrama is up to their usual tactics of trying to shut down all competition.Originally posted by blackchisel97 View PostMiracle tonic business shut down by Health Canada
Of course there is obviously a lot more money to made continually treating a persons "symptoms" rather than actually trying to cure them of a disease. Seeing as how they refuse to do any testing of MMS I wonder how they determined MMS was the cause of these "adverse reactions"?
Could that life threatening condition have been someone simply gagging on the taste?
I could at least relate to that.
Using the original protocol mixing it with organic apple juice instead of water helped to improve the taste but ruined the taste of some really good juice.
This new protocol looks like it could be a real improvement.
I also spend a lot of time at a health forum and the following is a link to a large section on MMS. For those interested there maybe some information there not found here.
Alternative Therapies Forum
Thank you Mad Scientist. I'm using MMS myself and it brought my health back in order on several occasions without any adverse effects.Originally posted by Mad Scientist View PostSounds like big phrama is up to their usual tactics of trying to shut down all competition.
Simply comparing it to the household bleach is ignorance. They haven't tested and they're not going to. Same with DMSO. There was enough trials and research done on it and as a result - I can get some if I bring my animal to the vet.
If they would use large print on each vial of drugs they sell, clearly stating associated risks and possible side effects, I bet, more people would search for alternative treatment. I have recently talked to a nurse about her family member. At least she was aware - " Yeah, I know it damages my son's liver but it seems to help a bit. What else I can do"?
They're the real drug lords making the rules and legalizing (licensing) whatever brings profit. Even death....
V'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
When you mix 28%NaClO2 with 50%Citric acid in 1:1 ratio the color after few seconds is like you describe: orange-brown. For me it is OK.Originally posted by AetherScientist View PostI've prepared MMS but the color of the solution after around 1 minutes is orange-brown. I've seen some videos where people get a yellow color.
Is important the difference of color I get and can affect the solution?
In a cold ambient the reaction produces a little ligther color more like yellow-orange.
See the last 2 videos of Jim Humble, he made some mixes, could help to make a visual comparison.
The color you have described is correct. When diluted with water it will change to pale yellow.Originally posted by AetherScientist View PostI've prepared MMS but the color of the solution after around 1 minutes is orange-brown. I've seen some videos where people get a yellow color.
Originally posted by Mad Scientist View PostI would be leery of this color difference.
When mixing two chemicals together you should get the same result as everyone else.
If your mixing ratios are correct, would say that something is contaminating your mixture.
When I add more citric acid 1:2 or 1:3 (I usually mix NaClO2 with Citric Acid in the ratio 1:1) I get a yellow-bright solution.
Can you write the links to the videos?Originally posted by charly2 View PostWhen you mix 28%NaClO2 with 50%Citric acid in 1:1 ratio the color after few seconds is like you describe: orange-brown. For me it is OK.
MMS on trial
Grand Jury to Determine
the Fate of Daniel Smith (and MMS)I Am Not An Animal
The FDA seeks to have the courts declare MMS a "drug" subject to regulation by the FDA and to charge Daniel Smith of Project GreenLifeI Am Not An Animal
