The Energy Cleaner ... personal experiences
  • #46
    Originally posted by whwm01 View Post
    Dupe, your Energy cleaner diagram never showed up.. I think I have a general understand of what I'm doing here, that is until the whole timer system. I'm still fairly confused with that. Generally speaking, I'm just not sure what type of timer/relay or 1 hour per rev clock type moter that I'm supposed to use. I have found the wiring at home here so I'm good on that, I plan on buying the screen and battery holders tomorrow.
    What type of metal am I looking for when purchasing this screen?
    I plan on using Ebay to order the remainder of parts needed unless Home Depot surprises me and would happen to have anything else needed.
    Sorry about the missing info, I'll look into that. You can use aluminium mesh screen... it's available here in the UK in various sizes and is the cheapest option. You will need to tape around the edges with a strong PVC tape cover the rough edges. I also have a 1mtr x 1mtr stainless fine mesh screen I use, but is expensive to purchase! Ali is ideal and cheaper.
    Will have a look why the diagram didn't post? .... probably me. Dupe
    • #47
      Cell switching diagram
      Here is the missing diagram of the mechanical ...polarity switching arrangement.
      Still no good, sorry.
      Last edited by Dupe; 12-22-2010, 10:42 AM. Reason: Attempting to post photo image!!
      • #48
        Energy Cleaner
        Hi whwm01,
        For my original mechanical unit I used a battery clock module from an old wall clock. Cut out a round thin disc and glued a plastic bush in the centre. to push onto the hour drive shaft. The disc was cut into four segments to operate a "light action lever" micro switch. The switch had change over contacts to achieve the polarity switching. By careful adjustments the disc would operate the switch without introducing to much drag force, and the module just needed an "AA" battery to run. This method is probably by far the simplest way for you, and gave me the encouragement to progress further using electronics circuits. Dupe
        • #49
          Cell Pack
          This diagram shows the Cell layout for the 3 volt version connected to a change over switch or relay. The green wire is connected directly to the screen and toggles between the RED positive and BLACK negative battery terminals every 15 mins.
          • #50
            Actuator disc and drive motor
            Hear is my first mechanical configuration using a battery powered wall clock module. The disc was cut to provide a switching motion every 15 mins. Micro switches are available with various operating levers and one that requires very little switching force would be ideal. Some time needs to be spent to achieve the ideal t15 min switch period.
            • #51
              Thanks Dupe, I'll let ya know how things go
              • #52
                Thanks for the diagram Dupe . Can you repost it as JPG or PNG? It seems to be autoscaled.
                I notice that you use plate for battery contact? Is it copper? Because I read that by putting a copper plate on each hand that connect to other two copper plate arranged like a capacitor, where one plate is on top of other can also be used as healing device too.
                However, there seems to be precation for not to use it too long.
                • #53
                  Hi sucahyo, Thank you. The plate I used was a piece of paxolin type board laminated either side with a very thin aluminium foil covering. I have no idea what it was originaly intended for other than RF screening may be. If you check out the "Lee Crock" first models, he used copper plate. I just wonder if using plates... (perhaps copper) is the concept behind how this device works? and the reason for using so many cells!!
                  By arranging 10 x"D" cells as per diagram with contact plates either side of a certain dimension you end up with an antenna... dipole!! with a low voltage bias on each side. The plates act as collectors to natural energy fields and transfered to the screen via the connecting wires. I may be completely wrong here of course, as replications use battery holders!
                  I'll leave my theory with you to study further... BTW which of the diagrams do you want resending? and I'll see what I can do. regards Dupe
                  • #54
                    Your welcome... hope the diagrams help. Good to see somebody else jumping in here to try out this device.
                    • #55
                      Thanks.
                      I read that different metal may give different kind of energy if arranged like that. I think you should try to feel if there are any difference if you change battery orientation or direction.
                      See if changing it with copper change the effect. Some believe alumunium give different effect to the body than copper.
                      "Polarity switching" is too small for me. JPG will have smaller file size than BMP that you may post it at original size. Thanks.
                      • #56
                        Thanks.
                        I have just altered the software to provide an hour long period between pre selected times. So will trial it and report back. My next version will be copper plates. I've resent the polarity switching diagram also
                        Last edited by Dupe; 12-24-2010, 03:55 PM. Reason: double posted and missed Attachment
                        • #57
                          Thanks.
                          • #58
                            With nuclear energy there is only water vapor given off from the cooling towers and the storage of the radioactive waist. However, There are breeder reactors that can enrich or "breed" the "spent" uranium into plutonium. It breed fuel by producing more fissile (capable of sustaining a chain reaction) material than it consumes. So imagine recycling one soda can and getting more and more from that one.
                            Shopping Articles|Top Ten Floral Perfumes
                            • #59
                              Thanks Dupe, thanks for the picture too .
                              • #60
                                Dupe, I haven't had the chance yet to go and build this but will one day soon. Thanks for all of your help explaining things out. I have another question that I've been working on figuring out and you might be able to help me? Do you have an idea on how a guitar Ebow works? I have a general idea on how they work, yet I'm sort of clueless. Reason I ask is I'm looking to build my own. Here are some links explaining the device -
                                Ebow Technical Analysis
                                EBow - Wikipedia, the free encyclopedia
                                YouTube - E-bow diy ask me how to make your own! Over Marooned- pink floyd - A guy built his own here.
                                Thanks bud!
