Air Ion Measurement
  • Air Ion Measurement
    Hello Everyone!
    Have finally decided to stop lurking and join
    I was hoping that some people here on the forums have had experience with measuring ionisation of air and the relation of negative ion polarity and health benefits. My intention is to buy an 'Air Ion Counter' and measure around my workplace and at home the positive(nasty) ion count and correlate these days to my mood etc.
    My background for the last 15 years has been in IT and electronics. As the years have progressed and the complexity of the environment has changed. I have noticed my mood and general well being isnt so great anymore. Years of working under synthetic lighting and in data centers with no windows and big loud AC has drained me.
    I have heard of postive ions being generated from pretty much anything IT and would like to take the scientific road and get a measuring device of some sort. Has anyone used a commercially available unit to do their own testing before? Not sure if moderation allows product placement, but if not please PM me. :-)
    I recommend my radiant sleeping aid.
    I highly believe that the circuit are similar to negative ion generation.
    I also highly believe what can produce "positive ion" is not just high voltage and I prefer to call it deadly orgone or positive od.
    You can also make your own with car coil but make sure that you connect the common terminal to the battery positive. I think it is much much better if you drive the car coil with digital switching. If you don't have relay, I think my stingo is much better than 555 one.
    I am an IT network admin and I have been running my circuit in my office (not always in HV mode) and 5 other IT member feel our room cooler than other room, feel more refreshing too.
    I have a bunch of other device too, but it seems the others would notice fresh air more if I run it on negative HV ionizer mode.
    BTW, if you replicate my sleeping aid and you don't feel "wrong" anymore turn off the device or you may nap during the work lol. If you feel you need physical boost, reverse the polarity. The electrode do not need to touch the skin to feel its effect.
      Hi Sucahyo! I'm a Net Admin also :-)
      Thanks for the info, I was actually reading about your electronic sleeping aid this morning. It looks very interesting and it is directly inline with my thinking at the moment, i.e. making a device to emit beneficial energy and experiment with it. I also have a friend who makes orgone generators and will probably ask him to make myself one.
      I went to work feeling awesome this morning (weather change), I then spent 3 hours in our data center, an hour later drained again. I think my workmates already think I'm a bit quacky enough, without placing a radiant device in the workplace. hehe. On off days I wear a Q-Link pendant but after 12 months of experimenting with it, it seems to have little beneficial effect and therefore subjective, it may as well be a talisman.
      I think I am just going to 'bite-the-bullet' and purchase an Ion Counter. They are approx. US$450 I believe for a handheld gadget. In the meantime I'll be experimenting with some radiant circuits :-)
        Be carefull with pendant or orgone generator. If their purpose is to boost your energy then it can make your problem worse.
        my passive version is this, it is important that you do not use crystal:
        It maybe a good solution since you may have no place for ungrounded water. although you may stick the positive radiant part to air conditioner water waste pipe.
        I believe that what you need right now is something that can produce clear ice. Freeze your pendant and see if it produce clear ice. Some pendant or talisman may worn out over time and may produce something different from their fresh one.
        For quick solution, some say carrying magnet help.
          Thanks for the info Sucahyo, I sort of went down a rabbit hole of related posts on youtube. All very interesting videos.
          I've placed the Qlink pendant in the freezer(in a cup of purified water). I'm very curious to see the 'cloudiness' if any. I was once told by a healer to be wary of cloudy crystals as the energy has been distorted. Could be a very good hypothesis :-) I will report back when i can.
            Thanks .
            I think even anything can be forced to be cloudy.
            I will look forward for your result .
              Some experiments
              Sorry for the delayed reply, been a hectic weekend.
              Here's the ice block with the pendant in it. As you can see still very cloudy, I'm going to tinker with this some more as i feel I could place it better and do a few more control tests.
              Photo1:
              Very interesting phenomenon though is the huge lump that formed on top of the cube. almost an inch in height
              Photo2:
              And the control block that was in a sealed container:
              I will be tinkering for the next couple of weeks. I'll post anything out of the ordinary. :-) next up neodymium magnets and a water vitaliser.
              Would be nice if i could capture a water crystal photo like Dr Emoto.
                Thanks for the photos .
                I think your pendant produce male energy, shown by foggy ice and lump.
                I think neo would produce less, but I will look forward for your result .
