Electric field detox
  • Electric field detox
    I'll start this with a story of a very special gift that was given to me, through a Lady Bug. This is not a joke, nor embellished.
    About a year and a half ago, I was as my friend's house, caring for his neglected dog, who has countless cancerous lumps all over his body. I was trying to figure out how to feel energy and manipulate it to work some of the crap out of him, but I wasn't really getting anywhere. I finally gave up. I'm pretty sure I prayed for guidance to understand how to do it.
    An hour later I went home and went to my room, which was filled with ladybugs, because it was spring time. I noticed that nearly every one of them had discolorations, and imperfect markings, or no markings. The one Ladybug that looked like it was healthy landed on me, and sat on the palm of my hand.
    It began moving its front legs in circles over my hand, and I felt a localized electric field. Every once in a while it would move a leg very quickly straight down or straight up, and I felt a small impulse. It began to slowly move in a circle on my hand while doing this. I started to take my other hand, and put it behind the hand with the Ladybug on it, also moving it in circles in and out, feeling how I could create a similar effect, and also transfer energy back and forth between my hands and the insect.
    This was all very amazing to me, but the thing that happened next was so beautiful I actually cried. The Ladybug got on its back, with its wings slightly spread so as to create a tripod between the end of its body and its wing-shell tips. It continued to move in a circle, while on its back. I continued to provide input from my free hand, as it showed me how to.
    Suddenly small, black, oily threads began surfacing around the insect. It used its front two legs to scoop up these threads, one by one, and pass them down to its lower legs, which balled them up. The ball looked like shiny black oil, and I know it was, or similar to it. I need to make an animation or drawing, because words can't compare to what I saw and felt.
    As this continued, I felt like the Ladybug was losing its power, and I saw that the oil was becoming too much to bear for it. The oil started sticking to the insect, and after a while it had to stop. It tried to clean its self, but I fear it was too late. It sacrificed its self for me to teach me this.
    (to be continued)
    As many of you know, electric fields can separate polar from non-polar things. If you're making bio-diesel for example, putting high voltage electrodes in the mix can pull the 2 parts into layers in a matter of seconds.
    I'm pretty sure that the non-polar (or maybe I have it wrong, and it's insulators, but either way, bear with me) is attracted to the positive.
    I've been trying to figure out how the holy anointing oil used by Jesus worked, on the basis that it contained mainly Cannabis oils as an active ingredient, along with ingredients to open the pores, and with anti-fungal/anti-partasitic ingredients.
    THC is known to absorb UV radiation. UV causes a positive charge. I've always felt that the oils on the cannabis plant are basically solar panels, to both electrically charge the plan, and to facilitate growth and uptake of water/nutrients through ionic conduction.
    If this is the case, slathering cannabis oil on yourself, and going out in the sun is like putting a high voltage + electrode on your skin. This in turn will draw many things out that should not be there. It seems to me that the parasites that live in my skin form fatty deposits around them, and want to avoid an electric charge at all costs. Because they are insulators and surround themselves with insulators, if you open your pores and put an electric field there, they will swim/pour/rise right out of you!
    Healthy skin is a pretty good conductor. Take a piezoelectric igniter and click it above your skin.... notice how in a healthy area it produces a blue spark, but over a scar or wound it is red and hardly conducts. The Damn FDA approves passive staticly charged plastic as scar treatment, but won't allow active electric devices.
    It seems to me that the kind of life we as humans are made of, and the plants we eat, need electric fields, and magnetic fields should be avoided at all costs.
      also, Japanese foot detox pads contain tourmaline, which is highly piezoelectric, and I'm sure you've all seen the black crap they can pull out of your feet!
        there is another devices used to detoxify the body using only electrical fields. The results, in some cases, are impressive since you see that a person rejuvenates. It's the most powerfull and fast method I've seen.
