Red Led Light Therapy
  • #46
    I may be missing something in my Red LED Christmas light set up if 292 frequency is the part that helps with healing. I also play the healing 528 Solefeggio frequency while using the red light board. Anyway, I don't have a lot of knowledge in using a freqency generator so, what's my next step for my panel in order to get the full benefits?
    • #47
      You need a source of stable frequency pulses which can be adjusted to the one of your choice. This can be either frequency generator, astable oscillator generating square wave made on transistors or integrated circuit such as NE555, LM393. You also need electronic switch capable of turning LED panel on and off according to driving pulse. Those IC based oscillators can handle mA's only. This part can be done with single transistor, Mosfet or solid state DC relay driven from the oscillator output. Regular relay won't work at high frequencies. While it is easy do pulse AC driven lights there will be an issue with 50 or 60Hz from mains and all related harmonics. We only want certain frequency eg. 292Hz, nothing else. For that reason I would use DC source rather than mains (110 or 220VAC).
      Vtech
      General D.Eisenhower
      http://www.nvtronics.org
      • #48
        I have a book from the library on the healing power of light and it list different colors (not just red and blue) that have healing influence on the body...such as yellow, orange, green, violet and indigo. Has anyone tried the different colors and had results? Has anyone had long lasting results with the red or blue. I thought of buying the blue light panel but found a site that list side effects for some people using blue light therpy and decided not to try that one. Perhaps a less intence form of blue light would work better, with no negative side effects? Just thinking outloud because blue is very calming.
        • #49
          color therapy
          Rozzi,
          Dinshah probably has the best material on all the multi color light therapy.
          However, from what I've seen, red and infrared alone has accomplished every benefit of all the colored light therapy. The exception is in altering the mood, which multi colors do have benefits there that the red/infrared don't.
          • #50
            • #51
              Just curious...Has anyone done the red light therapy with any positive results? I used the red light panel for almost 2 months from 15-40 minutes per day and so far with no notable results.
              • #52
                Yes. I healed my eye doing three 10min session of pulsed at 292Hz 660nm light.
                I'm still working on portable unit with all seven frequencies. Please visit Energy Science Forum - Electronic Healing Technologies - Red Light Therapy for details.
                Vtech
                • #53
                  red light therapy
                  Rhozzi,
                  Is the red light steady or pulsed?
                  And can you share the exact benefit you're trying to gain?
                  • #54
                    I used the deep red light panel that can be found at ledwholesale. I thought I read that a deeper red would be beneficial, even without the pulsing. I stopped using my christmas light panel with the 2 blinking red lights I had put together once I received the professionally made panel. (It does not pulse that I know of).
                    I want to see clearly again (disease-macular degeneration) and get rid of a sore on my temple that has not gone away in 3-4 years. I keep it under control with bag balm and some times use tumeric (tumeric can kill tumors).
                    • #55
                      red light closness
                      In order for red light to be helpful to eyes or skin does it have to be up against the skin or just very close?
                      • #56
                        For macular degeneration, this is what we found.
                        Our associate's mother was in her 80's and had severely advanced macular degeneration. She stopped going out, stopped going to Church, etc... she couldn't even make out people's faces anymore.
                        3 times a day, she would shine the red led's in her eyes for 10 minutes at a time pulsed at 292 times per second. In about 6 weeks, it had reversed enough where she could start making out faces and about 6 weeks after that, it had improved so much, she could could tell the difference in coins (pocket change) and was going back to church and going back out elsewhere. It had turned her life around.
                        The red LED's are much brighter these days. That was about 12 years ago or so. I wouldn't recommend doing that directly in the eye. What I do myself just for a good boost to the eyes is I close my eye lids and shine the led's right on them.
                        Anyway, that is the only experience I know of someone near me that received benefits for macular degeneration and red leds.
                        • #57
                          Thank you so much for those encouraging words. I haven't yet found a way that I can pulse my red light panel to 292. I don't know very much about electronics as some do that are on this forum. I've tried to find some kind of device I can plug into the wall and attach my panel to make it pulse. Hasn't happened yet. But, thank you again.
                          • #58
                            steady light
                            Rhozzi,
                            You can try it with steady light.
                            Please understand I'm not giving medical advice - I'm just sharing
                            my experience.
                            • #59
                              I understand you're not giving medical advice. I just appreciate the sharing of someone being helped with the red lights.
                              • #60
                                Hi rhozzi,
                                I should have my device ready within a week or so. It will work with one/couple 30W or less LED panels as well as stylus pointer for small areas (point treatment). Circuit isn't complicated, even for a beginner and was intended to be that way, rather than using Arduino or other programmable microprocessors.
                                There is no need to complicate and confuse. I mainly post on Energy Science Forum> Electronic Healing Technologies due to the work load.
                                If you wish to have something build and need a hand I'll be happy to assist.
                                Below is one of my setups with 711 LED panel and (unfinished) control unit on the right. It will have all 7 frequencies available.
                                Vtech
